电子产品世界 » 论坛首页 » 高校专区 » 周师电子设计创新社区 » 第五次作业
第五次作业
2014-10-31 18:03:21     打赏
3-5
条件赋值语句
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY decoder3to8 IS
port( DIN: IN STD_LOGIC_VECTOR(2 DOWNTO 0);
DOUT: OUT BIT_VECTOR(7 DOWNTO 0));
END decoder3to8;
ARCHITECTURE behave OF decoder3to8 IS
BEGIN
WITH CONV_INTEGER(DIN) SELECT
DOUT<="00000001" WHEN 0,
"00000010" WHEN 1,
"00000100" WHEN 2,
"00001000" WHEN 3,
"00010000" WHEN 4,
"00100000" WHEN 5,
"01000000" WHEN 6,
"10000000" WHEN 7,
UNAFFECTED WHEN OTHERS;
END behave;
 2 ):case 语句
LIBRARY IEEE;
END decoder3to8;
BEGIN
PROCESS (DIN)
BEGIN
CASE CONV_INTEGER(DIN) IS
WHEN 0 => DOUT<="00000001";
WHEN 1 => DOUT<="00000010";
WHEN 2 => DOUT<="00000100";
WHEN 3 => DOUT<="00001000";
WHEN 4 => DOUT<="00010000";
WHEN 5 => DOUT<="00100000";
WHEN 6 => DOUT<="01000000";
WHEN 7 => DOUT<="10000000";
WHEN OTHERS => NULL;
END CASE;
END PROCESS;
END behave;
 3 ):if_else 语句
LIBRARY IEEE;
END decoder3to8;
BEGIN
PROCESS (DIN)
BEGIN
IF CONV_INTEGER(DIN)=0 THEN DOUT<="00000001";
ELSIF CONV_INTEGER(DIN)=1 THEN DOUT<="00000010";
ELSIF CONV_INTEGER(DIN)=2 THEN DOUT<="00000100";
ELSIF CONV_INTEGER(DIN)=3 THEN DOUT<="00001000";
ELSIF CONV_INTEGER(DIN)=4 THEN DOUT<="00010000";
ELSIF CONV_INTEGER(DIN)=5 THEN DOUT<="00100000";
ELSIF CONV_INTEGER(DIN)=6 THEN DOUT<="01000000";
ELSIF CONV_INTEGER(DIN)=7 THEN DOUT<="10000000";
END IF;
END PROCESS;
END behave;
 4 ):移位操作符
LIBRARY IEEE;
END decoder3to8;
BEGIN
DOUT<="00000001" SLL CONV_INTEGER(DIN);
END behave;
3-14
LIBRARY IEEE;
ENTITY vote_7 IS
PORT( DIN: IN STD_LOGIC_VECTOR(6 DOWNTO 0);
G_4: OUT STD_LOGIC;
CNTH: OUT STD_LOGIC_VECTOR(2 DOWNTO 0));
END vote_7;
ARCHITECTURE BHV OF vote_7 IS
BEGIN
PROCESS(DIN)
VARIABLE Q: STD_LOGIC_VECTOR(2 DOWNTO 0);
BEGIN
Q:="000";
FOR n IN 0 TO 6 LOOP
IF(DIN(n)='1') THEN Q:=Q+1; END IF;
END LOOP;
CNTH<=Q;
IF Q>=4 THEN G_4<='1'; ELSE G_4<='0'; END IF;
END PROCESS;
END BHV;
猜你关注: 无觅关联推荐[?]
宽压输入(1.8V-28V)升压控制器(MAX668)
共1条 1/1 1
快速回复主题
  • 用户名:wengkai
  • 标题:
  • 内容:
  •  温馨提示:若您所发内容较多,耗时很长,建议您在发送前copy文档,以免出现错误导致文档丢失。
  • 验证码:
关于我们 - 广告服务 - 企业会员服务 - 网站地图 - 联系我们 - 征稿 - 友情链接 - 手机EEPW
Copyright ©2002 ELECTRONIC ENGINEERING & PRODUCT WORLD. All rights reserved.
