Analog,IC,Design,Engineer Analog IC Design Engineer
问
Job Responsibilities
Duties will include working within a Product Development Team to create (design, layout, and evaluate) new circuit architectures, and to modify existing circuit architectures, verify functionality of designs, prepare and present Design Reviews to internal groups and external customers, write technical reports, attend technical conferences in the areas of data storage and advanced IC design. Specific responsibilities include:
- Communicate effectively within a global business environment (must be proficient in both spoken and written English).
- Perform transistor level, analog and mixed signal integrated circuit design of various cells and blocks within custom chips for the hard disk drive industry. Examples of some blocks are: voltage regulators, bandgap circuits, data converters (DAC, ADS), low noise amplifiers, line drivers, multipliers, temperature sensing circuits, filters, operational amplifiers, variable gain amplifiers, control logic, serial port controller.
- Support the integration of all cells and blocks into a completed integrated circuit
- Work directly with customers to determine the system requirements, write specifications, and guide them on the use of our preamplifier products.
- Conduct detailed design reviews of cell and block level circuits.
- Perform design validation thru simulation with Cadence software.
- Use highspeed electronic characterization equipment to evaluate and debug the functionality of the silicon
- Perform transistor level and block level layout (physical design).
- Provide technical support and guidance to a cross functional team of engineers thru all phases of product development which includes: test, yield, characterization, reliability analysis, qualification, and release to manufacturing.
- Adhering to schedule, die size, and power commitments.
Functional/Industry Knowledge
Required:
- Minimum of 1-3 years Analog IC Design experience in a product development environment
- Proven Analog IC Design skills
- Proven experimental skills and lab/bench expertise
- Strong written and verbal communication skills
Desired:
- Past experience in a lead position giving guidance to other engineers
Education/Certifications
Required Degree: BS
Preferred Degree: MS
Preferred Major: Electrical Engineering or related discipline
MSN:shzhang2006@yahoo.com.cn
E-mail:shzhang2006@yahoo.com.cn 答 1: 在上海的 答 2: 能不能给新人一些机会我做软件4年,很想做IC设计,从来没做过,很感兴趣,能不能给个机会啊 答 3: 实在不好意思我们这里是猎头,只找符合客户要求的,所以,不好意思! 答 4: 要求不低啊呵呵,提到的那些模块,能做精一个就很了不起了
呵呵 答 5: ...嘿嘿
刚开始做模拟不久,还算新人,YY一下啦 答 6: 呵呵我研究生是读IC设计的 还算新手 答 7: 只要有工作经验的至少要3年经验,如果硕士及以上学历2年,也可以考虑。
Required:
Desired:
Required Degree: BS
呵呵 答 5: ...嘿嘿
| 【FreeRtos】FreeRtos + MPU模块的配置使用被打赏¥32元 | |
| 【分享开发笔记,赚取电动螺丝刀】墨水屏文本显示器被打赏¥25元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX读取磁力计iis2mdc被打赏¥19元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX读取LPS22HH气压、温度被打赏¥19元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX读取STTS751温度被打赏¥17元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX软件读取HTS221温湿度被打赏¥22元 | |
| M5PAPERESP32EINKDEVKIT评测|使用MicroPython开发M5Paper被打赏¥15元 | |
| OK1126B-S开发板下以导航按键控制云台/机械臂姿态调整被打赏¥29元 | |
| 【树莓派5】便携热成像仪被打赏¥36元 | |
| 【树莓派5】环境监测仪被打赏¥35元 | |
