实验二 按键控制数码管(消抖)
代码
//Name: key_xiaodou.v
//Function:
// PIN_27 50MHz SW8 KEY8 hgfedcba select
// clk rst key seg8[7:0] bit8[7:0]
//Author: YanceyLu
module key_xiaodou(clk,rst,key,seg8,bit8);
input clk,rst,key;
output [7:0] seg8;
output [7:0] bit8;
key_delay_xiaodou key_delay(clk,rst,key,okey);
reg [7:0] seg8;
reg [3:0] cnt;
assign bit8=8'b11111110;
always @(posedge clk or negedge rst)
begin
if(!rst)
cnt<=0;
else if(!okey)
begin
if(cnt==9)
cnt<=0;
else
cnt<=cnt+1;
end
else
cnt<=cnt;
end
always @(cnt)
begin
case(cnt)
0: seg8<=8'hc0;//0
1: seg8<=8'hf9;//1
2: seg8<=8'ha4;//2
3: seg8<=8'hb0;//3
4: seg8<=8'h99;//4
5: seg8<=8'h92;//5
6: seg8<=8'h82;//6
7: seg8<=8'hf8;//7
8: seg8<=8'h80;//8
9: seg8<=8'h90;//9
endcase
end
endmodule
//Name: key_delay_xiaodou.v
//Function:
// push key: 0
// pop key: 1
// xiao dou,using delay.
//Author: YanceyLu
module key_delay_xiaodou(clk,rst,i_pulse,o_pulse);
input clk,rst,i_pulse;
output o_pulse;
reg [19:0] delay_cnt;
reg [1:0] pulse_reg;
reg [1:0] pulse_reg_new;
wire low;
wire low_new;
//Test falling edge
begin
if(!rst)
pulse_reg[0]<=1;
else
pulse_reg[0]<=i_pulse;
end
begin
if(!rst)
pulse_reg[1]<=1;
else
pulse_reg[1]<=pulse_reg[0];
end
assign low=pulse_reg[1]&(~pulse_reg[0]);
//Delay 20ms
begin
if(!rst)
delay_cnt<=0;
else if(low)
delay_cnt<=0;
else
delay_cnt<=delay_cnt+1;
end
//Test falling edge again
begin
if(!rst)
pulse_reg_new[0]<=1;
else if(delay_cnt==20'hfffff)
pulse_reg_new[0]<=i_pulse;
end
begin
if(!rst)
pulse_reg_new[1]<=1;
else
pulse_reg_new[1]<=pulse_reg_new[0];
end
assign low_new=pulse_reg_new[1]&(~pulse_reg_new[0]);
//Output
assign o_pulse=~low_new;
endmodule
视频效果
