电子产品世界 » 论坛首页 » 嵌入式开发 » 国产MCU » 【Mini-F5265-OB】硬件SPI驱动ST7735OLED屏
共9条 1/1 1 跳转至
2025-01-04 09:23:27   被打赏 35 分(兑奖)     打赏
这篇跟大家分享如何使用硬件SPI驱动LCD屏。
【硬件环境】
1、灵动Mini-F5265-OB 开发板
2、ST7735LCD屏
【连接方式】
1 GND       GND
2 3.3V      VCC
3 PA5      SCL
4 PA7      SDA
7 PA4      CS
5 PA1      RES
6 PA3      DC
8 VCC      BL
【代码实现】
1、开发板的示例提供了基于flash的代码,他使用了硬件片选的功能,因为ST7735相比Flash示例,多了两个引脚即数据/命令脚DC,复位RES(其中的背光我这里直连VCC),因此我对LCD的硬件初始如下:
void LcdIoInit(void)
      GPIO_InitTypeDef GPIO_InitStruct;
    SPI_InitTypeDef  SPI_InitStruct;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
    SPI_StructInit(&SPI_InitStruct);
    SPI_InitStruct.SPI_Mode      = SPI_Mode_Master;
    SPI_InitStruct.SPI_DataSize  = SPI_DataSize_8b;
    SPI_InitStruct.SPI_DataWidth = 8;
    SPI_InitStruct.SPI_CPOL      = SPI_CPOL_Low;
    SPI_InitStruct.SPI_CPHA      = SPI_CPHA_1Edge;
    SPI_InitStruct.SPI_NSS       = SPI_NSS_Soft;
    SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
    SPI_InitStruct.SPI_FirstBit  = SPI_FirstBit_MSB;
    SPI_Init(SPI1, &SPI_InitStruct);
    SPI_BiDirectionalLineConfig(SPI1, SPI_Enable_RX);
    SPI_BiDirectionalLineConfig(SPI1, SPI_Enable_TX);
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource4, GPIO_AF_5);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_5);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource6, GPIO_AF_5);
    GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_5);
    GPIO_StructInit(&GPIO_InitStruct);
    GPIO_InitStruct.GPIO_Pin   = GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_7 ;
    GPIO_InitStruct.GPIO_Speed = GPIO_Speed_High;
    GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStruct);
    GPIO_InitStruct.GPIO_Pin   = GPIO_Pin_6;
    GPIO_InitStruct.GPIO_Mode  = GPIO_Mode_IPU;
        SPI_Cmd(SPI1, ENABLE);
    //初始化复位、数据引脚
    GPIO_InitStruct.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_3;
    GPIO_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP;
初始化这里要特别提一句,如果分频系数过大会造成与LCD通信对不上,我最起先使用256分频,结果点不亮,查找原因好久,后面使用64分频就亮了。
2、接着修改驱动中的写入数据、写命令:
void LCD_Writ_Bus(uint8_t dat)
  SPI_SendData(SPI1, dat);
    while (RESET == SPI_GetFlagStatus(SPI1, SPI_FLAG_TXEPT))
void LCD_WR_DATA8(uint8_t dat)
    SPI_FLASH_CS_L();
    LCD_DC_HIGH();//дÊý¾Ý
    LCD_Writ_Bus(dat);
    SPI_FLASH_CS_H();
void LCD_WR_DATA(uint16_t dat)
    SPI_FLASH_CS_L();
    LCD_Writ_Bus(dat>>8);
    LCD_Writ_Bus(dat);
    SPI_FLASH_CS_H();
void LCD_WR_REG(uint8_t  dat)
    SPI_FLASH_CS_L();
    LCD_DC_LOW();//дÃüÁî
    LCD_Writ_Bus(dat);
    SPI_FLASH_CS_H();
4、当然我还需要声明一些宏命令:
#define SPI_FLASH_CS_H() SPI_CSInternalSelected(SPI1, DISABLE)
#define SPI_FLASH_CS_L() SPI_CSInternalSelected(SPI1, ENABLE)
#define LCD_DC_LOW()       GPIO_WriteBit(GPIOA, GPIO_Pin_3, Bit_RESET)
#define LCD_DC_HIGH()      GPIO_WriteBit(GPIOA, GPIO_Pin_3, Bit_SET)
#define LCD_RES_LOW()      GPIO_WriteBit(GPIOA, GPIO_Pin_1, Bit_RESET)
#define LCD_RES_HIGH()     GPIO_WriteBit(GPIOA, GPIO_Pin_1, Bit_SET)
这样我们的代码移植就完成了。(注:代码我附)
image.png附工程源码:
My_st7735.zip
关键词: Mini-F5265-OB     ST7735
2025-01-04 10:27:11     打赏
2025-01-04 11:11:04     打赏
2025-01-04 11:12:35     打赏
2025-01-04 19:39:30     打赏
图片居然有QQ的标志性头像。
这年代感~~
2025-01-08 10:30:46     打赏
感谢分享!
2025-03-01 11:35:28     打赏
复现时报错。
2025-03-31 08:39:16     打赏
感谢分享!
2025-04-11 21:42:02     打赏
共享代码,互相学习,赞!
共9条 1/1 1 跳转至
