电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » zynq_devicetree
zynq_devicetree
2017-06-28 14:57:51     打赏
device tree最开始的是skeleton.dtsi
[plain] view plain copy  在CODE上查看代码片派生到我的代码片
http://blog.csdn.net/shichaog/article/details/51249106
* Skeleton device tree; the bare minimum needed to boot; just include and
* add a compatible value.  The bootloader will typically populate the memory
* node.
    #address-cells = <1>;
    #size-cells = <1>;
    chosen { };
    aliases { };
    memory { device_type = "memory"; reg = <0 0>; };
这是32位体系架构的设备树的skeleton,address-cells那行表示的是用32bit表示地址,寄存器也是用32bit来表示。接下来设备树里的东西是和zynq-7000这款芯片cpu息息相关的定义。将cpu以及外设都定义在此处。
《zynq-7000.dtsi》
  1 /*
  2  *  Copyright (C) 2011 - 2014 Xilinx
  3  *
  4  * This software is licensed under the terms of the GNU General Public
  5  * License version 2, as published by the Free Software Foundation, and
  6  * may be copied, distributed, and modified under those terms.
  7  *
  8  * This program is distributed in the hope that it will be useful,
  9  * but WITHOUT ANY WARRANTY; without even the implied warranty of
10  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
11  * GNU General Public License for more details.
12  */
13 /include/ "skeleton.dtsi"
14
15 / {
16     compatible = "xlnx,zynq-7000";
17
18     cpus {
19         #address-cells = <1>;
20         #size-cells = <0>;
21
22         cpu@0 {
23             compatible = "arm,cortex-a9";
24             device_type = "cpu";
25             reg = <0>;
26             clocks = <&clkc 3>;
27             clock-latency = <1000>;
28             cpu0-supply = <&regulator_vccpint>;
29             operating-points = <
30                 /* kHz    uV */
31                 666667  1000000
32                 333334  1000000
33             >;
34         };
35
36         cpu@1 {
37             compatible = "arm,cortex-a9";
38             device_type = "cpu";
39             reg = <1>;
40             clocks = <&clkc 3>;
41         };
42     };
43
44     pmu {
45         compatible = "arm,cortex-a9-pmu";
46         interrupts = <0 5 4>, <0 6 4>;
47         interrupt-parent = <&intc>;
48         reg = < 0xf8891000 0x1000 0xf8893000 0x1000 >;
49     };
50
51     regulator_vccpint: fixedregulator@0 {
52         compatible = "regulator-fixed";
53         regulator-name = "VCCPINT";
54         regulator-min-microvolt = <1000000>;
55         regulator-max-microvolt = <1000000>;
56         regulator-boot-on;
57         regulator-always-on;
58     };
59
60     amba: amba {
61         compatible = "simple-bus";
62         #address-cells = <1>;
63         #size-cells = <1>;
64         interrupt-parent = <&intc>;
65         ranges;
66
67         adc: adc@f8007100 {
68             compatible = "xlnx,zynq-xadc-1.00.a";
69             reg = <0xf8007100 0x20>;
70             interrupts = <0 7 4>;
71             interrupt-parent = <&intc>;
72             clocks = <&clkc 12>;
73         };
74
75         can0: can@e0008000 {
76             compatible = "xlnx,zynq-can-1.0";
77             status = "disabled";
78             clocks = <&clkc 19>, <&clkc 36>;
79             clock-names = "can_clk", "pclk";
80             reg = <0xe0008000 0x1000>;
81             interrupts = <0 28 4>;
82             interrupt-parent = <&intc>;
83             tx-fifo-depth = <0x40>;
84             rx-fifo-depth = <0x40>;
85         };
86
87         can1: can@e0009000 {
88             compatible = "xlnx,zynq-can-1.0";
89             status = "disabled";
90             clocks = <&clkc 20>, <&clkc 37>;
91             clock-names = "can_clk", "pclk";
92             reg = <0xe0009000 0x1000>;
93             interrupts = <0 51 4>;
94             interrupt-parent = <&intc>;
95             tx-fifo-depth = <0x40>;
96             rx-fifo-depth = <0x40>;
97         };
98
99         gpio0: gpio@e000a000 {
100             compatible = "xlnx,zynq-gpio-1.0";
101             #gpio-cells = <2>;
102             #interrupt-cells = <2>;
103             clocks = <&clkc 42>;
104             gpio-controller;
105             interrupt-controller;
106             interrupt-parent = <&intc>;
107             interrupts = <0 20 4>;
108             reg = <0xe000a000 0x1000>;
109         };
110
111         i2c0: i2c@e0004000 {
112             compatible = "cdns,i2c-r1p10";
113             status = "disabled";
114             clocks = <&clkc 38>;
115             interrupt-parent = <&intc>;
116             interrupts = <0 25 4>;
117             reg = <0xe0004000 0x1000>;
118             #address-cells = <1>;
119             #size-cells = <0>;
120         };
121
122         i2c1: i2c@e0005000 {
123             compatible = "cdns,i2c-r1p10";
124             status = "disabled";
125             clocks = <&clkc 39>;
126             interrupt-parent = <&intc>;
127             interrupts = <0 48 4>;
128             reg = <0xe0005000 0x1000>;
129             #address-cells = <1>;
130             #size-cells = <0>;
131         };
132
133         intc: interrupt-controller@f8f01000 {
134             compatible = "arm,cortex-a9-gic";
135             #interrupt-cells = <3>;
136             interrupt-controller;
137             reg = <0xF8F01000 0x1000>,
138                   <0xF8F00100 0x100>;
139         };
140
141         L2: cache-controller@f8f02000 {
142             compatible = "arm,pl310-cache";
143             reg = <0xF8F02000 0x1000>;
144             interrupts = <0 2 4>;
145             arm,data-latency = <3 2 2>;
146             arm,tag-latency = <2 2 2>;
147             cache-unified;
148             cache-level = <2>;
149         };
150
151         mc: memory-controller@f8006000 {
152             compatible = "xlnx,zynq-ddrc-a05";
153             reg = <0xf8006000 0x1000>;
154         };
155
156         ocmc: ocmc@f800c000 {
157             compatible = "xlnx,zynq-ocmc-1.0";
158             interrupt-parent = <&intc>;
159             interrupts = <0 3 4>;
160             reg = <0xf800c000 0x1000>;
161         };
162
163         uart0: serial@e0000000 {
164             compatible = "xlnx,xuartps", "cdns,uart-r1p8";
165             status = "disabled";
166             clocks = <&clkc 23>, <&clkc 40>;
167             clock-names = "uart_clk", "pclk";
168             reg = <0xE0000000 0x1000>;
169             interrupts = <0 27 4>;
170         };
171
172         uart1: serial@e0001000 {
173             compatible = "xlnx,xuartps", "cdns,uart-r1p8";
174             status = "disabled";
175             clocks = <&clkc 24>, <&clkc 41>;
176             clock-names = "uart_clk", "pclk";
177             reg = <0xE0001000 0x1000>;
178             interrupts = <0 50 4>;
179         };
180
181         spi0: spi@e0006000 {
182             compatible = "xlnx,zynq-spi-r1p6";
183             reg = <0xe0006000 0x1000>;
184             status = "disabled";
185             interrupt-parent = <&intc>;
186             interrupts = <0 26 4>;
187             clocks = <&clkc 25>, <&clkc 34>;
188             clock-names = "ref_clk", "pclk";
189             #address-cells = <1>;
190             #size-cells = <0>;
191         };
192
193         spi1: spi@e0007000 {
194             compatible = "xlnx,zynq-spi-r1p6";
195             reg = <0xe0007000 0x1000>;
196             status = "disabled";
197             interrupt-parent = <&intc>;
198             interrupts = <0 49 4>;
199             clocks = <&clkc 26>, <&clkc 35>;
200             clock-names = "ref_clk", "pclk";
201             #address-cells = <1>;
202             #size-cells = <0>;
203         };
204
205         qspi: spi@e000d000 {
206             clock-names = "ref_clk", "pclk";
207             clocks = <&clkc 10>, <&clkc 43>;
208             compatible = "xlnx,zynq-qspi-1.0";
209             status = "disabled";
210             interrupt-parent = <&intc>;
211             interrupts = <0 19 4>;
212             reg = <0xe000d000 0x1000>;
213             #address-cells = <1>;
214             #size-cells = <0>;
215         };
216
217         smcc: memory-controller@e000e000 {
218             #address-cells = <1>;
219             #size-cells = <1>;
220             status = "disabled";
221             clock-names = "memclk", "aclk";
222             clocks = <&clkc 11>, <&clkc 44>;
223             compatible = "arm,pl353-smc-r2p1";
224             interrupt-parent = <&intc>;
225             interrupts = <0 18 4>;
226             ranges ;
227             reg = <0xe000e000 0x1000>;
228             nand0: flash@e1000000 {
229                 status = "disabled";
230                 compatible = "arm,pl353-nand-r2p1";
231                 reg = <0xe1000000 0x1000000>;
232                 #address-cells = <0x1>;
233                 #size-cells = <0x1>;
234             };
235             nor0: flash@e2000000 {
236                 status = "disabled";
237                 compatible = "cfi-flash";
238                 reg = <0xe2000000 0x2000000>;
239                 #address-cells = <1>;
240                 #size-cells = <1>;
241             };
242         };
243
244         gem0: ethernet@e000b000 {
245             compatible = "cdns,zynq-gem", "cdns,gem";
246             reg = <0xe000b000 0x1000>;
247             status = "disabled";
248             interrupts = <0 22 4>;
249             clocks = <&clkc 30>, <&clkc 30>, <&clkc 13>;
250             clock-names = "pclk", "hclk", "tx_clk";
251             #address-cells = <1>;
252             #size-cells = <0>;
253         };
254
255         gem1: ethernet@e000c000 {
256             compatible = "cdns,zynq-gem", "cdns,gem";
257             reg = <0xe000c000 0x1000>;
258             status = "disabled";
259             interrupts = <0 45 4>;
260             clocks = <&clkc 31>, <&clkc 31>, <&clkc 14>;
261             clock-names = "pclk", "hclk", "tx_clk";
262             #address-cells = <1>;
263             #size-cells = <0>;
264         };
265
266         sdhci0: sdhci@e0100000 {
267             compatible = "arasan,sdhci-8.9a";
268             status = "disabled";
269             clock-names = "clk_xin", "clk_ahb";
270             clocks = <&clkc 21>, <&clkc 32>;
271             interrupt-parent = <&intc>;
272             interrupts = <0 24 4>;
273             reg = <0xe0100000 0x1000>;
274         };
275
276         sdhci1: sdhci@e0101000 {
277             compatible = "arasan,sdhci-8.9a";
278             status = "disabled";
279             clock-names = "clk_xin", "clk_ahb";
280             clocks = <&clkc 22>, <&clkc 33>;
281             interrupt-parent = <&intc>;
282             interrupts = <0 47 4>;
283             reg = <0xe0101000 0x1000>;
284         };
285
286         slcr: slcr@f8000000 {
287             #address-cells = <1>;
288             #size-cells = <1>;
289             compatible = "xlnx,zynq-slcr", "syscon", "simple-bus";
290             reg = <0xF8000000 0x1000>;
291             ranges;
292             clkc: clkc@100 {
293                 #clock-cells = <1>;
294                 compatible = "xlnx,ps7-clkc";
295                 fclk-enable = <0xf>;
296                 clock-output-names = "armpll", "ddrpll", "iopll", "cpu_6or4x",
297                         "cpu_3or2x", "cpu_2x", "cpu_1x", "ddr2x", "ddr3x",
298                         "dci", "lqspi", "smc", "pcap", "gem0", "gem1",
299                         "fclk0", "fclk1", "fclk2", "fclk3", "can0", "can1",
300                         "sdio0", "sdio1", "uart0", "uart1", "spi0", "spi1",
301                         "dma", "usb0_aper", "usb1_aper", "gem0_aper",
302                         "gem1_aper", "sdio0_aper", "sdio1_aper",
303                         "spi0_aper", "spi1_aper", "can0_aper", "can1_aper",
304                         "i2c0_aper", "i2c1_aper", "uart0_aper", "uart1_aper",
305                         "gpio_aper", "lqspi_aper", "smc_aper", "swdt",
306                         "dbg_trc", "dbg_apb";
307                 reg = <0x100 0x100>;
308             };
309
310             rstc: rstc@200 {
311                 compatible = "xlnx,zynq-reset";
312                 reg = <0x200 0x48>;
313                 #reset-cells = <1>;
314                 syscon = <&slcr>;
315             };
316
317             pinctrl0: pinctrl@700 {
318                 compatible = "xlnx,pinctrl-zynq";
319                 reg = <0x700 0x200>;
320                 syscon = <&slcr>;
321             };
322         };
323
324         dmac_s: dmac@f8003000 {
325             compatible = "arm,pl330", "arm,primecell";
326             reg = <0xf8003000 0x1000>;
327             interrupt-parent = <&intc>;
328             interrupt-names = "abort", "dma0", "dma1", "dma2", "dma3",
329                 "dma4", "dma5", "dma6", "dma7";
330             interrupts = <0 13 4>,
331                          <0 14 4>, <0 15 4>,
332                          <0 16 4>, <0 17 4>,
333                          <0 40 4>, <0 41 4>,
334                          <0 42 4>, <0 43 4>;
335             #dma-cells = <1>;
336             #dma-channels = <8>;
337             #dma-requests = <4>;
338             clocks = <&clkc 27>;
339             clock-names = "apb_pclk";
340         };
341
342         devcfg: devcfg@f8007000 {
343             compatible = "xlnx,zynq-devcfg-1.0";
344             interrupt-parent = <&intc>;
345             interrupts = <0 8 4>;
346             reg = <0xf8007000 0x100>;
347             clocks = <&clkc 12>, <&clkc 15>, <&clkc 16>, <&clkc 17>, <&clkc 18>;
348             clock-names = "ref_clk", "fclk0", "fclk1", "fclk2", "fclk3";
349             syscon = <&slcr>;
350         };
351
352         global_timer: timer@f8f00200 {
353             compatible = "arm,cortex-a9-global-timer";
354             reg = <0xf8f00200 0x20>;
355             interrupts = <1 11 0x301>;
356             interrupt-parent = <&intc>;
357             clocks = <&clkc 4>;
358         };
359
360         ttc0: timer@f8001000 {
361             interrupt-parent = <&intc>;
362             interrupts = <0 10 4>, <0 11 4>, <0 12 4>;
363             compatible = "cdns,ttc";
364             clocks = <&clkc 6>;
365             reg = <0xF8001000 0x1000>;
366         };
367
368         ttc1: timer@f8002000 {
369             interrupt-parent = <&intc>;
370             interrupts = <0 37 4>, <0 38 4>, <0 39 4>;
371             compatible = "cdns,ttc";
372             clocks = <&clkc 6>;
373             reg = <0xF8002000 0x1000>;
374         };
375
376         scutimer: timer@f8f00600 {
377             interrupt-parent = <&intc>;
378             interrupts = <1 13 0x301>;
379             compatible = "arm,cortex-a9-twd-timer";
380             reg = <0xf8f00600 0x20>;
381             clocks = <&clkc 4>;
382         };
383
384         usb0: usb@e0002000 {
385             compatible = "xlnx,zynq-usb-2.20a", "chipidea,usb2";
386             status = "disabled";
387             clocks = <&clkc 28>;
388             interrupt-parent = <&intc>;
389             interrupts = <0 21 4>;
390             reg = <0xe0002000 0x1000>;
391             phy_type = "ulpi";
392         };
393
394         usb1: usb@e0003000 {
395             compatible = "xlnx,zynq-usb-2.20a", "chipidea,usb2";
396             status = "disabled";
397             clocks = <&clkc 29>;
398             interrupt-parent = <&intc>;
399             interrupts = <0 44 4>;
400             reg = <0xe0003000 0x1000>;
401             phy_type = "ulpi";
402         };
403
404         watchdog0: watchdog@f8005000 {
405             clocks = <&clkc 45>;
406             compatible = "cdns,wdt-r1p2";
407             interrupt-parent = <&intc>;
408             interrupts = <0 9 1>;
409             reg = <0xf8005000 0x1000>;
410             timeout-sec = <10>;
411         };
412     };
413 };
接下来是对上面定义的节点一些属性的补充。
《zynq.dtsi》
1
  2 /include/ "zynq-7000.dtsi"
  3
  4 /*
  5  * The Xilinx EMACPS and the Cadance GEM drivers are for the same IP core, but
  6  * the drivers are not fully feature compatible. We stay with the Xilinx driver
  7  * for now. The main issue is the lack of support for gmii2rgmii when using the
  8  * Cadance driver.
  9  */
10 &amba {
11     eth: eth@e000b000 {
12         compatible = "xlnx,ps7-ethernet-1.00.a";
13         reg = <0xe000b000 0x1000>;
14         interrupts = <0 22 4>;
16         #address-cells = <0x1>;
17         #size-cells = <0x0>;
18
19         clock-names = "ref_clk", "aper_clk";
20         clocks = <&clkc 13>, <&clkc 30>;
21
22         xlnx,enet-clk-freq-hz = <0x17d7840>;
23         xlnx,enet-reset = "MIO 11";
24         xlnx,enet-slcr-1000mbps-div0 = <0x8>;
25         xlnx,enet-slcr-1000mbps-div1 = <0x1>;
26         xlnx,enet-slcr-100mbps-div0 = <0x8>;
27         xlnx,enet-slcr-100mbps-div1 = <0x5>;
28         xlnx,enet-slcr-10mbps-div0 = <0x8>;
29         xlnx,enet-slcr-10mbps-div1 = <0x32>;
30         xlnx,eth-mode = <0x1>;
31         xlnx,has-mdio = <0x1>;
32         xlnx,ptp-enet-clock = <111111115>;
33     };
34
35 };
36
37 /delete-node/ &gem0;
38 /delete-node/ &gem1;
39
40 / {
41     interrupt-parent = <&intc>;
42
43     aliases: aliases {
44         ethernet0 = ð
45         serial0 = &uart1;
46     };
47 };
48
49 &usb0 {
50     status = "okay";
51     dr_mode = "host"; /* This breaks OTG mode */
52 };
53
54 &uart1 {
55     status = "okay";
56 };
57
58 &sdhci0 {
59     status = "okay";
60 };
接下来是板级节点属性的定义, memory的reg属性表示内存的起始地址是0,大小是0x2000_0000(512M),这正是板子内存大小。
《zynq-zed.dtsi》
1 /include/ "zynq.dtsi"
  2
  3 / {
  4     model = "Xilinx Zynq ZED";
  5     memory {
  6         device_type = "memory";
  7         reg = <0x000000000 0x20000000>;
  8     };
  9
10     chosen {
11 //      bootargs = "console=ttyPS0,115200 root=/dev/ram rw initrd=0x1100000,33M ip=:::::eth0:dhcp earlyprintk";
12         bootargs = "console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait";
13         linux,stdout-path = "/amba@0/uart@E0001000";
14     };
15 };
16
17 &eth {
18     phy-handle = <&phy0>;
19     phy-mode = "rgmii-id";
20
21     phy0: phy@0 {
22         compatible = "marvell,88e1510";
23         device_type = "ethernet-phy";
24         reg = <0x0>;
25         marvell,reg-init=<3 16 0xff00 0x1e 3 17 0xfff0 0x0a>;
26     };
27 };
28
29 &usb0 {
30     xlnx,phy-reset-gpio = <&gpio0 85 0>;
31 };
32
33 &qspi {
34     status = "okay";
35     is-dual = <0>;
36     num-cs = <1>;
37     primary_flash: ps7-qspi@0 {
38         #address-cells = <1>;
39         #size-cells = <1>;
40         compatible = "n25q128a11";
41         reg = <0x0>;
42         spi-max-frequency = <50000000>;
43         partition@0x00000000 {
44             label = "boot";
45             reg = <0x00000000 0x00500000>;
46         };
47         partition@0x00500000 {
48             label = "bootenv";
49             reg = <0x00500000 0x00020000>;
50         };
51         partition@0x00520000 {
52             label = "config";
53             reg = <0x00520000 0x00020000>;
54         };
55         partition@0x00540000 {
56             label = "image";
57             reg = <0x00540000 0x00a80000>;
58         };
59         partition@0x00fc0000 {
60             label = "spare";
61             reg = <0x00fc0000 0x00000000>;
62         };
63     };
64 };
在下来,就是这里使用了hdmi视频和zed board上的音频以及其它外设资源定义了,这些外设使用了PL(program logic资源,即FPGA资源)。
《zynq-zed-adv7511.dtsi》
1 / {
  2     fpga_axi: fpga-axi@0 {
  3         compatible = "simple-bus";
  4         #address-cells = <0x1>;
  5         #size-cells = <0x1>;
  6         ranges;
  7
  8         i2c@41600000 {
  9             compatible = "xlnx,axi-iic-1.01.b", "xlnx,xps-iic-2.00.a";
11             interrupts = <0 58 0x4>;
12             reg = <0x41600000 0x10000>;
13
15             #address-cells = <1>;
16
17             adv7511: adv7511@39 {
18                 compatible = "adi,adv7511";
19                 reg = <0x39>;
20
21                 adi,input-style = <0x02>;
22                 adi,input-id = <0x01>;
23                 adi,input-color-depth = <0x3>;
24                 adi,sync-pulse = <0x03>;
25                 adi,bit-justification = <0x01>;
26                 adi,up-conversion = <0x00>;
27                 adi,timing-generation-sequence = <0x00>;
28                 adi,vsync-polarity = <0x02>;
29                 adi,hsync-polarity = <0x02>;
30                 adi,tdms-clock-inversion;
31                 adi,clock-delay = <0x03>;
32
33                 ports {
34                     #address-cells = <1>;
35                     #size-cells = <0>;
36
37                     port@0 {
38                         reg = <0>;
39                         adv7511_in: endpoint {
40                             remote-endpoint = <&axi_hdmi_out>;
41                         };
42                     };
43
44                     port@1 {
45                         reg = <1>;
46                     };
47                 };
48             };
49
50             adau1761: adau1761@3b {
51                 compatible = "adi,adau1761";
52                 reg = <0x3b>;
53             };
54         };
55
56         axi_vdma_0: axivdma@43000000 {
57             compatible = "xlnx,axi-vdma-1.00.a";
58             #address-cells = <1>;
59             #size-cells = <1>;
60             #dma-cells = <1>;
61             #dma-channels = <1>;
62             reg = <0x43000000 0x1000>;
63             xlnx,num-fstores = <0x3>;
64             dma-channel@43000000 {
65                 compatible = "xlnx,axi-vdma-mm2s-channel";
66                 interrupts = <0 59 0x4>;
67                 xlnx,datawidth = <0x40>;
68                 xlnx,genlock-mode = <0x0>;
69                 xlnx,include-dre = <0x0>;
70             };
71         };
72
73         hdmi_clock: axi-clkgen@79000000 {
74             compatible = "adi,axi-clkgen-2.00.a";
75             reg = <0x79000000 0x10000>;
76             #clock-cells = <0>;
77             clocks = <&clkc 16>;
78         };
79
80         axi_hdmi@70e00000 {
81             compatible = "adi,axi-hdmi-tx-1.00.a";
82             reg = <0x70e00000 0x10000>;
83             dmas = <&axi_vdma_0 0>;
84             dma-names = "video";
85             clocks = <&hdmi_clock>;
86
87             port {
88                 axi_hdmi_out: endpoint {
89                     remote-endpoint = <&adv7511_in>;
90                 };
91             };
92         };
93
94         audio_clock: audio_clock {
95             compatible = "fixed-clock";
96             #clock-cells = <0>;
97             clock-frequency = <12288000>;
98         };
99
100         axi_spdif_tx_0: axi-spdif-tx@0x75c00000 {
101             compatible = "adi,axi-spdif-tx-1.00.a";
102             reg = <0x75c00000 0x1000>;
103             dmas = <&dmac_s 0>;
104             dma-names = "tx";
105             clocks = <&clkc 15>, <&audio_clock>;
106             clock-names = "axi", "ref";
107         };
108
109         adv7511_hdmi_snd: adv7511_hdmi_snd {
110             compatible = "adv7511-hdmi-snd";
111             audio-codec = <&adv7511>;
112             cpu-dai = <&axi_spdif_tx_0>;
113         };
114
115         axi_i2s_0: axi-i2s@0x77600000 {
116             compatible = "adi,axi-i2s-1.00.a";
117             reg = <0x77600000 0x1000>;
118             dmas = <&dmac_s 1 &dmac_s 2>;
119             dma-names = "tx", "rx";
120             clocks = <&clkc 15>, <&audio_clock>;
121             clock-names = "axi", "ref";
122         };
/* 第116行的字段和<sound/soc/adi/axi-i2s.c>的260行相互匹配,reg这个字段在vivado的block design中Address Editor可以看出0x77600000是i2s是基地址,
0x1000是寄存器段的大小,dmas是dma字段,使用了PS端的dmac 1和dmac 2,dmac 0在vivado的设计中并没有设备,所以spdif的驱动并没有注册,这两个dma分别用于发送和
接收,clocks字段第一个是axi接口的时钟,第二个是iis的master时钟,这里就是12.288MHz。 这个IIS 控制器dai,实际上在PL里,但是相对adau1761这些外置dai而言,它们是cpu dai*/
123
124         zed_sound: zed_sound {
125             compatible = "digilent,zed-sound";
126             audio-codec = <&adau1761>;
127             cpu-dai = <&axi_i2s_0>;
128         };
/*这个字段的125行是和<sound/soc/adi/zed_adau1761.c> 的144相呼应的,设备树表示,adau1761将和axi_i2s_0进行音频数据交互,该文件描述了codec侧的dai*/
129     };
130
131     leds {
132         compatible = "gpio-leds";
133         ld0 {
134             label = "ld0:red";
135             gpios = <&gpio0 73 0>;
136         };
137
138         ld1 {
139             label = "ld1:red";
140             gpios = <&gpio0 74 0>;
141         };
142
143         ld2 {
144             label = "ld2:red";
145             gpios = <&gpio0 75 0>;
146         };
147
148         ld3 {
149             label = "ld3:red";
150             gpios = <&gpio0 76 0>;
151         };
152
153         ld4 {
154             label = "ld4:red";
155             gpios = <&gpio0 77 0>;
156         };
157
158         ld5 {
159             label = "ld5:red";
160             gpios = <&gpio0 78 0>;
161         };
162
163         ld6 {
164             label = "ld6:red";
165             gpios = <&gpio0 79 0>;
166         };
167
168         ld7 {
169             label = "ld7:red";
170             gpios = <&gpio0 80 0>;
171         };
172     };
173 };
