波特率74880
ets Jan 8 2013,rst cause:2, boot mode:(1,6) ets Jan 8 2013,rst cause:2, boot mode:(3,6) load 0x40100000, len 1396, room 16 tail 4 chksum 0x89 load 0x3ffe8000, len 776, room 4 tail 4 chksum 0xe8 load 0x3ffe8308, len 540, room 4 tail 8 chksum 0xc0 csum 0xc0 2nd boot version : 1.4(b1) SPI Speed : 40MHz SPI Mode : QIO SPI Flash Size & Map: 16Mbit(512KB+512KB) jump to run user1 @ 1000 R )D蠦芇P尃C ?阷p_task_hdl : 3ffef6f8, prio:13, stack:512 pm_task_hdl : 3ffeffd8, prio:1, stack:176 ApiMsgMutex created tcpip_task_hdl : 3fff03f0, prio:10,stack:512 wdt_task : 3fff0cb0, prio:14, stack:176 idle_task_hdl : 3fff1820 tim_task_hdl : 3fff1c18 xPortStartScheduler frc2_timer_task_hdl:3fff2528, prio:12, stack:512 OS SDK ver: 1.2.0(b900bd2) compiled @ Aug 28 2015 17:18:41 phy ver: 356, pp ver: 9.0 SDK version:1.2.0(b900bd2) mode : softAP(5e:cf:7f:81:c8:72) dhcp server start:(ip:192.168.4.1,mask:255.255.255.0,gw:192.168.4.1) add if1 bcn 100 hello world,I am MikuQ.com hello world,I am MikuQ.com
serialPort1.BaudRate = 74880; serialPort1.PortName = "COM51"; serialPort1.Open(); private void serialPort1_DataReceived(object sender, System.IO.Ports.SerialDataReceivedEventArgs e) { byte[] buf=new byte[1024]; if (e.EventType == SerialData.Chars) { int r=serialPort1.Read(buf, 0, 1024); output(Encoding.Default.GetString(buf, 0, r)); } }
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! |
打赏帖 | |
【换取手持数字示波器】+AT89C2051串口接收数据显示到LCD1602上被打赏50分 | |
【分享评测,赢取加热台】+AT89C2051控制NRF24L01收发数据被打赏50分 | |
【分享评测,赢取加热台】迪文屏设计实战技巧被打赏40分 | |
“DFRobot盖革计数器模块评测”基础模型搭建被打赏50分 | |
【换取手持数字示波器】+角点检测----Harris被打赏40分 | |
【换取手持数字示波器】常见音频指标被打赏20分 | |
【分享评测,赢取加热台】从零配置MCX-N947——PWM(SCtimer)被打赏50分 | |
【分享评测,赢取加热台】实际测试MCX-N947——PWM(Ctimer)被打赏50分 | |
【换取手持数字示波器】红外触摸框及各类红外设备的工作原理被打赏20分 | |
【换取手持数字示波器】+精英板驱动两相四线步进电机被打赏10分 |
