#include <reg52.H>
#define uint unsigned int
#define uchar unsigned char
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar num,aa;
sbit kc=P3^7;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void main()
num=0;
while(1)
kc=1;
P2=aa++;
P0=table[num++];
kc=0;
num=num%16;
delay(5000);
测试AT2402可正常工作程序:
#include<reg52.h>
sbit sda=P1^2;
sbit scl=P1^1;
sbit wp=P1^0;
uchar a;
void delay()
void start() //开始信号
sda=1;
delay();
scl=1;
delay();
sda=0;
delay();
void stop() //停止
sda=0;
delay();
scl=1;
delay();
sda=1;
delay();
void respons() //应答
uchar i;
scl=1;
delay();
while((sda==1)&&(i<250))i++;
scl=0;
delay();
void init()
sda=1;
delay();
scl=1;
delay();
void write_byte(uchar date)
uchar i,temp;
temp=date;
for(i=0;i<8;i++)
temp=temp<<1;
scl=0;
delay();
sda=CY;
delay();
scl=1;
delay();
scl=0;
delay();
sda=1;
delay();
uchar read_byte()
uchar i,k;
scl=0;
delay();
sda=1;
delay();
for(i=0;i<8;i++)
scl=1;
delay();
k=(k<<1)|sda;
scl=0;
delay();
return k;
void delay1(uint x)
uint a,b;
for(a=x;a>0;a--)
for(b=350;b>0;b--);
void write_add(uchar address,uchar date)
start();
write_byte(0xae);
respons();
write_byte(address);
respons();
write_byte(date);
respons();
stop();
uchar read_add(uchar address)
uchar date;
start();
write_byte(0xae);
respons();
respons();
start();
write_byte(0xaf);
respons();
date=read_byte();
stop();
return date;
void main()
uchar i;
i=0;
init();
while(1)
if(i>=16)
i=0;
wp=0;
write_add(23,table[i++]);
delay1(200);
P0=read_add(23);
wp=1;
delay1(10000);
通过测试18B20可以正常工作
#include<REG52.H>
#include<math.h>
#include<INTRINS.H>
sbit DQ=P1^3;//ds18b20 端口
sfr dataled=0x80;//显示数据端口
uchar temp;
uchar flag_get,count,num,minute,second;
uchar code tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//7段数码管段码表共阴
uchar str[3];
void delay1(uchar MS);
unsigned char ReadTemperature(void);
void Init_DS18B20(void);
unsigned char ReadOneChar(void);
void WriteOneChar(unsigned char dat);
void delay(unsigned int i);
main()
TMOD|=0x01;//定时器设置
TH0=0xef;
TL0=0xf0;
IE=0x82;
TR0=1;
P2=0x00;
count=0;
while(1)
str[2]=0x39;//显示C符号
str[0]=tab[temp/10]; //十位温度
str[1]=tab[temp%10]; //个位温度
if(flag_get==1) //定时读取当前温度
temp=ReadTemperature();
flag_get=0;
void tim(void) interrupt 1 using 1//中断,用于数码管扫描和温度检测间隔
TH0=0xef;//定时器重装值
TL0=0xf0;
num++;
if (num==50)
{num=0;
flag_get=1;//标志位有效
second++;
if(second>=60)
{second=0;
minute++;
count++;
if(count==1)
{P2=0;
dataled=str[0];}//数码管扫描
if(count==2)
{P2=1;
dataled=str[1];}
if(count==3)
{ P2=2;
dataled=str[2];
count=0;}
void delay(unsigned int i)//延时函数
while(i--);
//18b20初始化函数
unsigned char x=0;
DQ = 1; //DQ复位
delay(8); //稍做延时
DQ = 0; //单片机将DQ拉低
delay(480); //精确延时 大于 480us
DQ = 1; //拉高总线
delay(10);
x=DQ; //稍做延时后 如果x=0则初始化成功 x=1则初始化失败
delay(160);
//读一个字节
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
DQ = 0; // 给脉冲信号
dat>>=1;
DQ = 1; // 给脉冲信号
if(DQ)
dat|=0x80;
delay(40);
return(dat);
//写一个字节
unsigned char i=0;
for (i=8; i>0; i--)
DQ = 0;
DQ = dat&0x01;
delay(40);
DQ = 1;
dat>>=1;
delay(40);
//读取温度
unsigned char a=0;
unsigned char b=0;
unsigned char t=0;
//float tt=0;
Init_DS18B20();
WriteOneChar(0xCC); // 跳过读序号列号的操作
WriteOneChar(0x44); // 启动温度转换
delay(300);
Init_DS18B20();
WriteOneChar(0xCC); //跳过读序号列号的操作
WriteOneChar(0xBE); //读取温度寄存器等(共可读9个寄存器) 前两个就是温度
a=ReadOneChar();
b=ReadOneChar();
b<<=4;
b+=(a&0xf0)>>4;
t=b;
return(t);
