unsigned,int 【求助】宏定义时溢出,想用unsigned int,怎么办?
问
有如下一句定义:
#define TIMER_A_50 (750*50) // 50ms
程序中有:
CCR0 = TIMER_A_50; // 50ms
IAR C/C++ Compiler for MSP430
V3.20A/W32 [Kickstart] (3.20.1.3)
编译器报警告:
Warning[Pe061]: integer operation result is out of range
Warning[Pe068]: integer conversion resulted in a change of sign
而实际上750*50=37500 < 65535,实在是不解,怎么解决此问题呢? 答 1: 1种情况:
当改为#define TIMER_A_50 (37500) // 50ms
编译没有警告了。
2种情况:
改为CCR0 = 750*50; // 50ms
警告依然存在。
3种情况:
改为CCR0 = 37500; // 50ms
没有警告出现。
现在演变成给unsigned int数赋值时750*50就二条警告,而直接用37500就正常,
WHY?谁给个合理的解释?
我用是编译器是:
IAR Assembler for MSP430
V3.20A/W32 (3.20.1.9)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\bin\a430.exe
2004-6-15 15:59:34, 491520 bytes
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\bin\icc430.exe
2004-6-15 15:58:08, 5623808 bytes
IAR Build
4.3 (4.3.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\iarbuild.exe
2004-6-10 9:20:26, 14848 bytes
IAR Embedded Workbench IDE
4.3 (4.3.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\iaridepm.exe
2004-6-9 22:39:20, 729088 bytes
IAR Library Builder
1.03K (1.3.11.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\xar.exe
2004-6-9 17:31:22, 98304 bytes
IAR XLIB
3.29H/386 (3.29.0.8)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\xlib.exe
2004-6-9 17:31:22, 421888 bytes
IAR XLINK
4.59A (4.59.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\xlink.exe
2004-6-4 16:18:44, 1183744 bytes
IAR CSpyBat
4.3 (4.3.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\cspybat.exe
2004-6-9 20
02, 131072 bytes
IAR Project File Converter for MSP430
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\bin\cwtd430.dll
2004-6-16 8
32, 352256 bytes
IAR Workbench Target Descriptor for MSP430
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\bin\swtd430.dll
2004-6-22 15:10:52, 507904 bytes
IAR C-SPY Batch Simulator Driver for MSP430
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\bin\430bat.dll
2004-6-18 9:51:22, 118784 bytes
IAR C-SPY Library Support Plug-in for MSP430
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\bin\430libsupport.dll
2004-6-18 9:51:38, 225280 bytes
IAR C-SPY Processor Descriptor for MSP430
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\bin\430proc.dll
2004-6-21 11:36:00, 1036288 bytes
IAR C-SPY Simulator Driver for MSP430
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\bin\430sim.dll
2004-6-23 18:49:20, 692224 bytes
IAR Workbench Target Descriptor, Simulator, for MSP430
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\bin\swtd430sim.dll
2004-6-22 15
32, 155648 bytes
IAR C-SPY Emulator Driver for MSP430
V3.20D/W32 [Kickstart] (3.20.4.3)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\bin\430fet.dll
2004-8-3 20:34:06, 507904 bytes
HIL
1, 0, 1, 2 (1.0.1.2)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\bin\hil.dll
2004-3-3 15:58:18, 28672 bytes
MSP430
1, 1, 4, 6 (1.1.4.6)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\bin\JLink430.dll
2004-6-23 14:44:54, 25600 bytes
MSP430
1, 1, 6, 5 (1.1.6.5)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\bin\MSP430.dll
2004-7-30 9:50:18, 53248 bytes
IAR Workbench Target Descriptor, Emulator, for MSP430
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\bin\swtd430fet.dll
2004-6-22 15
04, 204800 bytes
LCD Plugin
3.20A (3.2.0.1)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\plugins\Lcd\lcd.dll
2004-6-21 11:18:10, 118784 bytes
Stack Plugin
2.31A (2.3.1.1)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\430\plugins\Stack\stack.dll
2004-6-17 9:36:24, 184320 bytes
IAR Find In Files
4.3 (4.3.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\findinfiles.dll
2004-6-10 9
50, 49152 bytes
IAR IDE Framework
4.3 (4.3.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\ideframework.dll
2004-6-9 19:29:52, 335872 bytes
IAR Log Window
4.3 (4.3.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\logwindow.dll
2004-6-10 9:05:02, 131072 bytes
MFCDLL Shared Library - Retail Version
7.10.3077.0 (7.10.3077.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\mfc71.dll
2004-6-10 9:28:00, 1060864 bytes
Microsoft? C++ Runtime Library
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\msvcp71.dll
2004-6-10 9:28:02, 499712 bytes
Microsoft? C Runtime Library
7.10.3052.4 (7.10.3052.4)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\msvcr71.dll
2004-6-10 9:28:04, 348160 bytes
IAR Project Manager Engine
4.3 (4.3.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\projectmanagerengine.dll
2004-6-9 22:28:42, 827392 bytes
IAR Project Manager Gui
4.3 (4.3.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\projectmanagergui.dll
2004-6-9 22:52:22, 520192 bytes
IAR Text Editor
4.3 (4.3.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\texteditor.dll
2004-6-9 21:18:38, 327680 bytes
Shared Library for Xerces-C Version 1.5.1
1, 5, 1 (1.5.1.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\xerces-c_1_5_1.dll
2004-6-9 18:40:50, 1175552 bytes
IAR C-SPY Debugger GUI
4.3 (4.3.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\debuggergui.dll
2004-6-11 14:39:20, 819200 bytes
IAR C-SPY Debugger Kernel
4.3 (4.3.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\bin\kernel.dll
2004-6-11 12:22:28, 1015808 bytes
IAR Code Coverage Plug-in
4.3 (4.3.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\plugins\CodeCoverage\codecoverage.dll
2004-6-9 19:57:48, 167936 bytes
IAR Profiling Plug-in
4.3 (4.3.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\plugins\Profiling\profiling.dll
2004-6-9 21:00:58, 155648 bytes
IAR Trace Plug-in
4.3 (4.3.0.0)
C:\Program Files\IAR Systems\Embedded Workbench 4.0\common\plugins\Trace\trace.dll
2004-6-9 21:27:08, 233472 bytes 答 2: 怎么就没人给个合理的解释啊 答 3: 哈,很明显,赋值前,750×50是作为有符号整数来计算,当然溢出了,改为750u×50u(强制为无符号)就是无符号的计算了,一切OK。。。。
有如下一句定义:
程序中有:
编译器报警告:
编译没有警告了。
2种情况:
警告依然存在。
3种情况:
没有警告出现。
WHY?谁给个合理的解释?
我用是编译器是:
IAR Build
4.3 (4.3.0.0)
4.3 (4.3.0.0)
IAR Library Builder
1.03K (1.3.11.0)
IAR XLIB
IAR XLINK
4.59A (4.59.1.0)
IAR CSpyBat
4.3 (4.3.0.0)
2004-6-9 20
02, 131072 bytesIAR Project File Converter for MSP430
2004-6-16 8
32, 352256 bytesIAR Workbench Target Descriptor for MSP430
2004-6-22 15
32, 155648 bytesIAR C-SPY Emulator Driver for MSP430
HIL
MSP430
MSP430
2004-6-22 15
04, 204800 bytesLCD Plugin
3.20A (3.2.0.1)
Stack Plugin
2.31A (2.3.1.1)
IAR Find In Files
4.3 (4.3.0.0)
2004-6-10 9
50, 49152 bytesIAR IDE Framework
4.3 (4.3.0.0)
IAR Log Window
4.3 (4.3.0.0)
4.3 (4.3.0.0)
4.3 (4.3.0.0)
IAR Text Editor
4.3 (4.3.0.0)
1, 5, 1 (1.5.1.0)
4.3 (4.3.0.0)
4.3 (4.3.0.0)
4.3 (4.3.0.0)
4.3 (4.3.0.0)
IAR Trace Plug-in
4.3 (4.3.0.0)
