共1条
samsung snds100 BSP出现“check sum do not match”的讨论结果!
我以前在坛子里面发过一篇关于samsung snds100 BSP出现“check sum do not match”的问题,但没有得到想要的结果,虽说这种警告提示对设计没有什么实质的影响,但不解决总觉得不舒服,前几天只好到google的新闻组重提此问,总算有了较清晰的线索,特帖以此,希望大家再讨论,并活跃坛子里的气氛.
所有留言及回应
Message 1 in thread
寄件者:seasoblue (seasoblue2000@yahoo.com.cn)
主旨:Check sum Error!------ Who can help me?
新闻群组:comp.os.vxworks
View this article only
日期:2002-07-14 23:05:32 PST
Hi,all
A trouble always troubles me.My debug enviroment includes tornadoII,
and Samsung snds100 board which with a arm7tdmi kernel inside.
I have finished connecting target board with my tornadoII,but afer I
start up my target server,I get warning messages:
"TGTSVR (arm@seasoblue): Mon Jul 15 13:41:11 2002
Wind River Systems Target Server: NT/Win95 version
Connecting to target agent... succeeded.
Attaching C++ interface... succeeded.
Attaching coff OMF reader for ARM CPU family... succeeded.
Warning: Target checksum: 0xdb3d (computed from 0x1000 to
0x81114).
Host checksum: 0xe96a (computed from 0x69c970 to
0x71ca84).
Warning: Core file checksums do not match."
oh,it tells me:checksums do not match! But my target and host do use
the SAME core file(vxwork image) in the SAME directory!
Could anybody give me a hint that how to configure my target server
to solve this problem?
Please give an example in detail ,thanks a lot !
Post a follow-up to this message
Message 2 in thread
寄件者:Leonid Rosenboim (MY_FIRST_NAME@CONSULTANT.COM)
主旨:Re: Check sum Error!------ Who can help me?
日期:2002-07-15 01:51:54 PST
This cold be a BSP bug (I have experience this a long time ago on some i960
BSPs from WRS).
What may happen is that a variable (typically assembly, e.g. sysALib.s,
romInit.s) is put by mistake into the code segment, and gets modified in run
time, so its value in RAM would fiffer from its value in file.
This is relatively easily fixed by anyone with BSP experience, and even
easier by the person who wrote this particular BSP initially.
"seasoblue" wrote in message
news:e82d8e83.0207142205.33a063a2@posting.google.com...
> Hi,all
> 0x81114).
> 0x71ca84).
Message 3 in thread
寄件者:Johan Borkhuis (borkhuis@agere.com)
日期:2002-07-15 04:54:17 PST
seasoblue2000@yahoo.com.cn (seasoblue) wrote:
> Hi,all
> 0x81114).
> 0x71ca84).
This means that your target server is pointing to a different image than
that is loaded on the target. Check thee configuration of the target
server and check the boot parameters of your target.
Groeten,
Johan
o o o o o o o . . . _____________________________
o _____ || Johan Borkhuis |
.][__n_n_|DD[ ====_____ | borkhuis@agere.com |
>(________|__|_[_________]_|__________________________|
_/oo OOOOO oo` ooo ooo 'o!o!o o!o!o`
=== VxWorks FAQ: http://www.xs4all.nl/~borkhuis/vxworks/vxworks.html ===
Message 4 in thread
寄件者:Jankesh Piparia (cjp054@email.mot.com)
日期:2002-07-15 10:35:28 PST
This could happen if you are using a rommable version of
the vxWorks. (vxWorks_rom or vxWorks_romCompress)
Are you using this ?
-Jankesh
seasoblue wrote:
> Hi,all
> 0x81114).
> 0x71ca84).
Message 5 in thread
日期:2002-07-17 03:01:27 PST
Jankesh,
I just use "vxworks" image,not "vxworks_rom" or"vxworks_romCompress".
Johan,
I config the core file in target
server:"D:\Tornado\target\config\santai\vxWorks",and symbols:"Global
symbols".In config.h file,I config the default line like this
:"#define DEFAULT_BOOT_LINE \
"secEnd(0,0)aman:/tornado/target/config/santai/vxWorks
h=192.168.0.110 e=192.168.0.221 u=hugh pw=0000 tn=snds100",
there is only a tornado install directory in my PC,so the core file
in target and host is same.
Maybe What Leonid Rosenboim said is right.But would you give me and
other newbie a detail explain?
Best Regards,
seasoblue
Message 6 in thread
日期:2002-07-17 10:23:05 PST
news:e82d8e83.0207170201.49dd6680@posting.google.com...
> Best Regards,
> seasoblue
Let me try to explain some more:
in "C" when you define a global (or static) variable, it automatically goes
to either "data" or "bss" segment, so the "text" segment that contains
executable code is not modified in memory after booting.
But in Assembly, the source program can place variables in any segment, and
this placement is done explicitly, e.g.
.data
.word 0x0505 /* some initialized data */
.text
/* executable code */
Now, if one puts a variable or a table, or anything else that changes at
run-time in the "text" segment, the TGTSVR will fail the checksum comparison
of the file and memory images of this "text" segment. Other segments are not
checked because it is EXECTED they will be changed in memory.
I suggest you direct this to the author of your BSP.
- Leonid
Message 7 in thread
寄件者:degang (wdg@bjhhl.sina.net)
日期:2002-07-16 23:59:25 PST
i have the same problem; i don't know how either
"seasoblue"
??????:e82d8e83.0207142205.33a063a2@posting.google.com...
> Hi,all
> 0x81114).
> 0x71ca84).
Message 8 in thread
寄件者:John Kevin Fabiani (nospam@nospam.net)
日期:2002-07-17 23:37:03 PST
"degang" wrote in message
news:ah34kc$1c6u$1@mail.cn99.com...
> "seasoblue"
> > Hi,all
> > 0x81114).
> > 0x71ca84).
Pretty sure Leonid hit the nail on the head when he posted:
"What may happen is that a variable (typically assembly, e.g. sysALib.s,
easier by the person who wrote this particular BSP initially."
> > Warning: Target checksum: 0xdb3d (computed from 0x1000 to 0x81114).
0x80114
> > 0x71ca84).
0x80114.
I'd say Leonid is correct.
-j
Message 9 in thread
寄件者:David Laight (david@spamm.me.l8s.co.uk)
日期:2002-07-18 01:44:01 PST
Indeed - in my experience the checksum error doesn't matter.
Provided, that is, that the target server has the correct vxworks image.
(My system had always patched its own code by the time the target server
could attach... I then removed the host tools support anyway - I wasn't
using it.)
If it has the wrong image you don't get very far!
(There are no HARD checks for a few items being at the correct
addresses, so the target server will just stomp all over the target
if you have the wrong file.)
David
关键词: samsung snds100 出现 check
共1条
有奖活动 | |
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! |
打赏帖 | |
老胖子聊电路--分析一个反馈电路被打赏50分 | |
