电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 357482894的进程贴-预习篇
共13条 2/2 ‹ 1 2 跳转至页
2012-10-18 15:50:34     打赏
11楼
我也是新手。。。
相互学习,呵呵
2012-10-18 16:23:22     打赏
12楼
10.18数码管静态显示
数码管以静态方式显示,循环0-f计数,每个循环完成后显示位数循环增加一位,效果演示:
代码:
module seg (rstn,clk,dig,seg);
 input rstn,clk;
 output[7:0] dig;
 output[7:0] seg;
 reg[25:0] count;
 always @(posedge clk or negedge rstn)
  if(~rstn)  count<=1'b0;
  else if(count==26'd25_000_000)
   count<=1'b0;
  else
   count<=count+1'b1;
 reg[3:0] num_d;   //number
  if(~rstn) num_d<=4'h0;
    if(num_d==4'hf) num_d<=4'h0;
    else num_d<=num_d+4'h1;
 reg[2:0] num_s;   //seg_sel
  if(~rstn) num_s<=3'd0;
  else if(count==26'd25_000_000 && num_d==4'hf)
    if(num_s==3'd7) num_s<=3'd0;
    else num_s<=num_s+3'd1;
 reg[7:0] seg_r;
  if(~rstn) seg_r<=8'h0;
  else
  case(num_d)
   4'h0: seg_r<=8'h3f;
   4'h1: seg_r<=8'h06;
   4'h2: seg_r<=8'h5b;
   4'h3: seg_r<=8'h4f;
   4'h4: seg_r<=8'h66;
   4'h5: seg_r<=8'h6d;
   4'h6: seg_r<=8'h7d;
   4'h7: seg_r<=8'h07;
   4'h8: seg_r<=8'h7f;
   4'h9: seg_r<=8'h6f;
   4'ha: seg_r<=8'h77;
   4'hb: seg_r<=8'h7c;
   4'hc: seg_r<=8'h39;
   4'hd: seg_r<=8'h5e;
   4'he: seg_r<=8'h79;
   4'hf: seg_r<=8'h71;
   default: seg_r<=8'h0;
  endcase
 reg[7:0] dig_r;
  if(~rstn) dig_r<=8'b1111_1111;
  else
  case(num_s)
   3'd0: dig_r<=8'b1111_1110;
   3'd1: dig_r<=8'b1111_1100;
   3'd2: dig_r<=8'b1111_1000;
   3'd3: dig_r<=8'b1111_0000;
   3'd4: dig_r<=8'b1110_0000;
   3'd5: dig_r<=8'b1100_0000;
   3'd6: dig_r<=8'b1000_0000;
   3'd7: dig_r<=8'b0000_0000;
   default: dig_r<=8'b1111_1111;
  endcase
 assign dig=dig_r;
 assign seg=~seg_r;
endmodule
2012-10-19 22:38:08     打赏
13楼
10.19 数码管动态显示
八段数码段显示不同数字,并且不断加1,效果:
代码:
module seg(clk,rstn,seg,dig);
 input clk,rstn;
 output[7:0] seg;
 output[7:0] dig;
 reg[25:0] count;
  if(~rstn) count<=26'd0;
  else if(count==26'd50_000_000)
    count<=26'd0;
  else count<=count+26'd1;
 reg[3:0] seg_num;
  if(~rstn) seg_num<=4'h0;
    if(seg_num==4'hf)
     seg_num<=4'h0;
    else seg_num<=seg_num+4'h1;
 reg[2:0] dig_num;
  if(~rstn) dig_num<=3'd0;
  else if(count%17'd100_000 == 1'd0)
    if(dig_num==3'd7)
     dig_num<=3'd0;
    else dig_num<=dig_num+3'd1;
 reg[7:0] dig_f;
 always @(dig_num)
  case(dig_num)
   3'd0: dig_f<=8'b1111_1110;
   3'd1: dig_f<=8'b1111_1101;
   3'd2: dig_f<=8'b1111_1011;
   3'd3: dig_f<=8'b1111_0111;
   3'd4: dig_f<=8'b1110_1111;
   3'd5: dig_f<=8'b1101_1111;
   3'd6: dig_f<=8'b1011_1111;
   3'd7: dig_f<=8'b0111_1111;
   default: dig_f<=8'b1111_1111;
  endcase
 reg[3:0] seg_num1;
 always @(dig_num)
  case(dig_num)
   3'd0: seg_num1<=seg_num;
   3'd1: seg_num1<=seg_num+4'h1;
   3'd2: seg_num1<=seg_num+4'h2;
   3'd3: seg_num1<=seg_num+4'h3;
   3'd4: seg_num1<=seg_num+4'h4;
   3'd5: seg_num1<=seg_num+4'h5;
   3'd6: seg_num1<=seg_num+4'h6;
   3'd7: seg_num1<=seg_num+4'h7;
   default: seg_num1<=seg_num;
  endcase
 reg[7:0] seg_f;
 always @(seg_num1)
  case(seg_num1)
   4'h0: seg_f<=8'h3f;
   4'h1: seg_f<=8'h06;
   4'h2: seg_f<=8'h5b;
   4'h3: seg_f<=8'h4f;
   4'h4: seg_f<=8'h66;
   4'h5: seg_f<=8'h6d;
   4'h6: seg_f<=8'h7d;
   4'h7: seg_f<=8'h07;
   4'h8: seg_f<=8'h7f;
   4'h9: seg_f<=8'h6f;
   4'ha: seg_f<=8'h77;
   4'hb: seg_f<=8'h7c;
   4'hc: seg_f<=8'h39;
   4'hd: seg_f<=8'h5e;
   4'he: seg_f<=8'h79;
   4'hf: seg_f<=8'h71;
   default: seg_f<=8'h0;
  endcase
 assign seg=~seg_f;
 assign dig=dig_f;
endmodule
共13条 2/2 ‹ 1 2 跳转至页
