-- TTL164 Shift Register library IEEE; use IEEE.Std_logic_1164.all; ENTITY dev164 IS PORT(a, b, nclr, clock : IN BIT; q : BUFFER BIT_VECTOR(0 TO 7)); END dev164; ARCHITECTURE version1 OF dev164 IS BEGIN PROCESS(a,b,nclr,clock) BEGIN IF nclr = '0' THEN q <= "00000000"; ELSE IF clock'EVENT AND clock = '1' THEN FOR i IN q'RANGE LOOP IF i = 0 THEN q(i) <= (a AND b); ELSE q(i) <= q(i-1); END IF; END LOOP; END IF; END IF; END PROCESS; END version1;
共1条
移位寄存器:74164
共1条
有奖活动 | |
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! |
打赏帖 | |
老胖子聊电路--分析一个反馈电路被打赏50分 | |
