电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 24号的作业本KEIL 的安装
共13条 2/2 ‹ 1 2 跳转至页
2014-12-25 23:14:30     打赏
11楼
  1. #include "stm32f10x.h"
  2. #include "stm32_eval.h"
  3. #include
  4. #include "spi_flash.h"
  5. #define VREF 3.3
  6.
  7. void delay_us(u32 n)
  8. {
  9.     u8 j;
  10.     while(n--)
  11.     for(j=0;j<10;j++);
  12. }
  13.
  14. void  delay_ms(u32 n)
  15. {
  16.     while(n--)
  17.     delay_us(1000);
  18. }
  19.
  20.
  21. #define TxBufferSize1   (countof(TxBuffer1) - 1)
  22. #define RxBufferSize1   (countof(TxBuffer1) - 1)
  23. #define countof(a)      (sizeof(a) / sizeof(*(a)))
  24. #define  BufferSize (countof(Tx_Buffer)-1)
  25. typedef enum { FAILED = 0, PASSED = !FAILED} TestStatus;
  26. #define  FLASH_WriteAddress     0x00000
  27. #define  FLASH_ReadAddress      FLASH_WriteAddress
  28. #define  FLASH_SectorToErase    FLASH_WriteAddress
  29. #define  sFLASH_ID              0xEF3015     //W25X16
  30. //#define  sFLASH_ID              0xEF4015   //W25Q16
  31. #define buff_size  16;
  32. char rx_buff[],rx_buff_count=0;
  33. /* ???????? */
  34. uint8_t Tx_Buffer[4096] ;
  35. uint8_t Rx_Buffer[BufferSize];
  36. __IO uint32_t DeviceID = 0;
  37. __IO uint32_t FlashID = 0;
  38. __IO TestStatus TransferStatus1 = FAILED;
  39.
  40. // ??????
  41. void Delay(__IO uint32_t nCount);
  42. TestStatus Buffercmp(uint8_t* pBuffer1, uint8_t* pBuffer2, uint16_t BufferLength);
  43.
  44. /** @addtogroup STM32F10x_StdPeriph_Examples
  45.   * @{
  46.   */
  47.
  48. /** @addtogroup EXTI_Config
  49.   * @{
  50.   */
  51.
  52. /* Private typedef -----------------------------------------------------------*/
  53. /* Private define ------------------------------------------------------------*/
  54. /* Private macro -------------------------------------------------------------*/
  55. /* Private variables ---------------------------------------------------------*/
  56. GPIO_InitTypeDef   GPIO_InitStructure;
  57. USART_InitTypeDef USART_InitStructure;
  58. USART_ClockInitTypeDef USART_ClockInitStructure;
  59.
  60. char *int_to_string(int number,char *strnum)//整形数据转换为字符型
  61. {
  62. int j=0,i=0,n=0;
  63. char temp;
  64. while(number>0)
  65. {
  66. *(strnum+j)=number%10+48;
  67. j++;
  68. number=number/10;
  69. n++;
  70. }
  71.
  72.
  73. for(i=0;iLibraries->Small printf
  74.      set to 'Yes') calls __io_putchar() */
  75.   #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
  76. #else
  77.   #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
  78. #endif /* __GNUC__ */
  79.
  80.
  81.
  82. /**
  83.   * @brief  Retargets the C library printf function to the USART.
  84.   * @param  None
  85.   * @retval None
  86.   */
  87. PUTCHAR_PROTOTYPE
  88. {
  89.   /* Place your implementation of fputc here */
  90.   /* e.g. write a character to the USART */
  91.   USART_SendData(EVAL_COM1, (uint8_t) ch);
  92.
  93.   /* Loop until the end of transmission */
  94.   while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  95.   {}
  96.
  97.   return ch;
  98. }
  99.
  100. #ifdef  USE_FULL_ASSERT
  101.
  102. /**
  103.   * @brief  Reports the name of the source file and the source line number
  104.   *         where the assert_param error has occurred.
  105.   * @param  file: pointer to the source file name
  106.   * @param  line: assert_param error line source number
  107.   * @retval None
  108.   */
  109. void assert_failed(uint8_t* file, uint32_t line)
  110. {
  111.   /* User can add his own implementation to report the file name and line number,
  112.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  113.
  114.   /* Infinite loop */
  115.   while (1)
  116.   {
  117.   }
  118. }
  119.
  120. #endif
2014-12-25 23:25:08     打赏
12楼
  3. GPIO_InitTypeDef GPIO_InitStructure;    //??GPIO???
  4.
  5. NVIC_InitTypeDef  NVIC_InitStructure;
  6. USART_InitTypeDef  USART_InitStructure;
  7. USART_ClockInitTypeDef  USART_ClockInitStructure;
  8.
  9. #define buff_size  16;
  10. char rx_buff[],rx_buff_count=0;
  11.
  12. /*???? ??*/
  13. void delay_us(u32 n)
  14. {
  15.     u8 j;
  16.     while(n--)
  17.     for(j=0;j<10;j++);
  18. }
  19. /*???? ??*/
  20. void  delay_ms(u32 n)
  21. {
  22.    while(n--)
  23.     delay_us(1000);
  24. }
  25.
  26. void RCC_Configuration(void)
  27. {
  28.     RCC_DeInit();
  29.     RCC_HSICmd(ENABLE);
  30.     while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  31.     RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  32.     RCC_HSEConfig(RCC_HSE_OFF);
  33.     RCC_LSEConfig(RCC_LSE_OFF);
  34.     RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  35.     RCC_PLLCmd(ENABLE);
  36.     while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  37.     RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  38.     RCC_PCLK2Config(RCC_HCLK_Div1);
  39.     RCC_PCLK1Config(RCC_HCLK_Div2);
  40.     RCC_HCLKConfig(RCC_SYSCLK_Div1);
  41.     RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  42.     while(RCC_GetSYSCLKSource() != 0x08);
  43.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  44.     GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
  45.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  46.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  47.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  48.     GPIO_Init(GPIOD, &GPIO_InitStructure);
  49.     GPIO_ResetBits(GPIOD,GPIO_Pin_2);                      //?????
  50. }
  51.
  52. void USART_SendStr(char *str)      //???????
  53. {
  54.    while((*str)!='\0')             //???????
  55.         {USART_SendData(USART1,*str++);
  56.         while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
  57.         }
  58. }
  59.
  60. void USART_int(long BaudRate)       //USART??
  61. {
  62.       RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//??PA?USART1
  63.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;               //PA^9??TX_D1
  64.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  65.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;          //??????
  66.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  67.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;               //PA^10??RX_D1
  68.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;     //????
  69.     GPIO_Init(GPIOA, &GPIO_InitStructure);
  70.
  71.     USART_InitStructure.USART_BaudRate = BaudRate;//????
  72.     USART_InitStructure.USART_WordLength = USART_WordLength_8b;//??8bit
  73.     USART_InitStructure.USART_StopBits = USART_StopBits_1;      //???1
  74.     USART_InitStructure.USART_Parity = USART_Parity_No;//????
  75.     USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;  //???none
  76.     USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;                  //???????
  77.       USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  78.     USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  79.     USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  80.     USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
  81.     USART_ClockInit(USART1, &USART_ClockInitStructure);           //???USART1??
  82.     USART_Init(USART1, &USART_InitStructure);                    //???USART1
  83.     USART_Cmd(USART1, ENABLE);
  84.       USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  85.     USART_Cmd(USART1, ENABLE);
  86.
  87.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);       //??4????
  88.         NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;     //??USART1????
  89.         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;
  90.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  91.         NVIC_Init(&NVIC_InitStructure);                       //?????
  92. }
  93.
  94. void GPIO_INIT()
  95. {
  96.     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);  //RCC_APB2Periph_GPIOC  ??GPIOX???      ENABLE\DISABLE   ??or??
  97.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//??:????PC^0-7
  98.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;         //??:????
  99.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;          //??:Out_PP????,????,??
  100.     GPIO_Init(GPIOC, &GPIO_InitStructure);
  101. }
  102.
  103. unsigned int my_atoi(char* pstr) //???:????????
  104. {
  105.       int s = 0;
  106.         while(*pstr != '\0')        //??????????????
  107.         {
  108.                 if(*pstr >= '0' && *pstr <= '9')  //????????0-9???
  109.                 {
  110.                         s = s * 10 + *pstr - '0';
  111.                 }
  112.                 pstr++;
  113.         }
  114.     return s;
  115. }
  116.
  117.
  118.
  119.
  120.
  121. int main()
  122. {
  123.         RCC_Configuration();
  124.       GPIO_INIT();
  125.         USART_int(9600);
  126.         USART_SendStr("Please input like: data=\r\n");
  127.         USART_SendStr("\n>");
  128.         while(1){
  129.                 }
  130. }
  131.
  132. void USART1_IRQHandler(void)
  133. {
  134.   while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET)
  135.   {
  136.   }
  137.
  138.   USART_ClearFlag(USART1, USART_FLAG_RXNE);
  139.
  140. }
2015-01-06 21:33:13     打赏
13楼
有待提高和深入啊
共13条 2/2 ‹ 1 2 跳转至页
