The MST56XXB series is a high input voltage (60V), low quiescent current, High PSRR linear regulator (LDO) able to provide 150mA load current. The LDO features very fast response against line voltage transient and load current transient, and ensures no overshoot voltage during the LDO start up and short circuit recovery. The device features integrated short-circuit and thermal shutdown protection. The device is available with fixed output voltages of 3.0V, 3.3V, 3.6V and 5.0V, and available in SOT23 and SOT89 packages. Application Ø Battery-powered equipment Ø Smoke detector and sensor Ø Micro controller Applications Ø Home Appliance Features Ø Low Quiescent Current:2uA Ø High Input Voltage Rating:Up to 80V Ø Output Current:150mA Ø High PSRR:70dB at 1Khz Ø Dropout Voltage:70mV@10mA 700mV@100mA Ø Fixed Output Voltages:3.0V, 3.3V, 3.6V and 5.0V Ø High-accuracy Output Voltage: ±2% Ø Good Transient Response Ø Integrated Short-Circuit Protection Ø Integrated Thermal Protection Ø Available Packages: MST56XXBTE MST56XXBTE-A MST56XXBTE-B MST56XXBTE-C SOT23-3 MST56XXBTS MST56XXBTS-A MST56XXBTS-B MST56XXBTS-C SOT89-3 MST56XXBTGSOT23-5 |
共3条
分享一个干货!!一个强大的60v高输入电压ldomst56xxb
只看楼主 1楼
关键词: mst56xxb 高输入 电压 60v
MST56XXB系列是一种高输入电压(60V),低静态电流,高PSRR线性稳压器(LDO)能够提供150毫安的负载电流。LDO具有对线电压瞬态和负载电流瞬态响应非常快的特点,并确保在LDO启动和短路恢复过程中没有过冲电压。该装置具有集成短路和热关机保护功能。该器件有3.0V、3.3V、3.6V和5.0V的固定输出电压,并有SOT23和SOT89封装。
应用
Ø电池供电设备
Ø烟雾探测器和传感器
Ø微控制器应用
Ø家用电器
特征
Ø低静态电流:2uA
Ø高输入电压额定值:高达80V
Ø输出电流:150mA
Ø高功率抑制比:1Khz时为70dB
Ø跌落电压:70毫伏@10毫安100毫安时为700毫伏
Ø固定输出电压:3.0V、3.3V、3.6V、5.0V
Ø高精度输出电压:±2%
Ø良好的瞬态响应
Ø集成短路保护
Ø综合热保护
共3条
有奖活动 | |
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! |
