#include "stm32f10x.h"
#include "stm32_eval.h"
#include
EXTI_InitTypeDef   EXTI_InitStructure;
GPIO_InitTypeDef   GPIO_InitStructure;
NVIC_InitTypeDef   NVIC_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
long flag;
void delay_us(u32 n)
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
void  delay_ms(u32 n)
    while(n--)
    delay_us(1000);
void RCC_Configuration(void)//外设时钟使能
	SystemInit();
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG  管脚映射重映射
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
	GPIO_ResetBits(GPIOD,GPIO_Pin_2);
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
	GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
	  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2|RCC_APB1Periph_TIM3, ENABLE);//TIM2  TIM3
		RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE);//TIM8
void USART_int(long BaudRate)//USART1初始化
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* PA10 USART1_Rx  */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  USART_InitStructure.USART_BaudRate = BaudRate;//??????
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
  USART_InitStructure.USART_Parity = USART_Parity_No;//????
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
	USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
    USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
    USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
    USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
    USART_ClockInit(USART1, &USART_ClockInitStructure);
  USART_Init(USART1, &USART_InitStructure);
  USART_Cmd(USART1, ENABLE);
	USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
 USART_Cmd(USART1, ENABLE);//使能USART1
void NVIC_Configuration(void)//中断优先级设置
  NVIC_InitTypeDef NVIC_InitStructure;//定义结构体变量
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);//设置优先级分组
  /* Enable the TIM2 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;//TIM2TIM3中断
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//先占优先级0级
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 5;//从优先级1级
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;//IRQ通道被使能
	NVIC_Init(&NVIC_InitStructure);//初始化NVIC寄存器
	/* Enable the TIM3 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;//TIM2TIM3中断
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 8;//从优先级1级
	/* Enable the TIM8 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;//从优先级1级
void Timer_Config(void)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;//定义结构体变量
	RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);//使能TIM2外设
	TIM_DeInit(TIM2);//复位时钟TIM2,恢复初始状态
	 /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 36000;//周期
  TIM_TimeBaseStructure.TIM_Prescaler = 1000;//分频系数
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;//设置时钟分割
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//向上计数模式
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);//初始化TIM2
	TIM_ClearFlag(TIM2,TIM_FLAG_Update);//清楚标志
  TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE ); //使能TIM2的更新中断
  /* TIM2 enable counter */
  TIM_Cmd(TIM2, ENABLE);//使能TIM2外设
	RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);//使能TIM3外设
	TIM_DeInit(TIM3);//复位时钟TIM3,恢复初始状态
  TIM_TimeBaseStructure.TIM_Period = 56000;//周期
  TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);//初始化TIM3
	TIM_ClearFlag(TIM3,TIM_FLAG_Update);//清楚标志
  TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE ); //使能TIM3的更新中断
  TIM_Cmd(TIM3, ENABLE);//使能TIM3外设
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE);//使能TIM8外设
	TIM_DeInit(TIM8);//复位时钟TIM8,恢复初始状态
  TIM_TimeBaseStructure.TIM_Period = 50000;//周期
  TIM_TimeBaseStructure.TIM_Prescaler = 1100;//分频系数
  TIM_TimeBaseStructure.TIM_ClockDivision =TIM_CKD_DIV1 ;//设置时钟分割
  TIM_TimeBaseInit(TIM8, &TIM_TimeBaseStructure);//初始化TIM2
	TIM_ClearFlag(TIM8,TIM_FLAG_Update);//清楚标志
  TIM_ITConfig(TIM8,TIM_IT_Update,ENABLE ); //使能TIM8的更新中断
  TIM_Cmd(TIM8, ENABLE);//使能TIM2外设
void TIM2_IRQHandler(void) //TIM2中断
if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET) //检查TIM2更新中断发生与否
TIM_ClearITPendingBit(TIM2, TIM_IT_Update ); //清除TIM2更新中断标志
	GPIO_SetBits(GPIOC,GPIO_Pin_1);
void TIM3_IRQHandler(void) //TIM2中断
if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) //检查TIM2更新中断发生与否
TIM_ClearITPendingBit(TIM3, TIM_IT_Update ); //清除TIM2更新中断标志
	GPIO_SetBits(GPIOC,GPIO_Pin_2);
void TIM8_IRQHandler(void) //TIM2中断
if (TIM_GetITStatus(TIM8, TIM_IT_Update) != RESET) //检查TIM2更新中断发生与否
TIM_ClearITPendingBit(TIM8, TIM_IT_Update ); //清除TIM2更新中断标志
	GPIO_SetBits(GPIOC,GPIO_Pin_3);
int main(void)
  RCC_Configuration();
  USART_int(115200);
	NVIC_Configuration();
	printf(" config done...\r\n");
  Timer_Config();
 TIM2_IRQHandler();
 TIM3_IRQHandler();
	TIM8_IRQHandler();
  while (1){
GPIO_ResetBits(GPIOC,GPIO_Pin_1);
		delay_ms(200);
GPIO_ResetBits(GPIOC,GPIO_Pin_2);
		delay_ms(400);
GPIO_ResetBits(GPIOC,GPIO_Pin_3);
		delay_ms(200);
#ifdef  USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
  while (1)
#endif
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
  * @brief  Retargets the C library printf function to the USART.
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  while (1)
#endif
 我要赚赏金 STM32
STM32 MCU
MCU 通讯及无线技术
通讯及无线技术 物联网技术
物联网技术 电子DIY
电子DIY 板卡试用
板卡试用 基础知识
基础知识 软件与操作系统
软件与操作系统 我爱生活
我爱生活 小e食堂
小e食堂
