电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Wi-Fi无线连接启动低功耗物联网应用
Wi-Fi无线连接启动低功耗物联网应用
2019-03-18 10:52:05     打赏
Siddarth Sundar - Senior Product Manager, Wi-Fi Solutions
Over the last two decades, Wi-Fi has transformed connectivity with more than 15 billion installed devices in the world.
Such a broad and pervasive installed base, along with its throughput capabilities and native IP capabilities, makes Wi-Fi an attractive protocol for IoT wireless applications. However, a key limitation of most Wi-Fi based IoT systems is high power consumption. As Wi-Fi was primarily designed to optimize bandwidth, using traditional Wi-Fi in power constrained battery powered applications can be a significant challenge. This whitepaper discusses the factors contributing to Wi- Fi power consumption, different power saving modes, as well as design and hardware considerations for optimizing power consumption and extending battery life in IoT devices.
关键词: silicon labs     Wi-Fi无线     物联网
