![](http://forum.eepw.com.cn/pub/kindeditor/plugins/emoticons/images/21.gif)
系统滴答&18B20
系统时钟配置为48MHZ,由滴答控制,300ms输出一次18B20的ID,500ms输出一次温度。
#include "stm32f10x.h"
#include "stm32_eval.h"
#include <stdio.h>
#define Set_B20() GPIO_SetBits(GPIOC, GPIO_Pin_12)
#define Reset_B20() GPIO_ResetBits(GPIOC, GPIO_Pin_12)
#define Read_B20() GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_12)
volatile int flag;
unsigned char Error_Flag=0;
unsigned char zf=0;
unsigned char ID[8];
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
void delay_ms(u32 n)
while(n--)
delay_us(1000);
void SysTick_Configuration(void)
/* Setup SysTick Timer for 1 msec interrupts */
if (SysTick_Config(48000)) //SysTick配置 48000/48MHZ=1ms 滴答一次
/* Capture error */
while (1);
/* Configure the SysTick handler priority */
NVIC_SetPriority(SysTick_IRQn, 0x0); //SysTick中断优先级
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
#define RCC_PLLSource_HSE_Div1 ((uint32_t)0x00010000)
void RCC_Configuration(void)
RCC_DeInit();
RCC_HSICmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
RCC_HSEConfig(RCC_HSE_OFF);
RCC_LSEConfig(RCC_LSE_OFF);
RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_6); // 6*8Mhz= 48MHz
RCC_PLLCmd(ENABLE);
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
RCC_ADCCLKConfig(RCC_PCLK2_Div4);
RCC_PCLK2Config(RCC_HCLK_Div1);
RCC_PCLK1Config(RCC_HCLK_Div2);
RCC_HCLKConfig(RCC_SYSCLK_Div1);
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
while(RCC_GetSYSCLKSource() != 0x08)
// SystemInit();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void USART_int(long BaudRate)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* PA10 USART1_Rx */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
/* USARTx configured as follow:
- BaudRate = 115200 baud
- Word Length = 8 Bits
- One Stop Bit
- No parity
- Hardware flow control disabled (RTS and CTS signals)
- Receive and transmit enabled
USART_InitStructure.USART_BaudRate = BaudRate;//??????
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
USART_InitStructure.USART_Parity = USART_Parity_No;//????
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
USART_ClockInit(USART1, &USART_ClockInitStructure);
USART_Init(USART1, &USART_InitStructure);
USART_Cmd(USART1, ENABLE);
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
void delay_18b20(u32 nus)
u16 i;
while(nus--)
for(i=12;i>0;i--);
void Init18B20(void)//18B20初始化
u8 b=0;
u8 count =0;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //GPIOC的复用时钟使能
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;//选择PC12
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;//开漏输出
GPIO_Init(GPIOC, &GPIO_InitStructure);//GPIOC初始化
Set_B20() ;
/*复位时需要至少480us的低电平*/
delay_18b20(1);
Reset_B20();
delay_18b20(480);
/* 探测到上升沿后等待15~60us后18B20发出存在脉冲 */
Set_B20();
delay_18b20(480);
count=0;
b=Read_B20();//读取18B20的一个字节 赋值给aa
/* 校验读取值,错误次数大于99才报错 */
while(!b && count<100)
b=Read_B20();
count++;
if(count>=99)
Error_Flag=1;
else
Error_Flag=0;
unsigned char Read18B20(void)//读取18B20的一个字节
unsigned char i=0;
unsigned char date=0;
u8 tempp;
for(i=8;i>0;i--)//按位读取,读取一个字需要循环8次
Reset_B20();//拉低电平
date>>=1;//date右移一位
delay_18b20(1);
Set_B20(); //置高电平
delay_18b20(1);
tempp=Read_B20();//读取温度值
if(tempp)//若读取到的值非0
{date|=0x80;} //将date的最高位置1
delay_18b20(60);
return(date);
void Write18B20(unsigned char date)//写入
unsigned char i=0;
for (i=8; i>0; i--)
Reset_B20(); //置低电平
delay_18b20(1);
if(date & 0x01) //如果date最低位为1
Set_B20();//置高电平
else//如果date最低位为0
Reset_B20();}//置低电平
delay_18b20(60);
date>>=1; //date右移一位
Set_B20();//置高电平
delay_18b20(1);
delay_18b20(15);
float Read_T()//读取温度值
unsigned char TUp,TDown;
unsigned char fTemp;
u8 TT=0;
float Temp = 0;
Init18B20();//1820初始化
Write18B20(0xcc); //不提供64位ROM编码使用存储器
Write18B20(0x44); //启动一次温度转换
Write18B20(0xbe); //从字节0开始读取暂存器内容
/*两次读取温度*/
TDown = Read18B20();
TUp = Read18B20();
if(TUp>0x7f) // 如果TUp的值大于最大值(11111111)bin
TDown=~TDown; //TDown取反
TUp=~TUp+1; //TUp取反加一
TUp/=8; //TUp除以8
zf=1; //zf标志位置1
else
zf=0;
fTemp=TDown&0x0f;//TDown保留后四位,赋值给fTemp
TUp<<=4;//TUp左移四位,舍去高四位
TDown>>=4;//TDown右移四位,舍去低四位
TT=TUp|TDown;//TUp与TDown合并 赋值给TT
Temp=TT+(float)fTemp/16;
return(Temp);
int main(void)
int i;
RCC_Configuration();
USART_int(115200);
Init18B20();//初始化18B20
SysTick_Configuration();//系统滴答时钟配置
printf(" config done...\r\n");
Write18B20(0x33);//此命令获取18B20的ID
for(i=0;i<8;i++)//用一个8位的数组保存id值
ID[i]=Read18B20();
delay_ms(1000);
while(1)
void SysTick_Handler(void)
int i;
flag++;
if(flag==300)//每300ms输出一次id
printf("\r\nevent 1 oc......\r\n");
printf("The id is :\r\n");
for(i=0;i<8;i++)
printf("%x",ID[i]);
else if(flag==500)//每500ms输出一次温度
printf("\r\nevent 2 oc......\r\n");
printf("The Temperature is:%f\r\n",Read_T());
flag = 0;
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
* @brief Retargets the C library printf function to the USART.
* @param None
* @retval None
PUTCHAR_PROTOTYPE
/* Place your implementation of fputc here */
/* e.g. write a character to the USART */
USART_SendData(EVAL_COM1, (uint8_t) ch);
/* Loop until the end of transmission */
while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
return ch;
* @retval None
/* Infinite loop */
while (1)
#endif
SPI从ADC中获取数值的代码作业
串口调试助手截图
/* Includes ------------------------------------------------------------------*/ #include "stm32f10x.h" #include "stm32_eval.h" #include #include "spi_flash.h" #define VREF 3.3 #define TxBufferSize1 (countof(TxBuffer1) - 1) #define RxBufferSize1 (countof(TxBuffer1) - 1) #define countof(a) (sizeof(a) / sizeof(*(a))) #define BufferSize (countof(Tx_Buffer)-1) typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus; #define FLASH_WriteAddress 0x00000 #define FLASH_ReadAddress FLASH_WriteAddress #define FLASH_SectorToErase FLASH_WriteAddress #define sFLASH_ID 0xEF3015 //W25X16 //#define sFLASH_ID 0xEF4015 //W25Q16 #define buff_size 16; char rx_buff[],rx_buff_count=0; uint8_t Tx_Buffer[4096] ; uint8_t Rx_Buffer[BufferSize]; __IO uint32_t DeviceID = 0; __IO uint32_t FlashID = 0; __IO TestStatus TransferStatus1 = FAILED; void delay_us(u32 n) { u8 j; while(n--) for(j=0;j<10;j++); } void delay_ms(u32 n) { while(n--) delay_us(1000); } void Delay(__IO uint32_t nCount); TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength); /** @addtogroup STM32F10x_StdPeriph_Examples * @{ */ /** @addtogroup EXTI_Config * @{ */ /* Private typedef -----------------------------------------------------------*/ /* Private define ------------------------------------------------------------*/ /* Private macro -------------------------------------------------------------*/ /* Private variables ---------------------------------------------------------*/ GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; USART_ClockInitTypeDef USART_ClockInitStructure; char *int_to_string(int number,char *strnum)//整形数据转换为字符型 { int j=0,i=0,n=0; char temp; while(number>0) { *(strnum+j)=number%10+48; j++; number=number/10; n++; } for(i=0;iLibraries->Small printf set to 'Yes') calls __io_putchar() */ #define PUTCHAR_PROTOTYPE int __io_putchar(int ch) #else #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f) #endif /* __GNUC__ */ /** * @brief Retargets the C library printf function to the USART. * @param None * @retval None */ PUTCHAR_PROTOTYPE { /* Place your implementation of fputc here */ /* e.g. write a character to the USART */ USART_SendData(EVAL_COM1, (uint8_t) ch); /* Loop until the end of transmission */ while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET) {} return ch; } #ifdef USE_FULL_ASSERT /** * @brief Reports the name of the source file and the source line number * where the assert_param error has occurred. * @param file: pointer to the source file name * @param line: assert_param error line source number * @retval None */ void assert_failed(uint8_t* file, uint32_t line) { /* User can add his own implementation to report the file name and line number, ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */ /* Infinite loop */ while (1) { } } #endif
关于焊电路板总结帖
焊接板只要做好以下几点其实是很容易的。
1.做好焊接部件的先后顺序,小的部件先焊,大的后面焊接。就是把握好焊接顺序就好了。
2.还有就是掌握好焊接的小技巧,利用一些小的技巧就可以了。
下面说说焊接要准备的一些工具如图:
接下来就是焊接了。经过焊接课程其实大多数的焊接技巧都掌握好了。这里我就不多说了。
说说大多数同学遇到的问题。也是难题那就是焊接芯片了。因为我们的芯片管脚很细,因此加大了焊接的难度。其实焊好后。
掌握方法也是不难的。下面我说说焊接的方法与技巧。
1.首先焊的核心板芯片,把管脚对齐,用透明胶布固定(检查管脚是否对其有个技巧,就是把板放到台灯下可以更好地观察到);
2.在芯片管脚上再涂上焊宝(我推荐大家最好使用焊宝,因为焊宝币松香更好用一点),这样就可以固定好芯片方便焊接了;
3.就是焊接了,焊这颗芯片千万不要加焊锡,并且要处理干净电烙铁,不然会不小心把芯片管脚焊短路了。焊接等烙铁达到温度后,
就慢慢加热芯片管脚就好了,这样芯片就焊好了!
涂焊宝
焊好芯片其他的贴片就很简单啦
可以先在焊盘上加一点焊锡,要有足够的焊锡才能把这些小贴片焊稳了
下面介绍一种针对芯片管脚被焊锡粘住后的解决方案
这是非常麻烦的一件事,很多同学不知道怎么处理,很难弄干净芯片的管脚。
用对方法其实就简单很多啦,方法就是使用焊宝或松香清洗就好了。
把被焊锡粘住的芯片放到焊宝或松香盒里。使用电烙铁加热。这样焊锡就好沉入焊宝盒的底部跟芯片管脚分开啦。
如图
下面是我的焊好的板的效果展示:
使用时候的线的连接
焊板的过程遇到挺多问题的,不过也学到了很多的东西,提高了自己的动手能力,对板也有了更多的了解。
总的来说焊电路板其实也是很有趣的
5月直播——【探索边缘智能的未来——直播盛宴即将开启!】 | |
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 |
