电子产品世界 » 论坛首页 » 综合技术 » 有熟悉TDA7050功放芯片的吗?
有熟悉TDA7050功放芯片的吗?
2005-04-12 21:10:22     打赏
帮帮忙翻译一下这段话,谢谢了!
Features · Limited to battery supply application only (typ. 3 and 4 V) · Operates with supply voltage down to 1,6 V · No external components required · Very low quiescent current · Fixed integrated gain of 26 dB, floating differential input · Flexibility in use - mono BTL as well as stereo · Small dimension of encapsulation (see package design example)
关键词: 熟悉     TDA7050     功放     芯片
