收到开发板,一直没有时间开发,只是详细阅读了开发板资料,感受到了此款单片机丰富的资源。明天我得抽时间跑跑我的ADC采集程序,看它做RMS运算的时间要多长。
				连接上了,做了个流水灯测试了IO口,同时用定时器做了1MS的中断,用来计时。其它的,像ADC实现,我会接着完成。不过我发现这个工具真是好用,用它生成的模块,只要在里面增加你自己的代码就可以,真方便,不错的开发环境。下面展示下我的实验结果及代码。
附上我的程序:
void  main(void)
 /* Start user code. Do not edit comment generated here */
  unsigned char i;
 SystemInit();
 SystemTime = 0;
 while (1U)
  for( i =0; i < 8; i ++)
   P7 =( 1 << i);
   DelayNms(500);
  //Delay(60000);
 /* End user code. Do not edit comment generated here */
void SystemInit()
  // WDT_Init();       //关闭看门狗
 CLOCK_Init();      //时钟设定
 //CG_ReadResetSource();
 PORT_Init();      //初始化P7口为输出
 TAU0_Init();      //定时器打开
 TAU0_Channel0_Start();    //启动定时器
 SAU0_Init();      //串口初始化
 UART0_Start();      //打开UART0
 //TAU0_Init();
void CLOCK_Init(void)
 /* Set fMX */
 CMC = _00_CG_HISYS_PORT | _00_CG_SUB_PORT | _00_CG_SYSOSC_DEFAULT | _00_CG_SUBMODE_DEFAULT;
 MSTOP = 1U;
 /* Set fMAIN */
 MCM0 = 0U;
 /* Set fSUB */
 XTSTOP = 1U;
 OSMC = _10_CG_RTC_CLK_FIL;
 /* Set fCLK */
 CSS = 0U;
 /* Set fIH */
 HIOSTOP = 0U;
void PORT_Init(void)
 P2 = _00_Pn0_OUTPUT_0 | _00_Pn1_OUTPUT_0 | _00_Pn2_OUTPUT_0 | _00_Pn3_OUTPUT_0 | _10_Pn4_OUTPUT_1 | _00_Pn5_OUTPUT_0 | _40_Pn6_OUTPUT_1 | _00_Pn7_OUTPUT_0;
 P5 = _00_Pn0_OUTPUT_0 | _00_Pn1_OUTPUT_0 | _00_Pn2_OUTPUT_0 | _00_Pn3_OUTPUT_0 | _00_Pn4_OUTPUT_0 | _00_Pn5_OUTPUT_0;
 P7 = _00_Pn0_OUTPUT_0 | _00_Pn1_OUTPUT_0 | _00_Pn2_OUTPUT_0 | _00_Pn3_OUTPUT_0 | _00_Pn4_OUTPUT_0 | _00_Pn5_OUTPUT_0 | _00_Pn6_OUTPUT_0 | _80_Pn7_OUTPUT_1;
 PM2 = _00_PMn0_MODE_OUTPUT | _00_PMn1_MODE_OUTPUT | _00_PMn2_MODE_OUTPUT | _00_PMn3_MODE_OUTPUT | _00_PMn4_MODE_OUTPUT | _00_PMn5_MODE_OUTPUT | _00_PMn6_MODE_OUTPUT | _00_PMn7_MODE_OUTPUT;
 PM5 = _00_PMn0_MODE_OUTPUT | _00_PMn1_MODE_OUTPUT | _00_PMn2_MODE_OUTPUT | _00_PMn3_MODE_OUTPUT | _00_PMn4_MODE_OUTPUT | _00_PMn5_MODE_OUTPUT | _C0_PM5_DEFAULT;
 PM7 = _00_PMn0_MODE_OUTPUT | _00_PMn1_MODE_OUTPUT | _00_PMn2_MODE_OUTPUT | _00_PMn3_MODE_OUTPUT | _00_PMn4_MODE_OUTPUT | _00_PMn5_MODE_OUTPUT | _00_PMn6_MODE_OUTPUT | _00_PMn7_MODE_OUTPUT;
void TAU0_Init(void)
 TAU0EN = 1U;  /* supplies input clock */
 TPS0 = _0000_TAU_CKM0_FCLK_0 | _0000_TAU_CKM1_FCLK_0 | _0000_TAU_CKM2_FCLK_1 | _0000_TAU_CKM3_FCLK_8;
 /* Stop all channels */
 TT0 = _0001_TAU_CH0_STOP_TRG_ON | _0002_TAU_CH1_STOP_TRG_ON | _0004_TAU_CH2_STOP_TRG_ON | _0008_TAU_CH3_STOP_TRG_ON | _0010_TAU_CH4_STOP_TRG_ON | _0020_TAU_CH5_STOP_TRG_ON | _0040_TAU_CH6_STOP_TRG_ON | _0080_TAU_CH7_STOP_TRG_ON | _0200_TAU_CH1_H8_STOP_TRG_ON | _0800_TAU_CH3_H8_STOP_TRG_ON;
 /* Mask channel 0 interrupt */
 TMMK00 = 1U; /* disable INTTM00 interrupt */
 TMIF00 = 0U; /* clear INTTM00 interrupt flag */
 /* Mask channel 1 interrupt */
 TMMK01 = 1U; /* disable INTTM01 interrupt */
 TMIF01 = 0U; /* clear INTTM01 interrupt flag */
 /* Mask channel 1 higher 8 bits interrupt */
 TMMK01H = 1U; /* disable INTTM01H interrupt */
 TMIF01H = 0U; /* clear INTTM01H interrupt flag */
 /* Mask channel 2 interrupt */
 TMMK02 = 1U; /* disable INTTM02 interrupt */
 TMIF02 = 0U; /* clear INTTM02 interrupt flag */
 /* Mask channel 3 interrupt */
 TMMK03 = 1U; /* disable INTTM03 interrupt */
 TMIF03 = 0U; /* clear INTTM03 interrupt flag */
 /* Mask channel 3 higher 8 bits interrupt */
 TMMK03H = 1U; /* disable INTTM03H interrupt */
 TMIF03H = 0U; /* clear INTTM03H interrupt flag */
 /* Mask channel 4 interrupt */
 TMMK04 = 1U; /* disable INTTM04 interrupt */
 TMIF04 = 0U; /* clear INTTM04 interrupt flag */
 /* Mask channel 5 interrupt */
 TMMK05 = 1U; /* disable INTTM05 interrupt */
 TMIF05 = 0U; /* clear INTTM05 interrupt flag */
 /* Mask channel 6 interrupt */
 TMMK06 = 1U; /* disable INTTM06 interrupt */
 TMIF06 = 0U; /* clear INTTM06 interrupt flag */
 /* Mask channel 7 interrupt */
 TMMK07 = 1U; /* disable INTTM07 interrupt */
 TMIF07 = 0U; /* clear INTTM07 interrupt flag */
 /* Set INTTM00 high priority */
 TMPR100 = 0U;
 TMPR000 = 0U;
 /* Channel 0 used as interval timer */
 TMR00 = _0000_TAU_CLOCK_SELECT_CKM0 | _0000_TAU_CLOCK_MODE_CKS | _0000_TAU_COMBINATION_SLAVE | _0000_TAU_TRIGGER_SOFTWARE | _0000_TAU_MODE_INTERVAL_TIMER | _0000_TAU_START_INT_UNUSED;
 TDR00 = _7CFF_TAU_TDR00_VALUE;
 TO0 &= ~_0001_TAU_CH0_OUTPUT_VALUE_1;
 TOE0 &= ~_0001_TAU_CH0_OUTPUT_ENABLE;
void TAU0_Channel0_Start(void)
 TMMK00 = 0U; /* enable INTTM00 interrupt */
 TS0 |= _0001_TAU_CH0_START_TRG_ON;
#pragma vector = INTTM00_vect
__interrupt void MD_INTTM00(void)
   SystemTime ++;
/* Start user code for adding. Do not edit comment generated here */
 unsigned long SystemTime = 0;
void DelayNms(unsigned int i)
 unsigned long time;
 time = SystemTime;
 while((SystemTime - time ) < i);
| 有奖活动 | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
 我要赚赏金 STM32
STM32 MCU
MCU 通讯及无线技术
通讯及无线技术 物联网技术
物联网技术 电子DIY
电子DIY 板卡试用
板卡试用 基础知识
基础知识 软件与操作系统
软件与操作系统 我爱生活
我爱生活 小e食堂
小e食堂
