电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 只有两个文件的mini型GUI试玩
只有两个文件的mini型GUI试玩
2017-11-27 16:28:37     打赏
这款GUI名称是uGUI, 官网:uGUI
源码: ugui v0.3.zip
官网展示的效果图都还不错。贴几张:
在emWIN的模拟器上来运行这个GUI:
将两个文件添加到工程,ugui.c ugui.h
在ugui.h进行修改:
  1、屏蔽include "system.h"
  2、
#if 0
#define __UG_CONST   const
typedef uint8_t      UG_U8;
typedef int8_t       UG_S8;
typedef uint16_t     UG_U16;
typedef int16_t      UG_S16;
typedef uint32_t     UG_U32;
typedef int32_t      UG_S32;
#else
typedef unsigned char         UG_U8;
typedef signed char           UG_S8;
typedef unsigned short          UG_U16;
typedef signed short            UG_S16;
typedef unsigned int     UG_U32;
typedef signed int       UG_S32;
#endif
进行GUI的初始化:
	for uGUI
UG_GUI  test_uGUI;
void __draw_pixel(UG_S16 x, UG_S16 y, UG_COLOR color)
	GUI_SetColor(color);
	GUI_DrawPixel(x, y);
	end
void MainTask(void) {
	WM_HWIN hWin;
#ifdef WIN32
//	WM_SetCreateFlags(WM_CF_MEMDEV);
#endif
	WM_MOTION_Enable(1);
	WM_MULTIBUF_Enable(1);
	GUI_Init();
	UG_Init(&test_uGUI, __draw_pixel, 480, 272);      // initialize uGUI
	UG_SetForecolor(GUI_RED);
	UG_DrawCircle(100, 100, 50, GUI_RED);             // draw a circle to test uGUI
	UG_FontSelect(&FONT_6X8);
	UG_PutString(50, 170, "I'm uGUI");
	GUI_SetColor(GUI_RED);
	GUI_DrawCircle(230, 100, 50);                     // compare with uGUI
	GUI_DispStringAt("I'm emWin",180, 170);
	while (1)
		GUI_Delay(50);
运行效果:
有兴趣的可以玩玩。
关键词: ugui     minigui
