1 #include <stdio.h>
2
3 int my_strcmp(const char *str1,const char *str2)
4 {
5 //判断两个字符串是否为空
6 if((str1 == NULL) && (str2 == NULL))
7 {
8 exit(0);
9 }
10 //利用while循环,str1不为零,判定str1的值是否等于str2的值
11 while((*str1) && ((*str1==*str2)))
12 {
13 str1++;
14 str2++;
15 }
16
17 //如果str1大于str2,第一字符串大于第二个字符串
18 if(*(unsigned char *)str1 > *(unsigned char *)str2)
19 {
20 printf("The first string is greater than the second string\n");
21 return 1;
22 }
23 //如果str1小于str2,第一个字符串小于第二个字符串
24 else if(*(unsigned char *)str1 < *(unsigned char *)str2)
25 {
26 printf("The first string is less than the second string\n");
27 return -1;
28 }
29 //如果循环完成,str1等于str2,那么这两个字符串相等
30 else
31 {
32 printf("Two strings are equal\n");
33 return 0;
34 }
35
36 }
37 int main(int argc, char *argv[])
38 {
39 char a[]="hfllo45";
40 char b[]="hello45";
41
42 my_strcmp(a,b);
43
44 return 0;
45 }
