电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » A question of SNMP and MIB..........
共9条 1/1 1 跳转至
2005-10-14 01:01:21     打赏
I use WindManage to develop SNMP
I have built my private MIB, such as "test.mib" file.
And i have include it into WindManage.
I can see it in WindManage IDE, but i can not see it in MIB browser.
WindManage has built windmarks vars of "test.mib" automatically.
Why?
Or i miss other steps?
Or i need to write code?
And how i get information form Vxworks to the private MIB OID?
My scope are as follows:
1.it can show the private MIB tree in MIB browser.
2.it can show the values in private MIB tree in MIB browser, such as IP address.
(How can i get the MIB OID values from Vxworks?)
I hope somebody can help me...........thanks a lot.
关键词: question     MIB..........
2005-10-17 07:48:00     打赏
MIB OID is global variable, you must buy it. And if you want to see the oid in mib brower, u must add the mib in the mib browser.
2005-10-17 16:50:00     打赏
Thank you for your reply.
I just try to build private MIB for testing and i also put my private MIB in MIB browser.
Now, i am working hard to trace source code and study windmanager MIBway IDE to know how
to get the device values form hardware and shows the values and OID in MIB browser.
I hope i can get something in there.
2005-10-17 20:41:00     打赏
Just put breakpoint into you get/set function, you can trace the windmanage snmp. According my pinion, the windmanage supplies the source code.
2005-10-18 00:41:00     打赏
I think my problem is not at MIB browser.
I describe my working steps to you......
1.I use MIB complier (MG-SOFT) to build my private MIB------>success.
2.Then i use wind manage to load my private MIB into my image file------->success.
3.I can see MIB tree (MIB2+private MIB) in wind manage MIBway IDE.
4.I put private MIB into MG-SOFT.
5.I use MIB browser(MG-SOFT) to connect my device.
6.Then i use SNMP walk to trace all MIB tree.
7.It can only see and get the MIB2 tree and values, but my private MIB can not show on the screen----->failure.
Today i study and trace the source code, i think i do not implement the private MIB agent for SNMP........now i keeps tracking hardly.
Or you have another opinions..........
I would very glad to listen to you.
2005-10-18 01:39:00     打赏
Do you generate the leaf and mib C file using mibcomp in WindManage ?
If you did this, you should also realize the function of you mib just as the get/set!
And then add you leaf/mib C file into you project.
2005-10-18 22:27:00     打赏
Today i have read Wind manage SNMP tutorial Doc.
And i follow the steps of this Doc(writting your own MIB).
I have build mib.c and leaf.h and stub.c and skel.h
and do some modifications which is descrided in Doc.
Complier is OK.
But when i use MIB browser to view my MIB tree.
It can not connect my device, Why? (It can connect my device,before.....)
community string read/write default is set as "public/private", it always show the "TIMEOUT" message.
And i can not view my MIB tree, Why?
2005-10-18 23:09:00     打赏
I have solved this problem.....
I remove the API function( initStartSnmp( ) ) from usrAppInit.c
It can connect to my device,already.
But i still can not see my private MIB tree in my MIB browser (MG-Soft).
WHY?........
I have bilut my private MIB and port image to device.
And i also modify and implement the agent program (tutEx_getproc,tutEx_setproc,tutEx_nextproc,tutEx_testproc )
and assign the init values to my private MIB.
2005-10-21 03:16:00     打赏
After i download the latest documents, but it still has some errors.
I modify the makefile.cfg in scr/wrn/wm/snmp/vxagent(document has some errors).
Finally, i succeed.
I can see the private MIB tree in MIB browser.
The problems is in the steps of makefile and makefile.cfg.
Now, i will try to trace and research agent code.
Then i will want to implement my private MIB agent.
And i also want to thank for these people that have some opinions to me.
共9条 1/1 1 跳转至
