这是关于蓝桥杯备赛路上练习的小程序,蓝桥杯的竞赛路上希望大家互相勉励。 祝大家有个好成绩。 以下代码是我利用手头上小红板(JW-51)训练的小程序。 希望大家一同进步。 #include<reg52.h> //利用中断使二极管正向或反向流动 #include"intrins.h" typedef unsigned int u16; typedef unsigned char u8; unsigned char code wei[]={0xfe, 0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; bit flag; void delay(u16 n) { u8 i ; while (n--) for(i=0;i<125;i++); } void main() { u8 aa=1; EA=1; EX0=1; IT0=1; while(1) { P1=0xff; delay(500); P1=wei[aa-1]; delay(500); if(flag==0) {aa++; if(aa==9) aa=1;} else {aa--; if(aa==0) aa=8;} } } void Ex0() interrupt 0 { EX0=0; flag=~flag; EX0=1; } #include<reg52.h>//利用中断1使数码管显示1-10 typedef unsigned char u8; typedef unsigned int u16; sbit ser=P2^7; sbit srclk=P2^6; sbit rclk=P2^5; unsigned char code smgduan[]={0x3f, 0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f, 0x77,0x7c,0x39,0x5e,0x79,0x71}; unsigned char code smgwei[]={0xfe, 0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; u8 j; void DelayMs(u16 n); void DispSmg(); void send_595(u8 dat); main() { EA=1; EX1=1; IT1=1; while(1) { send_595(smgwei[0]); send_595(smgduan[j]); rclk=0; rclk=1; DelayMs(200); } } void DelayMs(u16 n) { u8 i; while(n--) for(i=0;i<113;i++); } void send_595(u8 dat) { u8 i; for(i=0;i<8;i++) { if(dat&0x80) ser=1; else ser=0; srclk=0; srclk=1; dat=dat<<1; } } void Ex1() interrupt 2 { EX1=0; j++; if(j==10) j=0; EX1=1; } #include <reg52.h>//利用定时器1使LED实现闪烁 #define uchar unsigned char #define uint unsigned int uchar Led,Count; void main() { Led = 0x00; EA = 1; ET0 = 1; TMOD = 0x01; TH0 = (65536-46080)/256; TL0 = (65536-46080)%256; TR0 = 1; while(1) { P1 = Led; } } void timer0() interrupt 1 { TH0 = (65536-46080)/256; TL0 = (65536-46080)%256; Count ++; if(Count == 20) { Count = 0; Led = ~Led; } }
共4条
关于蓝桥杯训练小程序(2)中断练习
关键词: 中断 蓝桥 练习
共4条
有奖活动 | |
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! |
打赏帖 | |
老胖子聊电路--分析一个反馈电路被打赏50分 | |
