用C++实现链表操作,下面就直接上代码:
<span style="font-size:18px;">#include <iostream>
#include <stdlib.h>
using namespace std;
//结点类
class Node {
public:
int data;
Node *pNext;
//单向链表类
class LinkList {
public:
LinkList() {
//头结点不参与计数
head = new Node;
head->data = 0;
head->pNext = NULL;
~LinkList() { delete head; }
void CreateLinkList(int n); //创建链表
void InsertNode(int position, int d); //在指定位置插入结点
void TraverseLinkList(); //遍历链表
bool IsEmpty(); //判断链表是否为空
int GetLength(); //链表长度
void DeleteNode(int position); //删除指定位置结点
void DeleteLinkList(); //删除整个链表
private:
Node *head;
void LinkList::CreateLinkList(int n) {
if (n < 0) {
cout << "输入结点个数错误!" << endl;
exit(EXIT_FAILURE);
else {
Node *pnew, *ptemp;
ptemp = head;
int i = n;
while (n-- > 0) {
pnew = new Node;
cout << "输入第" << i - n << "个结点值:";
cin >> pnew->data;
pnew->pNext = NULL;
ptemp->pNext = pnew;
ptemp = pnew;
//postion从1开始计数,到链表长度加1结束,头结点后的结点称为第一个结点
void LinkList::InsertNode(int position, int d) {
if (position < 0 || position > GetLength() + 1) {
cout << "输入位置错误!" << endl;
exit(EXIT_FAILURE);
else {
Node *pnew, *ptemp;
ptemp = head;
pnew = new Node;
pnew->data = d;
pnew->pNext = NULL;
while (position-- > 1)
ptemp = ptemp->pNext;
pnew->pNext = ptemp->pNext;
void LinkList::TraverseLinkList() {
Node *p = head->pNext;
while (p != NULL) {
cout << p->data << " ";
p = p->pNext;
cout << endl;
bool LinkList::IsEmpty() {
if (head->pNext == NULL)
return true;
else
return false;
int LinkList::GetLength() {
int n = 0;
while (p != NULL) {
n++;
p = p->pNext;
return n;
//position只能从1开始到链表长度结束
void LinkList::DeleteNode(int position) {
if (position < 0 || position > GetLength()) {
exit(EXIT_FAILURE);
else {
Node *ptemp = head, *pdelete;
pdelete = ptemp->pNext;
ptemp->pNext = pdelete->pNext;
delete pdelete;
pdelete = NULL;
void LinkList::DeleteLinkList() {
Node *pdelete = head->pNext, *ptemp;
while(pdelete != NULL) {
ptemp = pdelete->pNext;
head->pNext = ptemp;
delete pdelete;
pdelete = ptemp;
//测试函数
int main() {
LinkList l;
int position = 0, value = 0, n = 0;
bool flag = false;
cout << "请输入需要创建单向链表的结点个数:";
cin >> n;
l.CreateLinkList(n);
cout << "打印链表值如下:";
l.TraverseLinkList();
cout << "请输入插入结点的位置和值:";
cin >> position >> value;
l.InsertNode(position, value);
cout << "打印链表值如下:";
cout << "请输入要删除结点的位置:";
cin >> position;
l.DeleteNode(position);
cout << "打印链表值如下:";
l.DeleteLinkList();
flag = l.IsEmpty();
if (flag)
cout << "删除链表成功!" << endl;
else
cout << "删除链表失败!" << endl;
return 0;
}</span
