Temperature Monitoring Using the MAX1253/54 and MAX1153/54
关键词: temperature, thermometer, diode, thermistor, thermister, ADC, die temp, temp, system monitor, diode sensor, analog to digital converter
Abstract: The MAX1253/54 and MAX1153/54 system monitors are a low cost solution for monitoring multiple temperatures in a system. This application note explains how to measure temperature using remote sensing diodes in single-ended or differential configuration and possible error sources.
Temperature Monitoring Using the MAX1253 54 and MAX1153 54.pdf
有奖活动 | |
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! |
打赏帖 | |
老胖子聊电路--分析一个反馈电路被打赏50分 | |
