电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » Petit FatFs 刚移植成功
共7条 1/1 1 跳转至页
Petit FatFs 刚移植成功
2014-03-25 12:30:11     打赏
代码写的不咋的  传上来供大家乐乐。140319.zip
http://elm-chan.org/fsw/ff/00index_p.html  整个传送门。嘿嘿。
#include <stc12c5a60s2.h>
#include <intrins.h>
#include "delay.h"
#include "uart.h"
#include "spi_msd.h"
#include "spi.h"
#include "pff.h"
FATFS fatfs;   ///定义一个文件系统对象
void main(void)
//	unsigned char flag = 0;
	unsigned int  read_size = 0;
	unsigned char buf[512] = {0};
	unsigned char times = 0;
	FRESULT res;
	char s[] = "  ";
    unsigned int i;
	WORD br,rc,bw;
	P0 =0xff;
	Delay999ms();
	P0 =0xF0;
	Delay999ms();
	P0 =0xFf;
	UartInit();
	SPI_LowSpeed();
	SendString("STC12C5A60S2\r\nUart Test !\r\n");
	SendString("THAT THE TRUTH YOU LEAVE !\r\n");
	 SD_Init();
 	if(SD_ReadSingleBlock(0x100,buf)== 0)
		for(read_size = 1; read_size < 512 ;read_size++)
			SendData(buf[read_size]);
			Delay999us();
			//SendString(&buf);
	res = pf_mount(&fatfs);
    if(res == FR_OK)
    	SendString("挂载成功!\n"); //如果返回1,则挂载失败,否则成功
	else
		SendString("挂载失败\n");
	res = pf_open("test.txt");
		SendString("*********************\r\n");
		SendData(res + 0X30);
		SendString("\r\n*********************\r\n");
	if(res == FR_OK)
		SendString("打开文件成功\n"); //如果返回1,则打开失败,否则成功
	else
		SendString("打开文件失败\n");
	for (;;) //读SD卡baichi.txt里的内容
		rc = pf_read(s, sizeof(s), &br);	/* Read a chunk of file */
		if (rc || !br) break;				/* Error or end of file */
		for (i = 0; i < br; i++)			/* Type the data */
		SendData(s[i]);
	flag = SD_Init();
	if(flag)
		SendString("ERROR!\r\n");
	else
		SendString("SUCCESSFUL!\r\n");
 /*for(times = 0 ;times<200;times++)
 	buf[times] = times;
/*	SendString("READING ......!\r\n");
	if(SD_ReadSingleBlock(0,buf)== 0)
		SendString("SECTOR 0 DATA:\n");
			Delay999us();
			//SendString(&buf);
		Delay999ms();
		SendString("\nDATA ENDED\n");
	else
		SendString("READING ERROR!\r\n");
/*	SendString("WRITING ......!\r\n");
	if(SD_WriteSingleBlock(129,buf) == 0)
		for(times = 0;times<200;times++)
			buf[times] = 0;
		if(SD_ReadSingleBlock(129,buf)== 0)
			Delay999us();
	else
	 	SendString("WRITING ERROR!\r\n");
while(1)
关键词: Petit
2014-03-25 12:49:38     打赏
因为第一次操作SD卡是用的znFAT,之后就偏向于用znFAT了,楼主的附件还在审核,过会下载下来瞧瞧
2014-03-25 13:58:14     打赏
找人帮忙还要积分啊,这个不推荐
2014-03-25 14:20:01     打赏
没懂老大啥意思?  我这不是找人帮忙,,,,,
2014-03-25 23:07:29     打赏
FatFS很好的文件操作系统
我们就使用的这个开源 免费的文件系统
2014-04-29 08:33:07     打赏
好东西,回宿舍了下载看看
2014-04-29 09:10:12     打赏
标记一下,也准备玩玩文件系统
共7条 1/1 1 跳转至页
