这款GUI名称是uGUI, 官网:uGUI
源码: ugui v0.3.zip
官网展示的效果图都还不错。贴几张:
在emWIN的模拟器上来运行这个GUI:
将两个文件添加到工程,ugui.c ugui.h
在ugui.h进行修改:
1、屏蔽include "system.h"
2、
#if 0 #define __UG_CONST const typedef uint8_t UG_U8; typedef int8_t UG_S8; typedef uint16_t UG_U16; typedef int16_t UG_S16; typedef uint32_t UG_U32; typedef int32_t UG_S32; #else #define __UG_CONST const typedef unsigned char UG_U8; typedef signed char UG_S8; typedef unsigned short UG_U16; typedef signed short UG_S16; typedef unsigned int UG_U32; typedef signed int UG_S32; #endif
进行GUI的初始化:
for uGUI
UG_GUI test_uGUI;
void __draw_pixel(UG_S16 x, UG_S16 y, UG_COLOR color)
GUI_SetColor(color);
GUI_DrawPixel(x, y);
end
void MainTask(void) {
WM_HWIN hWin;
#ifdef WIN32
// WM_SetCreateFlags(WM_CF_MEMDEV);
#endif
WM_MOTION_Enable(1);
WM_MULTIBUF_Enable(1);
GUI_Init();
UG_Init(&test_uGUI, __draw_pixel, 480, 272); // initialize uGUI
UG_SetForecolor(GUI_RED);
UG_DrawCircle(100, 100, 50, GUI_RED); // draw a circle to test uGUI
UG_FontSelect(&FONT_6X8);
UG_PutString(50, 170, "I'm uGUI");
GUI_SetColor(GUI_RED);
GUI_DrawCircle(230, 100, 50); // compare with uGUI
GUI_DispStringAt("I'm emWin",180, 170);
while (1)
GUI_Delay(50);
}运行效果:
有兴趣的可以玩玩。
