电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » 6713头文件
6713头文件
2014-12-21 10:31:40     打赏
看到有人把头文件都贴出来了,我也跟风,把以前用的一个头文件贴出来。
/* Define EMIF Registers  */
#define EMIF_GBLCTL        (*((unsigned int *)0x01800000))    /* Address of EMIF global control        */
#define EMIF_CE1CTL        (*((unsigned int *)0x01800004))    /* Address of EMIF CE1 control            */
#define EMIF_CE0CTL        (*((unsigned int *)0x01800008))    /* Address of EMIF CE0 control            */
#define EMIF_CE2CTL        (*((unsigned int *)0x01800010))    /* Address of EMIF CE2 control            */
#define EMIF_CE3CTL        (*((unsigned int *)0x01800014))    /* Address of EMIF CE3 control            */
#define EMIF_SDCTRL        (*((unsigned int *)0x01800018))    /* Address of EMIF SDRAM control        */
#define EMIF_SDTIM        (*((unsigned int *)0x0180001C))    /* Address of EMIF SDRAM refresh control*/
#define EMIF_SDEXT        (*((unsigned int *)0x01800020))    /* Address of EMIF SDRAM extension control*/
#define EMIF_CCFG           (*((unsigned int *)0x01840000))
/* Define McBSP0 Registers */
#define McBSP0_DRR          0x18c0000   /* Address of data receive reg.         */
#define McBSP0_DXR          0x18c0004   /* Address of data transmit reg.        */
#define McBSP0_SPCR         0x18c0008   /* Address of serial port contl. reg.   */
#define McBSP0_RCR          0x18c000C   /* Address of receive control reg.      */
#define McBSP0_XCR          0x18c0010   /* Address of transmit control reg.     */
#define McBSP0_SRGR         0x18c0014   /* Address of sample rate generator     */
#define McBSP0_MCR          0x18c0018   /* Address of multichannel reg.         */
#define McBSP0_RCER         0x18c001C   /* Address of receive channel enable.   */
#define McBSP0_XCER         0x18c0020   /* Address of transmit channel enable.  */
#define McBSP0_PCR          0x18c0024   /* Address of pin control reg.          */
/* Define McBSP1 Registers */
#define McBSP1_DRR          0x1900000   /* Address of data receive reg.         */
#define McBSP1_DXR          0x1900004   /* Address of data transmit reg.        */
#define McBSP1_SPCR         0x1900008   /* Address of serial port contl. reg.   */
#define McBSP1_RCR          0x190000C   /* Address of receive control reg.      */
#define McBSP1_XCR          0x1900010   /* Address of transmit control reg.     */
#define McBSP1_SRGR         0x1900014   /* Address of sample rate generator     */
#define McBSP1_MCR          0x1900018   /* Address of multichannel reg.         */
#define McBSP1_RCER         0x190001C   /* Address of receive channel enable.   */
#define McBSP1_XCER         0x1900020   /* Address of transmit channel enable.  */
#define McBSP1_PCR          0x1900024   /* Address of pin control reg.          */
/* Define L2 Cache Registers */
#define L2CFG                   0x1840000   /* Address of L2 config reg             */
#define MAR0                    0x1848200   /* Address of mem attribute reg         */
/* Define Interrupt Registers */
#define IMH                     0x19c0000   /* Address of Interrupt Multiplexer High*/
#define IML                     0x19c0004   /* Address of Interrupt Multiplexer Low */
/* Define Timer0 Registers */
#define TIMER0_CTRL         0x1940000    /* Address of timer0 control reg.       */
#define TIMER0_PRD          0x1940004    /* Address of timer0 period reg.        */
#define TIMER0_COUNT        0x1940008    /* Address of timer0 counter reg.       */
/* Define Timer1 Registers */
#define TIMER1_CTRL      0x1980000    /* Address of timer1 control reg.       */
#define TIMER1_PRD          0x1980004    /* Address of timer1 period reg.        */
#define TIMER1_COUNT      0x1980008    /* Address of timer1 counter reg.       */
/* Define EDMA Registers */
#define PQSR                0x01A0FFE0    /* Address of priority queue status     */
#define CIPR                0x01A0FFE4    /* Address of channel interrupt pending */
#define CIER                0x01A0FFE8    /* Address of channel interrupt enable  */
#define CCER                0x01A0FFEC    /* Address of channel chain enable      */
#define ER                0x01A0FFF0    /* Address of event register            */
#define EER                0x01A0FFF4    /* Address of event enable register     */
#define ECR                0x01A0FFF8    /* Address of event clear register      */
#define ESR                0x01A0FFFC    /* Address of event set register        */
/* Define EDMA Transfer Parameter Entry Fields */
#define OPT                0*4            /* Options Parameter                    */
#define SRC                1*4            /* SRC Address Parameter                */
#define CNT                2*4            /* Count Parameter                      */
#define DST                3*4            /* DST Address Parameter                */
#define IDX                4*4            /* IDX Parameter                        */
#define LNK                5*4            /* LNK Parameter                        */
/* Define EDMA Parameter RAM Addresses */
#define EVENT0_PARAMS 0x01A00000
#define EVENT1_PARAMS EVENT0_PARAMS + 0x18
#define EVENT2_PARAMS EVENT1_PARAMS + 0x18
#define EVENT3_PARAMS EVENT2_PARAMS + 0x18
#define EVENT4_PARAMS EVENT3_PARAMS + 0x18
#define EVENT5_PARAMS EVENT4_PARAMS + 0x18
#define EVENT6_PARAMS EVENT5_PARAMS + 0x18
#define EVENT7_PARAMS EVENT6_PARAMS + 0x18
#define EVENT8_PARAMS EVENT7_PARAMS + 0x18
#define EVENT9_PARAMS EVENT8_PARAMS + 0x18
#define EVENTA_PARAMS EVENT9_PARAMS + 0x18
#define EVENTB_PARAMS EVENTA_PARAMS + 0x18
#define EVENTC_PARAMS EVENTB_PARAMS + 0x18
#define EVENTD_PARAMS EVENTC_PARAMS + 0x18
#define EVENTE_PARAMS EVENTD_PARAMS + 0x18
#define EVENTF_PARAMS EVENTE_PARAMS + 0x18
#define EVENTN_PARAMS EVENTF_PARAMS + 0x18
#define EVENTO_PARAMS EVENTN_PARAMS + 0x18
/* Define QDMA Memory Mapped Registers */
#define QDMA_OPT        0x02000000    /* Address of QDMA options register     */
#define QDMA_SRC        0x02000004    /* Address of QDMA SRC address register */
#define QDMA_CNT        0x02000008    /* Address of QDMA counts register      */
#define QDMA_DST        0x0200000C    /* Address of QDMA DST address register */
#define QDMA_IDX        0x02000010    /* Address of QDMA index register       */
/* Define QDMA Pseudo Registers */
#define QDMA_S_OPT        0x02000020    /* Address of QDMA options register     */
#define QDMA_S_SRC        0x02000024    /* Address of QDMA SRC address register */
#define QDMA_S_CNT        0x02000028    /* Address of QDMA counts register      */
#define QDMA_S_DST        0x0200002C    /* Address of QDMA DST address register */
#define QDMA_S_IDX        0x02000030    /* Address of QDMA index register       */
/* Definitions for the DSK Board and SW */
//操作扩展中断
//操作16C550
#define        UART_BASE_ADDR        0xA0000000
#define        OFFSET                0X00000400
#define        RBR_16C550            *((int*)(UART_BASE_ADDR+0*OFFSET))
#define        THR_16C550            *((int*)(UART_BASE_ADDR+0*OFFSET))
#define        IER_16C550            *((int*)(UART_BASE_ADDR+1*OFFSET))
#define        IIR_16C550            *((int*)(UART_BASE_ADDR+2*OFFSET))
#define        FCR_16C550            *((int*)(UART_BASE_ADDR+2*OFFSET))
#define        LCR_16C550            *((int*)(UART_BASE_ADDR+3*OFFSET))
#define        MCR_16C550            *((int*)(UART_BASE_ADDR+4*OFFSET))
#define        LSR_16C550            *((int*)(UART_BASE_ADDR+5*OFFSET))
#define        MSR_16C550            *((int*)(UART_BASE_ADDR+6*OFFSET))
#define        SCR_16C550            *((int*)(UART_BASE_ADDR+7*OFFSET))
#define        DLL_16C550            *((int*)(UART_BASE_ADDR+0*OFFSET))
#define        DLM_16C550            *((int*)(UART_BASE_ADDR+1*OFFSET))
#define        Reset16C550            *((int*)0X90080000)=0X00;Wait(100);*((int*)NULL_ADDRESS)=0x00
#define        SEND_CHAR(SendChar)        while(1){if((LSR_16C550&0x20)!=0x00)break;}THR_16C550=SendChar
//6711寄存器
#define        EXTPOL                *(int*)0x019C0008      //External Interrupt Polarity Register
#define        MUXL                *(int*)0x019C0004        //Interrupt Selector Registers
#define        MUXH                *(int*)0x019C0004        //Interrupt Selector Registers
//命令匹配
#define        RX_DATA            0x00            //正在接收数据
#define        MATCHING            0x01            //命令正在匹配
#define        MATCHED            0x02            //命令已经匹配
//状态字
#define        YES                    0x55            //    !YES=NO
#define        NO                    0xaa            //
//状态字
#define        VALID                0x55            //    !VALID=INVALID
#define        INVALID                0xaa            //
//可调参数
#define        MAX_COMMAND_NUM    5            //命令匹配时最多需要匹配的命令
#define        MATRIX_DEM        5            //进行QR分解的矩阵的维数
//空地之
#define         NULL_ADDRESS        0xAFFF0000    //FPGA的空地址
//中断开关
#define        ENABLE_ALL            CSR|=1        //开全局中断
#define        DISABLE_ALL        CSR&=0        //关全局中断
//通用IO
#define        WDI                     *((int*)0X90050000)=0x00    //看门购输入脉冲
#define        RS485_RECEIVE        *((int*)0X90010000)=0x00    //485接收数据
#define        RS485_TRANSMIT    *((int*)0X90020000)=0x00    //485发送数据
#define        CAPMODE160128        *((int*)0X90030000)=0x00    //视频模块图像格式160*128
#define        CAPMODE320240        *((int*)0X90040000)=0x00    //视频模块图像格式320*240
#define        EX_LATCH2_HIGH    *((int*)0X90090000)=0x00    //扩展IO 2 置低
#define        EX_LATCH2_LOW        *((int*)0X900A0000)=0x00    //扩展IO 2 置高
#define        EX_LATCH3_HIGH    *((int*)0X900B0000)=0x00    //扩展IO 3置低
#define        EX_LATCH3_LOW        *((int*)0X900C0000)=0x00    //扩展IO 2 置高
#define        EX_LATCH4_HIGH    *((int*)0X900D0000)=0x00    //扩展IO 4置低
#define        EX_LATCH4_LOW        *((int*)0X900E0000)=0x00    //扩展IO 2 置高
//多路选通
#define        TXD_TO_TXDOUT1    *((int*)0X90200000)=0x00    //16c550的串行输出到第一路232
#define        TXD_TO_TXDOUT2    *((int*)0X90210000)=0x00    //16c550的串行输出到第二路232
#define        TXD_TO_RS485DI    *((int*)0X90220000)=0x00    //16c550的串行输出到485
#define        RXDIN1_TO_RXD        *((int*)0X90230000)=0x00    //第一路232输出到16c550的串行输入
#define        RXDIN2_TO_RXD        *((int*)0X90240000)=0x00    //第二路232输出到16c550的串行输入
#define        RS485RO_TO_RXD    *((int*)0X90250000)=0x00    //485输出到16c550的串行输入
//LED
#define        LED                    0x90202018
#define        LED1_ON            *((int*)0x90202018)|=0x80000000
#define        LED1_OFF            *((int*)0x90202018)&=0x70000000
#define        LED2_ON            *((int*)0x90202018)|=0x40000000
#define        LED2_OFF            *((int*)0x90202018)&=0xB0000000
#define        LED3_ON            *((int*)0x90202018)|=0x20000000
#define        LED3_OFF            *((int*)0x90202018)&=0xD0000000
#define        LED4_ON            *((int*)0x90202018)|=0x10000000
#define        LED4_OFF            *((int*)0x90202018)&=0xE0000000
#define        LED_ALL_ON            *((int*)0x90202018)=0xff000000
#define        LED_ALL_OFF        *((int*)0x90202018)=0x00000000
//常用常数
#define        LONG_BUAA            116                //北航的经度
#define        LAT_BUAA            39                //北航的纬度
#define        Wie                    0.0041667        //地球自转角速度
#define         PI                    3.1415926        //PI
#define        uchar                unsigned char
#define        FLASHMAP1ADDRESS  0x90000000    //flash首地址
