//库函数
#include "stm32f10x.h"
#include "stm32_eval.h"
#include <stdio.h>
#define VREF 3.3
//延时函数
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
//延时函数
void delay_ms(u32 n)
while(n--)
delay_us(1000);
//几个结构体的定义
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
//配置时钟函数
void RCC_Configuration(void)
SystemInit();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void USART_int(long BaudRate)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//使能PA USART1
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;//TX位于PA9
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //推挽输出
GPIO_Init(GPIOA, &GPIO_InitStructure);//TX初始化PA9
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//RX位于PA10
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//悬空输出
GPIO_Init(GPIOA, &GPIO_InitStructure);//RX初始化PA10
USART_InitStructure.USART_BaudRate = BaudRate;//传输速率
USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长8比特
USART_InitStructure.USART_StopBits = USART_StopBits_1;//停止位1
USART_InitStructure.USART_Parity = USART_Parity_No;//????
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//流控位none
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//接收和发送模式
USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
USART_ClockInit(USART1, &USART_ClockInitStructure);//初始化USART1时钟
USART_Init(USART1, &USART_InitStructure);//初始化USART1
USART_Cmd(USART1, ENABLE);
USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
void PWM_Config()
{ uint16_t PrescalerValue = 0;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;//定义结构体
TIM_OCInitTypeDef TIM_OCInitStructure;
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);//打开TIM2,TIM2挂在AP1上
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO , ENABLE);//一、开启功能复用
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;//所需的3个管脚,复用输出
TIM_Cmd(TIM2, ENABLE);
PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;//二、配置TIM2
TIM_TimeBaseStructure.TIM_Period = 0x07FF;
TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;//三、脉冲宽度调制模式1
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//四、选择输出比较状态
TIM_OCInitStructure.TIM_Pulse = 0xFFFF;//IM_Pulse设置了待装入捕获比较寄存器的脉冲值,取值在0x0000-0xFFFF之间
TIM_OC2Init(TIM2, &TIM_OCInitStructure);
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//(通道3)
TIM_OCInitStructure.TIM_Pulse = 0xFFFF;//0x0000最亮,0xFFFF熄灭
TIM_OC3Init(TIM2, &TIM_OCInitStructure);
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//(通道4)
TIM_OC4Init(TIM2, &TIM_OCInitStructure);
TIM_ARRPreloadConfig(TIM2, ENABLE);//重新装载初始值
void PWM_TEST()
{ unsigned int temp0=0,temp1=0,temp2=0;
printf("PWM-RGB TEST......\r\n");
while(1)
TIM_SetCompare2(TIM2, temp0);//设置TIM2捕获比较2寄存器值
if (temp0>=2047)//2的11次方减一
delay_ms(2000);
temp0=0;
break;
else {temp0++;delay_us(1000);}
while(1)
TIM_SetCompare3(TIM2, temp1);//设置TIM2捕获比较2寄存器值
if (temp1>=2047)
delay_ms(2000);
temp1=0;
break;
else {temp1++;delay_us(1000);}
while(1)
TIM_SetCompare4(TIM2, temp2);
if (temp2>=2047)
delay_ms(2000);
temp2=0;
break;
else {temp2++;delay_us(1000);}
int main(void)
RCC_Configuration();
USART_int(115200);
printf(" config done...\r\n");
PWM_Config();
delay_ms(1000);
while(1)
PWM_TEST();
#ifdef USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
while (1)
#endif
#ifdef __GNUC__
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif
PUTCHAR_PROTOTYPE
USART_SendData(EVAL_COM1, (uint8_t) ch);
while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
return ch;
while (1)
#endif
//代码未OK,先放个注释留个位置
再次更新pwm的
//库函数
#include
#define VREF 3.3
unsigned int temp0,temp1,temp2;
//延时函数
u8 j;
while(n--)
for(j=0;j<10;j++);
//延时函数
while(n--)
delay_us(1000);
//几个结构体的定义
//配置时钟函数
SystemInit();
void PWM_Config()
void colour(int z)//自定义的函数colour
switch(z)//分别点亮相应的颜色
case 0 : temp0=0,temp1=5000,temp2=0; /*红色*/ break;
case 1 : temp0=0,temp1=5000,temp2=2500;/*橙色*/ break;
case 2 : temp0=0,temp1=5000,temp2=5000;/*黄色*/ break;
case 3 : temp0=0,temp1=0,temp2=5000; /*绿色*/ break;
case 4 : temp0=2500,temp1=0,temp2=2500;/*青色*/ break;
case 5: temp0=5000,temp1=0,temp2=0; /*蓝色*/ break;
case 6 : temp0=2500,temp1=2500,temp2=0;/*紫色*/ break;
default: printf(" error\n");
void PWM_TEST()
int i=0;
for(i=0;i<7;i++)
colour(i); //temp1-红,temp2-绿,temp0-蓝
TIM_SetCompare2(TIM2,temp0);delay_ms(500); //设置TIM2捕获比较器2寄存器的值
TIM_SetCompare3(TIM2,temp1);delay_ms(500);//TIM——通道数(定时器,数值)
TIM_SetCompare4(TIM2,temp2);delay_ms(500);
int main(void)//主函数
USART_int(115200);
printf(" config done...\r\n");//屏幕打印出config done...
PWM_Config();//配置pwm
delay_ms(1000);//执行延时函数
while(1)
PWM_TEST();
}//当以上为真时,执行PWM_TEST();函数
while (1)
#endif
#ifdef __GNUC__
#else
#endif
PUTCHAR_PROTOTYPE
return ch;
while (1)
#endif
| 有奖活动 | |
| 2026年“我要开发板活动”第三季,开始了! | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
| 打赏了!打赏了!打赏了! | |
| 全彩色度变化图的绘制被打赏¥27元 | |
| 【FreeRtos】FreeRtos任务栈的生长方向管理方式被打赏¥20元 | |
| 【瑞萨RA8D1 LVGL/LWIP评测】LVGL添加输入设备:EC11旋转编码器被打赏¥39元 | |
| 【瑞萨RA8D1 LVGL/LWIP评测】RA8D1部署FreeRTOS+LVGL被打赏¥33元 | |
| 空气质量检测器设计与实现被打赏¥24元 | |
| 【瑞萨RA8D1 LVGL/LWIP评测】LWIP进行UDP、TCP、HTTP、MQTT功能联合测试被打赏¥41元 | |
| 【瑞萨RA8D1 LVGL/LWIP评测】RA8D1部署FreeRTOS+LWIP被打赏¥36元 | |
| RTOS怎么选?让我来给你答案!被打赏¥15元 | |
| 【S32K3XX】Flash驱动使用被打赏¥26元 | |
| 【FreeRtos】第一个任务的启动过程被打赏¥21元 | |
