电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 请帮我看看这是什么问题
共3条 1/1 1 跳转至
请帮我看看这是什么问题
2005-09-14 16:33:37     打赏
本人是菜鸟,交叉编译成功后下载到开发板,不能成功运行,请指教。
go 40000
## Starting application at 0x00040000 ...
Linux version 2.4.17-uC-pre5 (root@localhost) (gcc version 2.95.3 20010315 (release)(ColdFire patches - 20010318 from http://fiddes.net/coldfire/)(uClinux XIP and shared lib patches from http://www.snapgear.com/)) #304 二 9月 13 12:01:25 CST 2005
Processor: Samsung s3c2500(arm940T)s revision 2
Architecture: SMDK2510-AN
On node 0 totalpages: 4096
*** bit_mapsize =0x1000, zones_size[0]=0x800, zones_size[1]=0x800
*** bit_map =0x1da040, lmem_map=0x19a000
*** normal map/size=0x1da040/ 0x800, dma map/size =0x1da140, 0x800
*** start of dma page =0x800
*** first_usable_page_normal /dma= 0x1da/ 0x800
*** first_usable_page = 0x1da, p= 0x1da000
zone(2): 0 pages.
zone(1): 2048 pages.
zone(0): 2048 pages.
Kernel command line: root=/dev/rom0
Calibrating delay loop... 117.96 BogoMIPS
Memory: 16MB = 16MB total
Memory: 14484KB available (975K code, 228K data, 172K init)
Dentry-cache hash table entries: 2048 (order: 2, 16384 bytes)
Inode-cache hash table entries: 1024 (order: 1, 8192 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
POSIX conformance testing by UNIFIX
S3C2510 PCI Host Controller Initializing...
Found 00:00 [144d/a510] 000600 00
Found 00:28 [16f4/8000] 000400 00
Fixups for bus 00
PCI: bus0: Fast back to back transfers enabled
got res[2000000:20000ff] for resource 2 of PCI device 144d:a510 (Samsung Electronics Co Ltd)
got res[0:1ffffff] for resource 0 of PCI device 144d:a510 (Samsung Electronics Co Ltd)
got res[2000000:201ffff] for resource 0 of PCI device 16f4:8000
got res[2020000:2020fff] for resource 1 of PCI device 16f4:8000
got res[2021000:2021fff] for resource 2 of PCI device 16f4:8000
got res[2022000:20221ff] for resource 1 of PCI device 144d:a510 (Samsung Electronics Co Ltd)
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Initializing S3C2510 buffer pool for DMA workaround
Starting kswapd
S3C2510X Serial I/O driver. Version 2.5.23 <oleks@arcturusnetworks.com>
ttyS0: at 0xf0060000 (IRQs: Tx=11 Rx=12) is a builtin Console UART
ttyS1: at 0xf0070000 (IRQs: Tx=07 Rx=08) is a builtin High-Speed UART
ttyS2: at 0xf0080000 (IRQs: Tx=09 Rx=10) is a builtin High-Speed UART
block: 64 slots per queue, batch=16
RAMDISK driver initialized: 16 RAM disks of 1024K size 1024 blocksize
ethif_probe
eth0: S3c2510-0 found at f00a0000, 00.09.30.28.12.22.
np->txfd 0: 195000
ethif_probe
eth1: S3c2510-1 found at f00c0000, 00.09.30.28.12.24.
np->txfd 1: 195200
ethif_probe
ethif_probe
ethif_probe
ethif_probe
ethif_probe
ethif_probe
Blkmem copyright 1998,1999 D. Jeff Dionne
Blkmem copyright 1998 Kenneth Albanowski
Blkmem 1 disk images:
0: 80020000-8012F3FF [VIRTUAL 80020000-8012F3FF] (RO)
SCSI subsystem driver Revision: 1.00
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
usb_hub_event
usb-ohci.c: USB OHCI at membase 0xf0100000, IRQ 13
usb-ohci.c: usb-s3c2510, usb-ohci
usb.c: new USB bus registered, assigned bus number 1
devnum: 0 ,roothub's devnum 0
control request :500 ,request type: 0,request 5
devnum: 1 ,roothub's devnum 1
control request :680 ,request type: 80,request 6
control request :900 ,request type: 0,request 9
hub.c: USB hub found
control request :6a0 ,request type: a0,request 6
hub.c: 2 ports detected
control request :a0 ,request type: a0,request 0
interrupt transfer with root hub
control request :323 ,request type: 23,request 3
usb_hub_event
Initializing USB Mass Storage driver...
usb.c: registered new driver usb-storage
USB Mass Storage support registered.
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 1024)
NetWinder Floating Point Emulator V0.95 (c) 1998-1999 Rebel.com
VFS: Mounted root (cramfs filesystem) readonly.
BINFMT_FLAT: reloc outside program 0xc05b0000 (0 - 0x80f0/0x5ba0), killing init!
BINFMT_FLAT: reloc outside program 0xf30000 (0 - 0x12c70/0xf2e0), killing sh!
Kernel panic: No init found. Try passing init= option to kernel.
关键词: 请帮     我看     看这     是什么     问题     devnum     ro
2005-09-15 01:00:00     打赏
elf2flt文件错误
2005-09-20 23:34:00     打赏
请问那我该怎么做?
共3条 1/1 1 跳转至
