library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity XiYiJi is
port(
clk_50M :in std_logic;
k_select :in std_logic;
k_run_stop :in std_logic;
led_state :out std_logic_vector(3 downto 0);---zhishi 11 ge zhuang tai
hex0 :out std_logic_vector(7 downto 0);
hex1 :out std_logic_vector(7 downto 0);
hex2 :out std_logic_vector(7 downto 0);
hex3 :out std_logic_vector(7 downto 0);
ctrl_danxi :out std_logic;
ctrl_danpiao:out std_logic;
ctrl_dantuo :out std_logic);
end XiYiJi;
architecture state_machine1 of XiYiJi is
type state_type is (s_wt_idle,s_wt_dx,s_wt_dp,s_wt_dt,s_wt_pt,s_wt_xpt,s_dx,s_dp,s_dt,s_pt,s_xpt);
signal present_state,next_state:state_type;
signal a1,a2,a3:integer range 0 to 9;
signal a4:integer range 0 to 9;
signal clk_10ms:std_logic;
signal clk_10ms_v:std_logic_vector(1 downto 0);
signal time_up : std_logic;
signal k1_v,k2_v:std_logic_vector( 5 downto 0 );
signal from_idle:std_logic;
signal state_unfinish:std_logic;
begin
caiyang:process(clk_50M,k_select,k_run_stop)
begin
if rising_edge(clk_10ms) then
k1_v(5)<=k1_v(4); --用于消抖
k1_v(4)<=k1_v(3);
k1_v(3)<=k1_v(2);
k1_v(2)<=k1_v(1);
k1_v(1)<=k1_v(0);
k1_v(0)<=k_select;
k2_v(5)<=k2_v(4);
k2_v(4)<=k2_v(3);
k2_v(3)<=k2_v(2);
k2_v(2)<=k2_v(1);
k2_v(1)<=k2_v(0);
k2_v(0)<=k_run_stop;
end if ;
end process;
state_transfer:process(clk_10ms,present_state,next_state,k1_v,k2_v)
begin
if rising_edge(clk_10ms)then
if present_state=s_wt_idle then
from_idle<='1';----zan ting hou ji shi xian shi panduan
if k1_v ="00011"then
next_state<=s_wt_dx;
end if ;
elsif present_state=s_wt_dx then
if k1_v="00011"then
next_state<=s_wt_dp;
end if;
if k2_v="00011"then
next_state<=s_dx;
end if ;
elsif present_state=s_wt_dp then
if k1_v="00011"then
next_state<=s_wt_dt;
elsif k2_v="00011"then
next_state<=s_dp;
end if ;
elsif present_state =s_wt_dt then
if k1_v="00011"then
next_state<=s_wt_pt;
next_state<=s_dt;
end if ;
elsif present_state=s_wt_pt then
if k1_v="00011"then
next_state<=s_wt_xpt;
next_state<=s_pt;
end if ;
elsif present_state=s_wt_xpt then
if k1_v="00011"then
next_state<=s_wt_idle;
next_state<=s_xpt;
end if ;
elsif present_state=s_dx then
from_idle<='0';
if time_up='1'then
state_unfinish <='0';
end if;
if k2_v="00011" then
state_unfinish <='1';
end if ;
elsif present_state=s_dp then
from_idle<='0';
if time_up='1'then
end if;
if k2_v="00011"then
end if ;
elsif present_state=s_dt then
from_idle<='0';
if time_up='1'then
end if;
if k2_v="00011"then
end if ;
elsif present_state=s_pt then
from_idle<='0';
if time_up='1'then
end if;
if k2_v="00011"then
end if ;
elsif present_state=s_xpt then
from_idle<='0';
if time_up='1'then
end if;
if k2_v="00011"then
end if ;
end if;
end if;
end process;
fenpin_1ms:process(clk_50M)
variable clk_div:integer range 0 to 25;--0000;
begin
if rising_edge(clk_50M)then
clk_div:=clk_div+1;
if clk_div=25 then--0000
clk_10ms<=not clk_10ms;
clk_div:=0;
end if;
end if;
end process;
caiyang1:process(clk_50M,clk_10ms)-----caiyang yongyi xiaochu shijian yanchi
begin
if rising_edge(clk_50M) then
clk_10ms_v(1)<=clk_10ms_v(0);
clk_10ms_v(0)<=clk_10ms;
end if;
end process;
state_register:process(clk_50M)
begin
present_state<=next_state;
end if;
end process;
zhuangtaichuli:process(clk_50M,clk_10ms_v,present_state,time_up)
begin
case present_state is
when s_wt_idle =>
a4<=8;a3<=8;a2<=8;a1<=8;
led_state <="1111";
ctrl_danxi<='0';---lv deng yun xing zhishi
ctrl_danpiao<='0';
ctrl_dantuo<='0';
when s_wt_dx =>
-- if state_unfinish='1'then
if from_idle='1'or time_up='1'then
a4<=2;a3<=0;a2<=0;a1<=0;
end if ;
led_state <="0001";
ctrl_danxi<='0';
ctrl_danpiao<='0';
ctrl_dantuo<='0';
when s_wt_dp =>
a4<=1;a3<=5;a2<=0;a1<=0;
end if;
led_state <="0010";
ctrl_danxi<='0';
ctrl_danpiao<='0';
ctrl_dantuo<='0';
when s_wt_dt =>
a4<=1;a3<=0;a2<=0;a1<=0;
end if ;
led_state <="0011";
ctrl_danxi<='0';
ctrl_danpiao<='0';
ctrl_dantuo<='0';
when s_wt_pt =>
a4<=3;a3<=5;a2<=0;a1<=0;
end if;
led_state <="0100";
ctrl_danxi<='0';
ctrl_danpiao<='0';
ctrl_dantuo<='0';
when s_wt_xpt =>
a4<=4;a3<=5;a2<=0;a1<=0;
end if ;
led_state <="0101";
ctrl_danxi<='0';
ctrl_danpiao<='0';
ctrl_dantuo<='0';
when s_dx =>
led_state <="0110";
ctrl_danxi<='1';
ctrl_danpiao<='0';
ctrl_dantuo<='0';
if clk_10ms_v="01" then----------weihe jiu neng xiaochushijianyanchi
-- if rising_edge(clk_10ms)then
a1<=a1-1;
if a1=0 then
a2<=a2-1;a1<=9;
if a2=0 then
a3<=a3-1;a2<=9;
if a3=0 then
a4<=a4-1;a3<=9;
if a4=0 and a3=0 and a2=0 and a1=0 then
time_up<='1';
a4<=0;a3<=0;a2<=0;a1<=0;
else time_up<='0';
end if;
end if;
end if;
end if;
end if;
when s_dp =>
led_state <="0111";
ctrl_danxi<='0';
ctrl_danpiao<='1';
ctrl_dantuo<='0';
a1<=a1-1;
if a1=0 then
a2<=a2-1;a1<=9;
if a2=0 then
a3<=a3-1;a2<=9;
if a3=0 then
a4<=a4-1;a3<=9;
time_up<='1';
else time_up<='0';
end if;
end if;
end if;
end if;
end if;
when s_dt =>
led_state <="1000";
ctrl_danxi<='0';
ctrl_danpiao<='0';
ctrl_dantuo<='1';
a1<=a1-1;
if a1=0 then
a2<=a2-1;a1<=9;
if a2=0 then
a3<=a3-1;a2<=9;
if a3=0 then
a4<=a4-1;a3<=9;
time_up<='1';
else time_up<='0';
end if;
end if;
end if;
end if;
end if;
when s_pt =>
led_state <="1001";
ctrl_danxi<='0';
ctrl_danpiao<='1';
ctrl_dantuo<='1';
a1<=a1-1;
if a1=0 then
a2<=a2-1;a1<=9;
if a2=0 then
a3<=a3-1;a2<=9;
if a3=0 then
a4<=a4-1;a3<=9;
time_up<='1';
else time_up<='0';
end if;
end if;
end if;
end if;
end if;
when s_xpt =>
led_state <="1010";
ctrl_danxi<='1';
ctrl_danpiao<='1';
ctrl_dantuo<='1';
a1<=a1-1;
if a1=0 then
a2<=a2-1;a1<=9;
if a2=0 then
a3<=a3-1;a2<=9;
if a3=0 then
a4<=a4-1;a3<=9;
time_up<='1';
else time_up<='0';
end if;
end if;
end if;
end if;
end if;
when others =>
led_state <="1111";
ctrl_danxi<='0';
ctrl_danpiao<='0';
ctrl_dantuo<='0';
end case;
end if;
end process;
a1yimaxianshi:process(clk_50M,a1)
begin
case a1 is
when 0=>
hex0<="11000000";
when 1=>
hex0<="11111001";
when 2=>
hex0<="10100100";
when 3=>
hex0<="10110000";
when 4=>
hex0<="10011001";
when 5=>
hex0<="10010010";
when 6=>
hex0<="10000010";
when 7=>
hex0<="11111000";
when 8=>
hex0<="10000000";
when others=>
hex0<="10010000";
end case;
end if;
end process;
a2yimaxianshi:process(clk_50M,a2)
begin
case a2 is
when 0=>
hex1<="11000000";
when 1=>
hex1<="11111001";
when 2=>
hex1<="10100100";
when 3=>
hex1<="10110000";
when 4=>
hex1<="10011001";
when 5=>
hex1<="10010010";
when 6=>
hex1<="10000010";
when 7=>
hex1<="11111000";
when 8=>
hex1<="10000000";
when others=>
hex1<="10010000";
end case;
end if;
end process;
a3yimaxianshi:process(clk_50M,a3)
begin
case a3 is
when 0=>
hex2<="11000000";
when 1=>
hex2<="11111001";
when 2=>
hex2<="10100100";
when 3=>
hex2<="10110000";
when 4=>
hex2<="10011001";
when 5=>
hex2<="10010010";
when 6=>
hex2<="10000010";
when 7=>
hex2<="11111000";
when 8=>
hex2<="10000000";
when others=>
hex2<="10010000";
end case;
end if;
end process;
a4yimaxianshi:process(clk_50M,a4)
begin
case a4 is
when 0=>
hex3<="11000000";
when 1=>
hex3<="11111001";
when 2=>
hex3<="10100100";
when 3=>
hex3<="10110000";
when 4=>
hex3<="10011001";
when 5=>
hex3<="10010010";
when 6=>
hex3<="10000010";
when 7=>
hex3<="11111000";
when 8=>
hex3<="10000000";
when others=>
hex3<="10010000";
end case;
end if;
end process;
end state_machine1;
