电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 【STM32Nucleo-C031C6样片开发】室内人数统计
共24条 1/3 1 2 3 › 跳转至页
2023-03-13 21:18:54     打赏
不得不说,STM32C031C6T6这个芯片很赞,在同价位芯片来说性能还是非常好的,而且编程方便,使用stm32CubeMx即可完成配置,完成了各个基本功能的测试。
在配置串口时,我使用了内部晶振,打开串口中断,实现PC端与开发板的通信功能。
#define LED_ON()         HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_SET);
#define LED_OFF()            HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_RESET);
uint8_t Tx_star1[] = "hello world!\r\n";
uint8_t Tx_star2[] ="led open\r\n";
uint8_t Tx_star3[] ="led off\r\n";
uint8_t Rx_dat = 0;
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
    if(huart->Instance == USART2)
            if(Rx_dat == 0xa1)
            LED_ON();
            HAL_UART_Transmit(&huart2,Tx_star2,sizeof(Tx_star2),10000);
            HAL_UART_Receive_IT(&huart2,&Rx_dat,1);
            else  if(Rx_dat == 0xa2)
                LED_OFF();
                HAL_UART_Transmit(&huart2,Tx_star3,sizeof(Tx_star3),10000);
                HAL_UART_Receive_IT(&huart2,&Rx_dat,1);            }
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_USART2_UART_Init();
  MX_USART1_UART_Init();
  /* USER CODE BEGIN 2 */
    LED_ON();
    HAL_UART_Transmit(&huart2,Tx_star1,sizeof(Tx_star1),10000);
    LED_OFF();
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
本来想上云来着,但是本人技术问题,搞了很久还没连上,只能在后续补上;做了一个关于室内人数统计的小功能,可以实现屋里进出人数以及室内人数统计;首先须要OLED的移植,SPI通信的OLED非常好移植,只需要配置相应的管脚就好:
随后将中景园的代码移植更改,同样只需要更改引脚定义的函数就好:
void OLED_Init()
	GPIO_InitTypeDef GPIO_InitStruct;
	__HAL_RCC_GPIOB_CLK_ENABLE();
	//CS
	GPIO_InitStruct.Pin = OLED_CS_GPIO_PIN;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_PULLUP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  HAL_GPIO_Init(OLED_CS_GPIO, &GPIO_InitStruct);
	//DC
	GPIO_InitStruct.Pin = OLED_DC_GPIO_PIN;
  HAL_GPIO_Init(OLED_DC_GPIO, &GPIO_InitStruct);
	//SCLK
	GPIO_InitStruct.Pin = OLED_SCLK_GPIO_PIN;
  HAL_GPIO_Init(OLED_SCLK_GPIO, &GPIO_InitStruct);
	//SDIN
	GPIO_InitStruct.Pin = OLED_SDIN_GPIO_PIN;
  HAL_GPIO_Init(OLED_SDIN_GPIO, &GPIO_InitStruct);
	HAL_GPIO_WritePin(OLED_CS_GPIO, OLED_CS_GPIO_PIN, GPIO_PIN_SET);
 	HAL_GPIO_WritePin(OLED_DC_GPIO, OLED_DC_GPIO_PIN, GPIO_PIN_SET);
	HAL_GPIO_WritePin(OLED_SCLK_GPIO, OLED_SCLK_GPIO_PIN, GPIO_PIN_SET);
	HAL_GPIO_WritePin(OLED_SDIN_GPIO, OLED_SDIN_GPIO_PIN, GPIO_PIN_SET);
	//RESET THE OLED
 	#if 0
  OLED_RST_Set();
	delay_ms(100);
	OLED_RST_Clr();
	delay_ms(100);
	OLED_RST_Set();
	#endif
	OLED_WR_Byte(0xAE,OLED_CMD);//--turn off oled panel
	OLED_WR_Byte(0x02,OLED_CMD);//---set low column address
	OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
	OLED_WR_Byte(0x40,OLED_CMD);//--set start line address  Set Mapping RAM Display Start Line (0x00~0x3F)
	OLED_WR_Byte(0x81,OLED_CMD);//--set contrast control register
	OLED_WR_Byte(0xCF,OLED_CMD); // Set SEG Output Current Brightness
	OLED_WR_Byte(0xA1,OLED_CMD);//--Set SEG/Column Mapping     0xa0左右反置 0xa1正常
	OLED_WR_Byte(0xC8,OLED_CMD);//Set COM/Row Scan Direction   0xc0上下反置 0xc8正常
	OLED_WR_Byte(0xA6,OLED_CMD);//--set normal display
	OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
	OLED_WR_Byte(0x3f,OLED_CMD);//--1/64 duty
	OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset	Shift Mapping RAM Counter (0x00~0x3F)
	OLED_WR_Byte(0x00,OLED_CMD);//-not offset
	OLED_WR_Byte(0xd5,OLED_CMD);//--set display clock divide ratio/oscillator frequency
	OLED_WR_Byte(0x80,OLED_CMD);//--set divide ratio, Set Clock as 100 Frames/Sec
	OLED_WR_Byte(0xD9,OLED_CMD);//--set pre-charge period
	OLED_WR_Byte(0xF1,OLED_CMD);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
	OLED_WR_Byte(0xDA,OLED_CMD);//--set com pins hardware configuration
	OLED_WR_Byte(0x12,OLED_CMD);
	OLED_WR_Byte(0xDB,OLED_CMD);//--set vcomh
	OLED_WR_Byte(0x40,OLED_CMD);//Set VCOM Deselect Level
	OLED_WR_Byte(0x20,OLED_CMD);//-Set Page Addressing Mode (0x00/0x01/0x02)
	OLED_WR_Byte(0x8D,OLED_CMD);//--set Charge Pump enable/disable
	OLED_WR_Byte(0x14,OLED_CMD);//--set(0x10) disable
	OLED_WR_Byte(0xA4,OLED_CMD);// Disable Entire Display On (0xa4/0xa5)
	OLED_WR_Byte(0xA6,OLED_CMD);// Disable Inverse Display On (0xa6/a7)
	OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
	OLED_WR_Byte(0xAF,OLED_CMD); /*display ON*/
	OLED_Clear();
	OLED_Set_Pos(0,0);
配合两个光电开关就可以实现进入和离开室内的功能判断了,然后就是代码中最核心的逻辑代码:
void READ_PRO()
    if(in_sign==1)
       enter_flag = 1;
    if((enter_flag==1)&&(out_sign==1))//进入
       while(out_sign==1);
       enter_flag=0;
       also_have++;
       enter_namber++;
    if(out_sign == 1)
       out_flag = 1;
    if((out_flag==1)&&(in_sign==1))//离开
       while(in_sign==1);
       out_flag = 0;
       also_have--;
       out_number++;
将所有的数据显示在OLED上:
void oled_display()
    OLED_ShowCHinese(0,0,0);//进
    OLED_ShowCHinese(18,0,1);//入
    OLED_ShowCHinese(0,3,2);//离
    OLED_ShowCHinese(18,3,3);//开
    OLED_ShowCHinese(0,6,4);//室
    OLED_ShowCHinese(18,6,5);//内
    OLED_ShowNum(36,0,enter_namber,3,16);
    OLED_ShowNum(36,3,out_number,3,16);
    OLED_ShowNum(36,6,also_have,3,16);
这个功能可以统计室内人数,以及进出入的总次数,至于连接云端,后期会继续更新的。
2023-03-13 22:49:01     打赏
看看
2023-03-14 00:10:51     打赏
2023-03-14 01:31:45     打赏
感谢楼主的分享,很实用了。
2023-03-14 01:31:58     打赏
感谢楼主的分享,很实用了。
2023-03-14 02:21:10     打赏
感谢楼主分享
2023-03-14 07:41:41     打赏
2023-03-14 07:57:30     打赏
感谢楼主分享
2023-03-14 08:00:40     打赏
2023-03-14 08:06:09     打赏
感谢楼主的分享,很实用了。
