【前言】
我的工程目的是使用手势传感器来实现无接触的控制,所以驱动PAJ7620U2为首要任务。在前面我已经 驱动好的oled屏的前提下,添加手势传感的驱动。
【I2C读写函数的封装】
因为有多个i2c的读写,所以在github上面找到了一个库,修改以后可以实现i2c的单、多数据的写入,多数据的读取。
其代码如下:
#include "i2c_app.h"
#define I2CT_FLAG_TIMEOUT         ((uint32_t)0x1000)
#define I2CT_LONG_TIMEOUT         ((uint32_t)(10 * I2CT_FLAG_TIMEOUT))
static __IO uint32_t  I2CTimeout = I2CT_LONG_TIMEOUT;
uint8_t i2c_app_write (I2C_Regs *i2c, uint8_t addr, uint8_t reg, uint8_t *dat, uint8_t len)
    DL_I2C_fillControllerTXFIFO(i2c, ®, 1);
    DL_I2C_fillControllerTXFIFO(i2c, dat, len);
    I2CTimeout = I2CT_FLAG_TIMEOUT;
    while (!(DL_I2C_getControllerStatus(i2c) & DL_I2C_CONTROLLER_STATUS_IDLE)) if ((I2CTimeout--) == 0) return 1;
    DL_I2C_startControllerTransfer(i2c, addr, DL_I2C_CONTROLLER_DIRECTION_TX, len + 1);
    while (DL_I2C_getControllerStatus(i2c) & DL_I2C_CONTROLLER_STATUS_BUSY_BUS) if ((I2CTimeout--) == 0) return 2;
    if (DL_I2C_getControllerStatus(i2c) & DL_I2C_CONTROLLER_STATUS_ERROR) return 1;
    while (!(DL_I2C_getControllerStatus(i2c) & DL_I2C_CONTROLLER_STATUS_IDLE)) if ((I2CTimeout--) == 0) return 3;
    return 0;
uint8_t i2c_app_read (I2C_Regs *i2c, uint8_t addr, uint8_t reg, uint8_t *dat, uint8_t len)
    DL_I2C_startControllerTransfer(i2c, addr, DL_I2C_CONTROLLER_DIRECTION_TX, 1);
//    DL_I2C_startControllerTransferAdvanced(i2c, addr, DL_I2C_CONTROLLER_DIRECTION_TX, 1,
//                                           I2C_MCTR_START_ENABLE, I2C_MCTR_STOP_DISABLE, I2C_MCTR_ACK_ENABLE);
        DL_I2C_CONTROLLER_STATUS_ERROR) {
        /* LED will remain high if there is an error */
        __BKPT(0);
    /* Wait for I2C to be Idle */
    while (!(
    /* Add delay between transfers */
    delay_cycles(1000);
    DL_I2C_startControllerTransfer(i2c, addr, DL_I2C_CONTROLLER_DIRECTION_RX, len);
    for (uint8_t i = 0; i < len; i++)
        while (DL_I2C_isControllerRXFIFOEmpty(i2c)) if ((I2CTimeout--) == 0) return 3;
        dat[i] = DL_I2C_receiveControllerData(i2c);
    return 0;
}i2capp.h如下:
#ifndef I2C_APP_H #define I2C_APP_H #include "ti_msp_dl_config.h" uint8_t i2c_app_read (I2C_Regs *i2c, uint8_t addr, uint8_t reg, uint8_t *dat, uint8_t len); uint8_t i2c_app_write (I2C_Regs *i2c, uint8_t addr, uint8_t reg, uint8_t *dat, uint8_t len); #endif
封装好后,只需要传感i2c序号,写入从机的地址(为7bit地址),buf的地址,以及buf的长度。
将其加入到工程之中:
【PAJ7620驱动】
根据i2c的驱动封装,我这里只需要修改PAJ7620如下几个函数的代码,即可以完成:
function:
	I2C Write and Read
static void DEV_I2C_WriteByte(I2C_Regs * PAJ7620U2_I2C,uint8_t add_, uint8_t data_)
	uint8_t Buf[1] = {0};
	Buf[0] = data_;
	i2c_app_write(I2C1, 0x73, add_,Buf, 2);
static void DEV_I2C_WriteWord(I2C_Regs * PAJ7620U2_I2C,uint8_t add_, uint16_t data_)
	uint8_t Buf[2] = {0};
	Buf[0] = data_ >> 8;
	Buf[1] = data_;
static uint8_t DEV_I2C_ReadByte(I2C_Regs * PAJ7620U2_I2C,uint8_t add_)
    uint8_t state;
	uint8_t Buf[1];
	Buf[0] = add_;
	state = i2c_app_read(I2C1, 0x73, add_,Buf, 1);
	if(state == 0)
	    return Buf[0];
	else
	    return state;
static uint16_t DEV_I2C_ReadWord(I2C_Regs * PAJ7620U2_I2C,uint8_t add_)
    uint8_t Buf[2]={0, 0};
    i2c_app_read(I2C1, 0x73, add_,Buf, 2);
    return ((Buf[1] << 8) | (Buf[0] & 0xff));
}这样就可以成功的驱动他了,接上逻辑分析仪,捕获到数据为读写正常的:
在主程序中添加测试代码:
#include "\drivers\PAJ7620U2.h"
#include "\oled\oled.h"
int main(void)
    SYSCFG_DL_init();
    /* Set LED to indicate start of transfer */
    OLED_Init();
    OLED_Clear();
    OLED_ShowString(0,0,"hello world",16,1);
    OLED_Refresh_Gram();
    uint8_t OBJ_BRIGHTNESS = 0;      // Object Brightness (Max. 255)
    uint16_t OBJ_SIZE = 0;               // Object Size (Max. 900)
    uint16_t ID = PAJ7620U2_init(I2C1);
    /* If write and read were successful, toggle LED */
    while (1) {
        delay_cycles(1000);
        OLED_Clear();
        OBJ_BRIGHTNESS = PAJ7620U2_PS_ReadObjBrightness(I2C1);    // Object Brightness (Max. 255)
        OBJ_SIZE = PAJ7620U2_PS_ReadObjSize(I2C1);                            // Object Size (Max. 900)
        OLED_Printf(0,0,16,1,"BRIGHT:%d",OBJ_BRIGHTNESS);
        OLED_Printf(0,24,16,1,"OBJ_SIZE:%d",OBJ_SIZE);
}下载程序后,未测检到手势时的数值:
手靠近到传感器的数据:
到此说明手势传感器驱动正常。
 我要赚赏金 STM32
STM32 MCU
MCU 通讯及无线技术
通讯及无线技术 物联网技术
物联网技术 电子DIY
电子DIY 板卡试用
板卡试用 基础知识
基础知识 软件与操作系统
软件与操作系统 我爱生活
我爱生活 小e食堂
小e食堂
