电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 江湖救急! 链接时报错!
共4条 1/1 1 跳转至页
江湖救急! 链接时报错!
2003-12-01 22:59:55     打赏
[color=#DC143C]ldarm -o tmp.o[/color] -X -EL -r dataSegPad.o sysALib.o sysLib.o E:\pppoe_np\target/lib/ libARMARCH4gnutms.a sysConfig.o sysSwitch.o hpcFsFunc.o hpcFsRpc.o hpcFsDrv.o po rtTable.o dnlValidate.o NetPortLoopBack.o NPCSys.o testp.o FlashIO.o flashFsLib. o sysTffs.o wamdmtd.o Fscmd.o usrConfig_st.o version.o E:\pppoe_np\target/../host/x86-win32/lib/gcc-lib/ar m-wrs-vxworks/2.7.9-970819/libgcc.a E:\pppoe_np\target/lib/libARMARCH4gnutms.a E:\pppoe_np\target/lib/libARMARCH4gnuenvoy.a E:\pppoe_np\target/lib/libARMARCH4g nuddp.a E:\pppoe_np\target/lib/libARMARCH4gnuzlib.a E:\pppoe_np\target/lib/libAR MARCH4gnuPPP.a E:\pppoe_np\target/lib/libARMARCH4gnucli.a E:\pppoe_np\target/lib /libARMARCH4gnupppradius.a E:\pppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp_DRV .a E:\pppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/rtm.a E :\pppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/app_1200.a E:\pppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/hal_1200.a E:\pppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/uclo.a E: \pppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/debug_1200.a E:\pppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/ucommDriv er.a E:\pppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/GigMa c.a E:\pppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/msgQ.a E:\pppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/sv_libs.a E:\pppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/ueng.a E: \pppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/core_utils.a E:\pppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/libd.a E: \pppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/utils.a E:\p ppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/osApi.a E:\ppp oe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/rs_udebug.a E:\p ppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/scomm.a E:\ppp oe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/app_1200.a E:\pp poe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/debug_1200.a E: \pppoe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/hdbm.a E:\pp poe_np\target/src/tms/swdrv/ixp1200eb_le/ixp1200_lib/vxworks_lib/ixp_hash.a E:pppoe_np\target/lib/libARMARCH4gnutms.a E:\pppoe_np\target/lib/libARMARCH4gnuvx .a E:\pppoe_np\target/../host/x86-win32/lib/gcc-lib/arm-wrs-vxworks/2.7.9-970819 /libgcc.a [color=#DC143C]ldarm: tmp.o: .text: reloc overflow: 0x10060 > 0xffff[/color] [color=#DC143C]tmp.o: final close failed: File truncated[/color] make: *** [vxWorks.st] Error 0x1 请问高人们如何解决?? [align=right][color=#000066][此贴子已经被作者于2003-12-1 15:06:06编辑过][/color][/align]
关键词: 江湖     救急     链接     报错     pppoe     target
2003-12-01 23:02:00     打赏
RAM_HIGH_ADRS和RAM_LOW_ADRS之间的空间太小了,修改BSP,然后重做bootrom和vxworks。
2003-12-01 23:05:00     打赏
试过了,没有用。还可能是什么情况呢?
2003-12-02 03:58:00     打赏
问题解决了,修改rules.bsp $(LD) -o tmp.o $(LD_PARTIAL_FLAGS) dataSegPad.o $(MACH_DEP) usrConfig_st.o version.o $(LIBS) 修改为 $(LD) -o tmp.o $(LD_PARTIAL_FLAGS) --split-by-reloc 2 dataSegPad.o $(MACH_DEP) usrConfig_st.o version.o $(LIBS) --split-by-reloc count Trys to creates extra sections in the output file so that no single output section in the file contains more than count relocations. This is useful when generating huge relocatable for downloading into certain real time kernels with the COFF object file format; since COFF cannot represent more than 65535 relocations in a single section. Note that this will fail to work with object file formats which do not support arbitrary sections. The linker will not split up individual input sections for redistribution, so if a single input section contains more than count relocations one output section will contain that many relocations.
共4条 1/1 1 跳转至页
