13楼
16楼
传一个用VB写的关于温度计的上位机,配合单片机串口程序在电脑端实时显示温度曲线
Public sina As Variant
Public sinb As Variant
Public sinc As Variant
Public sind As Variant
Public sine As Variant
Public i As Variant
Private Sub Command1_Click()
If Command1.Caption = "关闭串口" Then
MSComm1.PortOpen = False
Command1.Caption = "打开串口"
Timer1.Enabled = False
Else
MSComm1.CommPort = Combo1.Text
MSComm1.Settings = "" '"Combo2.text"'","'" combo3.text "'", "'" combo4.text "'" , "'"combo5.text "'""
MSComm1.InputMode = 0
MSComm1.PortOpen = True
Timer1.Enabled = True
End If
End Sub
Private Sub Form_Load()
Dim i As Integer '生成串口号
For i = 1 To 20
With Combo1
.AddItem i
End With
Next
Combo2.AddItem "600"
Combo2.AddItem "1200"
Combo2.AddItem "2400"
Combo2.AddItem "4800"
Combo2.AddItem "9600"
Combo2.AddItem "57600"
Combo2.AddItem "115200"
Combo3.AddItem "n"
Combo3.AddItem "e"
Combo3.AddItem "o"
Combo3.AddItem "s"
Combo3.AddItem "m"
Combo4.AddItem "8"
Combo4.AddItem "9"
Combo5.AddItem "1"
Combo5.AddItem "1.5"
Combo5.AddItem "2"
i = 100
sina = 0
sind = 1400
sinc = 0
End Sub
Private Sub Timer1_Timer()
Dim buf$
Dim v As Double
buf = Trim(MSComm1.Input)
If Len(buf) <> 0 Then
sina = sinc
sinb = sind
v = Asc(buf) + 256 '只传了低八位,所以直接加256,相当于把接受的数据& 0001 0000 0000
v = v / 10
Text1.Text = Text1.Text + Str(v) + Chr(13) + Chr(10)
sinc = (sina + 100)
sind = (Asc(buf) * 20)
sine = Val(2000)
Form1.Picture1.Line (sina, 5000 - sinb)-(sinc, 5000 - sind), sine
If sinc = 10000 Then
Picture1.Cls
sina = 0
sinc = 0
End If
End If
End Sub
Private Sub cmdquite_chick()
Unload Me
End Sub
等一会再传一个EXE可执行文件
程序数据处理比较特殊
uint tmp() //get the temperature
float tt;
uchar a,b;
dsreset();
delay(1);
tmpwritebyte(0xcc);
tmpwritebyte(0xbe);
a=tmpread();
b=tmpread();
temp=b;
temp<<=8; //two byte compose a int variable
temp=temp|a;
tt=temp*0.0625;
temp=tt*10+0.5;
return temp;
这个是单片机读18B20,传感器是12数据,但是我们只传送了低八位,因为常温状态下第九位为1,所以加256
ii =tmp(); // SBUF=ii>>8; // while(TI==0);//???????? // TI=0;//?????? // SBUF=ii; while(TI==0);//???????? TI=0;//??????
| OrangePiZero2W系统被打赏¥33元 | |
