电子产品世界 » 论坛首页 » 休闲专区 » 我爱工作 » 替换IRLR8726 MSO VS3080性能更好 价格更优势
2014-06-23 10:09:36     打赏
       丘先生  13827482730. QQ1481000462  提供样品测试
No.
Part ID
Polarity
BVGS [V]
VTH[V]
BVDSS [V]
ID[A] TC=25°C
RDON Max. [mohm] @ TC=25°C (A)
Package
Production
Status
Vgs=10V
Vgs=4.5V
Vgs=2.5V
1
VS2301AT
PMOS
±12
-0.5~-1.5
-20
-4.2
95
120
SOT-23
Full production
2
VS2301AL
PMOS
±12
-0.5~-1.5
-20
-4.2
95
120
SOT-23-3L
Full production
3
VS2301BT
PMOS
±12
-0.5~-1.5
-20
-2.8
95
120
SOT-23
Full production
4
VS3401AT
PMOS
±12
-0.5~-1.5
-30
-2.8
75
90
120
SOT-23
Full production
5
VS3401AL
PMOS
±12
-0.5~-1.5
-30
-4.2
75
90
120
SOT23-3L
Full production
6
VS3407AT
PMOS
±20
-1~-2
-30
-4.2
75
90
120
SOT-23
Coming Soon
7
VS3407AL
PMOS
±20
-1~-2
-30
-4.2
75
90
120
SOT23-3L
Coming Soon
8
VS9435AS
PMOS
±20
-0.9~-2.0
-30
-4.9
60
90
SOP8
Full production
9
VS4953AS
Dual-PMOS
±20
-0.9~-2.0
-30
-4.9
60
90
SOP8
Full production
10
VS4503AS
P+NMOS
±20
1~2
±30
±8
18
28
SOP8
Full production
11
VS4503DP
P+NMOS
±20
1~2
±30
±8
18
28
DFN5X6
Full production
12
VS2302AT
NMOS
±20
0.4-1.0
20
3
45
65
85
SOT23
Full Production
13
VS2300AT
NMOS
±12
0.5~1.5
20
5.6
32
65
SOT-23
Full production
14
VS2300AL
NMOS
±20
0.5~1.5
20
5.2
32
40
SOT23-3L
Full production
15
VS8205AS
Dual-NMOS
±12
0.4~1.2
20
6
25
40
SOT23-6
Full production
16
VS8205ATS
Dual-NMOS
±12
0.4-1.2
20
6
25
40
TSSOP8
Full production
17
VS8810AL
NMOS
±12
0.6~1.8
20
7
20
23
28
SOT-23-3L
Full production
18
VS8810ATS
Dual-NMOS
±12
0.6~1.8
20
7
20
23
28
TSSOP8
Full production
19
VS2598AD
NMOS
±20
1~3
30
98
4
5
8
TO-252
Full production
20
VS2598AI
NMOS
±20
1~3
30
98
4
5
8
TO-251
Full production
21
VS2598AP
NMOS
±20
1~3
30
98
4
5
8
DFN5X6
Full production
22
VS3400AT
NMOS
±12
0.6~1.3
30
5.8
30
40
SOT-23
Full production
23
VS3400AL
NMOS
±12
0.6~1.3
30
5.8
30
40
SOT-23-3L
Full production
24
VS3038AO
NMOS
±20
1~3
30
8
22
40
SOP8
Full production
25
VS3018AD
NMOS
±12
0.6~1.8
30
16
30
40
TO-252
Full production
26
VS3038AI
NMOS
±20
1~3
30
30
22
40
TO-251
Full production
27
VS3038AD
NMOS
±20
1~3
30
30
22
40
TO-252
Full production
28
VS3060AD
NMOS
±20
1~3
30
60
10
12
DFN5X6
Engineering
29
VS3060AI
NMOS
±20
1~3
30
60
10
12
TO-251
Engineering
产品特点
♦低导通电阻
♦快速切换
♦ 100 %雪崩测试
♦重复性雪崩中允许多达TJMAX
♦无铅,符合RoHS标准
描述
VS3080AP由沟槽加工技术,旨在实现极低的导通电阻。这种设计的附加功能是150 °C交界处的工作温度,开关速度快,改进型重复雪崩额定值。这些特点结合起来,使这个设计一个非常有效和可靠的装置在汽车应用以及其他各种应用。
绝对最大额定值
超越“绝对最大额定值”,就可能造成永久性损坏设备。这些压力额定值只,以及设备在这些或超出了规范标明的任何其它条件下的功能操作不暗示。暴露于长时间在绝对最大额定条件下可能影响器件的可靠性。热电阻和功耗额定值
计量板下安装和静止空气条件。环境温度(TA )为25 ° C,除非另有规定。
Symbol
Parameter
Rating
Unit
Common Ratings (TC=25°C Unless Otherwise Noted)
VGS
Gate-Source Voltage
±20
V
V(BR)DSS
Drain-Source BreakdowVoltage
30
V
TJ
Maximum Junction Temperature
150
°C
TSTG
Storage Temperature Range
-55 to 150
°C
IS
Diode Continuous Forward Current
TC =25°C
90
A
Mounted on Large Heat Sink
IDM
Pulse Drain Current Tested (Sillicon Limit)
TC =25°C
320
A
ID
GS
T =25°C
90
A
PD
Maximum Power Dissipation
TC =25°C
62
W
Rθ JC
Thermal Resistance-Junction to Case
1.98
°C/W
Drain-Source Avalanche Ratings
EAS
Avalanche Energy, Single Pulsed
225
mJ
Symbol
Parameter
Condition
Min.
Typ.
Max.
Unit
Static Electrical Characteristics @ TJ = 25°C (unless otherwise stated)
V(BR)DSS
VGS=0V ID=250μA
30
V
IDSS
Zero Gate Voltage Drain Current(Tc=25)
VDS=24V,VGS=0V
1
μA
Zero Gate Voltage Drain Current(Tc=125)
VDS=24V,VGS=0V
100
μA
IGSS
Gate-BodLeakage Current
VGS=±20V,VDS=0V
±100
nA
VGS(TH)
Gate Threshold Voltage
VDS=VGS,ID=250μA
1.2
2.0
2.8
V
RDS(ON)
Drain-Source On-State Resistance
V   =10V, I =40A
4.0
5.5
RDS(ON)
V   =4.5V, I =20A
5.5
6.5
Dynamic Electrical Characteristics @ TJ = 25°C (unless otherwise stated)
Ciss
Input Capacitance
VDS=15V,VGS=0V, f=1MHz
1650
pF
Coss
Output Capacitance
210
pF
Crss
Reverse Transfer Capacitance
155
pF
Qg
Total Gate Charge
VGS=10V
VDS=15V,ID=20A, VGS=10V
36
nC
VGS=4.5V
18.5
nC
Qgs
Gate-Source Charge
5
nC
Qgd
Gate-Drain Charge
8
nC
Switching Characteristics
td(on)
Turn-on Delay Time
VDD=15V, ID=10A, RG=6.8Ω, VGS=10V
13.5
nS
tr
Turn-on Rise Time
15
nS
td(off)
Turn-Off Delay Time
20
nS
tf
Turn-Off Fall Time
14
nS
Source- Drain Diode Characteristics@ TJ = 25°C (unless otherwise stated)
ISD
Source-drain current(Body Diode)
Tc=25
90
A
VSD
Forward on voltage
ISD=60A,VGS=0V
1.3
V
trr
Reverse Recovery Time
Tj=25,Isd=30A,
VGS=0V
di/dt=100A/μs
24
nS
Qrr
Reverse Recovery Charge
13
nC
注意:
①脉冲宽度≤300μs ;占空比≤ 2 % 。
②由TJMAX有限公司,开始温度TJ = 25 ° C,L = 0.5mH , RG = 25Ω , IAS = 30A ,V GS = 10V 。部分不推荐使用高于此值
③重复评级;脉冲宽度限制最大。结温度。
关键词: IRLR8726     VS3080
