电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 用gnu编译没问题,diab编译bootrom却产生语法错误? 哪个兄弟指点一下
2008-02-27 23:48:47     打赏
dcc -Xmake-dependency -Xincfile-missing-ignore -w -tARMLS:vxworks55 -W:c:,-Xmismatch-warni
ng=2 -ew1554,1551,1552,1086,1047,1547 -Xclib-optim-off -Xansi -Xstrings-in-text=0 -Wa,-Xse
mi-is-newline -ei1516,1643,1604 -Xlocal-data-area-static-only -XO -Xsize-opt -Xmemory-is-v
olatile -Xlint -I\h   -I. -IC:\Tornado2.2\target\config\all -IC:\Tornado2.2\target\h -IC:\
Tornado2.2\target\src\config -IC:\Tornado2.2\target\src\drv -DCPU=ARMARCH4 -DTOOL_FAMILY=d
iab -DTOOL=diab -DARMEL -Wcomment -DCPU_920T -DARMMMU=ARMMMU_920T -DARMCACHE=ARMCACHE_920T
   s3c2410xIntrCtl.c s3c2410xSio.c s3c2410xTimer.c sysLib.c sysSerial.c C:\Tornado2.2\targ
et\config\all\bootConfig.c C:\Tornado2.2\target\config\all\bootInit.c C:\Tornado2.2\target
\config\all\dataSegPad.c C:\Tornado2.2\target\config\all\usrConfig.c C:\Tornado2.2\target\
config\all\version.c > depend.ts2410
dcc -E -Xpreprocessor-lineno-off -Xmake-dependency -w -tARMLS:vxworks55 -E -Wa,-Xlit-auto-
off -I\h   -I. -IC:\Tornado2.2\target\config\all -IC:\Tornado2.2\target\h -IC:\Tornado2.2\
target\src\config -IC:\Tornado2.2\target\src\drv -DCPU=ARMARCH4 -DTOOL_FAMILY=diab -DTOOL=
diab -DARMEL -Wcomment -DCPU_920T -DARMMMU=ARMMMU_920T -DARMCACHE=ARMCACHE_920T romInit.s
>> depend.ts2410
diab -DARMEL -Wcomment -DCPU_920T -DARMMMU=ARMMMU_920T -DARMCACHE=ARMCACHE_920T sysALib.s
>> depend.ts2410
wtxtcl C:\Tornado2.2\host\src\hutils\bspDepend.tcl depend.ts2410
dcc -c -tARMLS:vxworks55 -W:c:,-Xmismatch-warning=2 -ew1554,1551,1552,1086,1047,1547 -Xcli
b-optim-off -Xansi -Xstrings-in-text=0 -Wa,-Xsemi-is-newline -ei1516,1643,1604 -Xlocal-dat
a-area-static-only -XO -Xsize-opt -Xmemory-is-volatile -Xlint -I\h   -I. -IC:\Tornado2.2\t
arget\config\all -IC:\Tornado2.2\target\h -IC:\Tornado2.2\target\src\config -IC:\Tornado2.
2\target\src\drv -DCPU=ARMARCH4 -DTOOL_FAMILY=diab -DTOOL=diab -DARMEL -Wcomment -DCPU_920
T -DARMMMU=ARMMMU_920T -DARMCACHE=ARMCACHE_920T    C:\Tornado2.2\target\config\all\bootIni
t.c
dcc -tARMLS:vxworks55 -W:c:,-Xmismatch-warning=2 -ew1554,1551,1552,1086,1047,1547 -Xclib-o
ptim-off -Xansi -Xstrings-in-text=0 -Wa,-Xsemi-is-newline -ei1516,1643,1604 -Xlocal-data-a
rea-static-only -XO -Xsize-opt -Xmemory-is-volatile -I\h   -I. -IC:\Tornado2.2\target\conf
ig\all -IC:\Tornado2.2\target\h -IC:\Tornado2.2\target\src\config -IC:\Tornado2.2\target\s
rc\drv -DCPU=ARMARCH4 -DTOOL_FAMILY=diab -DTOOL=diab -DARMEL -Wcomment -DCPU_920T -DARMMMU
=ARMMMU_920T -DARMCACHE=ARMCACHE_920T -Xpreprocess-assembly -Wa,-Xlit-auto-off -c  -c -o r
omInit.o romInit.s
"romInit.s", line 3595: error: syntax error
"romInit.s", line 3596: error: syntax error
"romInit.s", line 3597: error: syntax error
"romInit.s", line 3599: error: syntax error
"romInit.s", line 3600: error: syntax error
"romInit.s", line 3601: error: syntax error
"romInit.s", line 3602: error: syntax error
"romInit.s", line 3603: error: syntax error
"romInit.s", line 3604: error: syntax error
"romInit.s", line 3606: error: syntax error
"romInit.s", line 3607: error: syntax error
"romInit.s", line 3608: error: syntax error
"romInit.s", line 3609: error: syntax error
"romInit.s", line 3610: error: syntax error
"romInit.s", line 3611: error: syntax error
"romInit.s", line 3614: error: syntax error
"romInit.s", line 3615: error: syntax error
"romInit.s", line 3616: error: syntax error
"romInit.s", line 3617: error: syntax error
"romInit.s", line 3618: error: syntax error
"romInit.s", line 3619: error: syntax error
"romInit.s", line 3622: error: syntax error
"romInit.s", line 3623: error: syntax error
"romInit.s", line 3624: error: syntax error
"romInit.s", line 3625: error: syntax error
"romInit.s", line 3626: error: syntax error
"romInit.s", line 3627: error: syntax error
"romInit.s", line 3630: error: syntax error
"romInit.s", line 3631: error: syntax error
"romInit.s", line 3632: error: syntax error
"romInit.s", line 3633: error: syntax error
"romInit.s", line 3634: error: syntax error
"romInit.s", line 3635: error: syntax error
"romInit.s", line 3638: error: syntax error
"romInit.s", line 3639: error: syntax error
"romInit.s", line 3640: error: syntax error
"romInit.s", line 3641: error: syntax error
"romInit.s", line 3642: error: syntax error
"romInit.s", line 3643: error: syntax error
"romInit.s", line 3646: error: syntax error
"romInit.s", line 3647: error: syntax error
"romInit.s", line 3648: error: syntax error
"romInit.s", line 3649: error: syntax error
"romInit.s", line 3650: error: syntax error
"romInit.s", line 3651: error: syntax error
"romInit.s", line 3654: error: syntax error
"romInit.s", line 3655: error: syntax error
"romInit.s", line 3656: error: syntax error
"romInit.s", line 3657: error: syntax error
"romInit.s", line 3658: error: syntax error
"romInit.s", line 3659: error: syntax error
"romInit.s", line 3660: error: syntax error
"romInit.s", line 3661: error: syntax error
"romInit.s", line 3662: error: syntax error
program C:\Tornado2.2\host\diab\WIN32\bin\das terminated
make.exe: *** [romInit.o] Error 0x1
Done.
所有错误提示均指向rominit.s文件的尾部,而尾部是注释
请问diab语法与gnu语法有什么不同,请碰到此问题的朋友指点一下
关键词: 编译     没问题     bootrom     产生     语法     错误
