时钟滴答代码
  * @file    EXTI/EXTI_Config/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
    © COPYRIGHT 2011 STMicroelectronics
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
#include "delay.h"
#include
volatile int flag;
#define Set_B20()    GPIO_SetBits(GPIOC, GPIO_Pin_12)      //????PC12
#define Reset_B20()  GPIO_ResetBits(GPIOC, GPIO_Pin_12)  //????PC12
#define Read_B20()   GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12)  //?PC12??
unsigned char Error_Flag=0;
unsigned char zf=0;
void SysTick_Configuration(void)
  /* Setup SysTick Timer for 10 msec interrupts  */
  if (SysTick_Config(48000))                //SysTick??
    /* Capture error */
    while (1);
 /* Configure the SysTick handler priority */
  NVIC_SetPriority(SysTick_IRQn, 0x0);                       //SysTick?????
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup EXTI_Config
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
GPIO_InitTypeDef   GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
void RCC_Configuration(void)
  RCC_DeInit();                 //???RCC???????
  RCC_HSICmd(ENABLE);            //????????
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);      //?SHI?????????
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);      //??????,??SHI???????
  RCC_HSEConfig(RCC_HSE_OFF);     //????????,HSE??OFF
  RCC_LSEConfig(RCC_LSE_OFF);      //????????,LSE??OFF
    //******??PLL?????48MHZ*******//
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_8);    //RCC_PLLMul_x ???PLL????? 6*x MHz
  RCC_PLLCmd(ENABLE);             ////*******************??PLL
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);        //PLL??
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);                     //  ADC??=PCLK/2
  RCC_PCLK2Config(RCC_HCLK_Div1);                       //  APB2??=HCLK
  RCC_PCLK1Config(RCC_HCLK_Div2);            /// APB1??=HCLK/2
  RCC_HCLKConfig(RCC_SYSCLK_Div1);         //  AHB??=????
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);       // ??PLL?????
  while(RCC_GetSYSCLKSource() != 0x08);        //?PLL??????
//  SystemInit();
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //??APB2????/****GPIOD???????IO??***/
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG    SW_DP??
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;         // //????GPIO??
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;  ////??????
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;     ////????????,??????
  GPIO_Init(GPIOD, &GPIO_InitStructure);    //???GPIOD
    GPIO_ResetBits(GPIOD,GPIO_Pin_2);     //???????
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//LED
  GPIO_Init(GPIOC, &GPIO_InitStructure);
    GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
      RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); //??TIM2??
void USART_int(long BaudRate)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//??GPIOA?USART1????
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* PA10 USART1_Rx  */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = BaudRate;//??USART?????  BaudRate = 9600 ?????9600
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//??????????????8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//???????????
  USART_InitStructure.USART_Parity = USART_Parity_No;//??????
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//???????
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//???????
    USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;    //???????
    USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;      //???????????
    USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;     //?????????????
    USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;//?????????????SCLK??
    USART_ClockInit(USART1, &USART_ClockInitStructure);
  USART_Init(USART1, &USART_InitStructure);//USART1???
  USART_Cmd(USART1, ENABLE);//??USART1????
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//??????
void delay_18b20(u32 nus)    //18b20?????????,??????
    u16 i;
    while(nus--)
        for(i=12;i>0;i--);
void Init18B20(void)  //18B20???
   u8 aa=0;
   u8 count =0;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//??PC??
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;//????
   Set_B20() ;   // GPIO_SetBits(GPIOC, GPIO_Pin_12)
   delay_18b20(1);
   Reset_B20();
   delay_18b20(480);
   Set_B20();
//  delay_18b20(500);
   delay_18b20(480);
    count=0;
    aa=Read_B20();         //????
    /****???????????99?,??????*/
    while(!aa && count<100)
    aa=Read_B20();
    count++;          //????for()?while??
   if(count>=99)
        Error_Flag=1;
    else
        Error_Flag=0;
unsigned char Read18B20(void)//??????
unsigned char i=0;
unsigned char date=0;
u8 tempp;
   for(i=8;i>0;i--)
   Reset_B20();   //??PC12
   date>>=1;    //??????
   delay_18b20(1);
   Set_B20();    //??
    delay_18b20(1);
   tempp=Read_B20();   //????
   if(tempp)
        date|=0x80;     // 1000 0000   ?????1 ,????,??????0?1,?8??????? 0xff = 1111 1111
    delay_18b20(60);
    return(date);
void Write18B20(unsigned char date)//???
    unsigned char i=0;
    for (i=8; i>0; i--)
        Reset_B20();
        delay_18b20(1);
        if(date & 0x01)
            Set_B20();
        else
        {   Reset_B20();}
        delay_18b20(60);
        date>>=1;
         Set_B20();
         delay_18b20(1);
    delay_18b20(15);
 float Read_T()//???
        unsigned char TUp,TDown;
    unsigned char fTemp;
    u8 TT=0;
     float Temp = 0;
    Init18B20();
    Write18B20(0xcc);
    Write18B20(0x44);
    Init18B20();
    Write18B20(0xcc);
    Write18B20(0xbe);
    TDown = Read18B20();
    TUp = Read18B20();
    if(TUp>0x7f)
        TDown=~TDown;
        TUp=~TUp+1;
        TUp/=8;
        zf=1;
    else
        zf=0;
    fTemp=TDown&0x0f;
    TUp<<=4;
    TDown>>=4;
    TT=TUp|TDown;
    Temp=TT+(float)fTemp/16;
    return(Temp);
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System Clocks Configuration */
    char ID[8];
    int i;
  RCC_Configuration();
  USART_int(115200);
    SysTick_Configuration();
    printf(" config done...\r\n");
  delay_ms(1000);
    Init18B20();     //???
    Write18B20(0x33);  //?????????
    delay_18b20(20);
    for(i=0;i<8;i++)   //?????for?? ????printf("event 1 oc......\r\n")??,??????
        ID[i] = Read18B20();//????
    while(1)
        if(flag == 300)
            printf("At the moment of ID is:")   ;
            for(i=0;i<8;i++)     //????????,?????
          printf("%u",ID[i]);//????
            printf("\r\n")  ;
        if(flag == 500)
            printf("The Temperature is:%f\r\n",Read_T());//???????
            printf("===================================================\r\n");
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
  * @brief  Retargets the C library printf function to the USART.
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
 我要赚赏金 STM32
STM32 MCU
MCU 通讯及无线技术
通讯及无线技术 物联网技术
物联网技术 电子DIY
电子DIY 板卡试用
板卡试用 基础知识
基础知识 软件与操作系统
软件与操作系统 我爱生活
我爱生活 小e食堂
小e食堂
