NRF24L01 驱动函数
const u8 TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //发送地址
const u8 RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //发送地址
//初始化24L01的IO口
void NRF24L01_Init(void)
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_NRF24L01_CE, ENABLE); //使能GPIO的时钟
GPIO_InitStructure.GPIO_Pin = NRF24L01_CE; //NRF24L01 模块片选信号
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIO_NRF24L01_CE, &GPIO_InitStructure);
RCC_APB2PeriphClockCmd(RCC_NRF24L01_CSN, ENABLE); //使能GPIO的时钟
GPIO_InitStructure.GPIO_Pin = NRF24L01_CSN;
GPIO_Init(GPIO_NRF24L01_CSN, &GPIO_InitStructure);
Set_NRF24L01_CE; //初始化时先拉高
Set_NRF24L01_CSN; //初始化时先拉高
//配置NRF2401的IRQ
GPIO_InitStructure.GPIO_Pin = NRF24L01_IRQ;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU ; //上拉输入
GPIO_Init(GPIO_NRF24L01_IRQ, &GPIO_InitStructure);
GPIO_SetBits(GPIO_NRF24L01_IRQ,NRF24L01_IRQ);
SPI2_Init(); //初始化SPI
Clr_NRF24L01_CE; //使能24L01
Set_NRF24L01_CSN; //SPI片选取消
//上电检测NRF24L01是否在位
//写5个数据然后再读回来进行比较,相同时返回值:0,表示在位;否则返回1,表示不在位
u8 NRF24L01_Check(void)
u8 buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5};
u8 buf1[5];
u8 i;
NRF24L01_Write_Buf(SPI_WRITE_REG+TX_ADDR,buf,5);//写入5个字节的地址.
NRF24L01_Read_Buf(TX_ADDR,buf1,5); //读出写入的地址
for(i=0;i<5;i++)if(buf1[i]!=0XA5)break;
if(i!=5)return 1; //NRF24L01不在位
return 0; //NRF24L01在位
//通过SPI写寄存器
u8 NRF24L01_Write_Reg(u8 regaddr,u8 data)
u8 status;
Clr_NRF24L01_CSN; //使能SPI传输
status =SPI2_ReadWriteByte(regaddr); //发送寄存器号
SPI2_ReadWriteByte(data); //写入寄存器的值
Set_NRF24L01_CSN; //禁止SPI传输
return(status); //返回状态值
//读取SPI寄存器值 ,regaddr:要读的寄存器
u8 NRF24L01_Read_Reg(u8 regaddr)
u8 reg_val;
reg_val=SPI2_ReadWriteByte(0XFF);//读取寄存器内容
return(reg_val); //返回状态值
//在指定位置读出指定长度的数据
//*pBuf:数据指针
//返回值,此次读到的状态寄存器值
u8 NRF24L01_Read_Buf(u8 regaddr,u8 *pBuf,u8 datalen)
u8 status,u8_ctr;
status=SPI2_ReadWriteByte(regaddr); //发送寄存器值(位置),并读取状态值
for(u8_ctr=0;u8_ctr<datalen;u8_ctr++)pBuf[u8_ctr]=SPI2_ReadWriteByte(0XFF);//读出数据
Set_NRF24L01_CSN; //关闭SPI传输
return status; //返回读到的状态值
//在指定位置写指定长度的数据
//*pBuf:数据指针
//返回值,此次读到的状态寄存器值
u8 NRF24L01_Write_Buf(u8 regaddr, u8 *pBuf, u8 datalen)
u8 status,u8_ctr;
status = SPI2_ReadWriteByte(regaddr); //发送寄存器值(位置),并读取状态值
for(u8_ctr=0; u8_ctr<datalen; u8_ctr++)SPI2_ReadWriteByte(*pBuf++); //写入数据
//启动NRF24L01发送一次数据
//txbuf:待发送数据首地址
//返回值:发送完成状况
u8 NRF24L01_TxPacket(u8 *txbuf)
u8 state;
Clr_NRF24L01_CE;
NRF24L01_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//写数据到TX BUF 32个字节
Set_NRF24L01_CE; //启动发送
while(READ_NRF24L01_IRQ!=0); //等待发送完成
state=NRF24L01_Read_Reg(STATUS); //读取状态寄存器的值
NRF24L01_Write_Reg(SPI_WRITE_REG+STATUS,state); //清除TX_DS或MAX_RT中断标志
if(state&MAX_TX) //达到最大重发次数
NRF24L01_Write_Reg(FLUSH_TX,0xff); //清除TX FIFO寄存器
return MAX_TX;
if(state&TX_OK) //发送完成
return TX_OK;
return 0xff; //其他原因发送失败
//启动NRF24L01发送一次数据
//txbuf:待发送数据首地址
//返回值:0,接收完成;其他,错误代码
u8 NRF24L01_RxPacket(u8 *rxbuf)
u8 state;
if(state&RX_OK) //接收到数据
NRF24L01_Read_Buf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//读取数据
NRF24L01_Write_Reg(FLUSH_RX,0xff); //清除RX FIFO寄存器
return 0;
return 1; //没收到任何数据
//该函数初始化NRF24L01到RX模式
//设置RX地址,写RX数据宽度,选择RF频道,波特率和LNA HCURR
//当CE变高后,即进入RX模式,并可以接收数据了
void RX_Mode(void)
Clr_NRF24L01_CE;
NRF24L01_Write_Buf(SPI_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH);//写RX节点地址
NRF24L01_Write_Reg(SPI_WRITE_REG+EN_AA,0x01); //使能通道0的自动应答
NRF24L01_Write_Reg(SPI_WRITE_REG+EN_RXADDR,0x01);//使能通道0的接收地址
NRF24L01_Write_Reg(SPI_WRITE_REG+RF_CH,40); //设置RF通信频率
NRF24L01_Write_Reg(SPI_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//选择通道0的有效数据宽度
NRF24L01_Write_Reg(SPI_WRITE_REG+RF_SETUP,0x0f); //设置TX发射参数,0db增益,2Mbps,低噪声增益开启
NRF24L01_Write_Reg(SPI_WRITE_REG+CONFIG, 0x0f); //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式
Set_NRF24L01_CE; //CE为高,进入接收模式
//该函数初始化NRF24L01到TX模式
//设置TX地址,写TX数据宽度,设置RX自动应答的地址,填充TX发送数据,选择RF频道,波特率和LNA HCURR
//PWR_UP,CRC使能
//CE为高大于10us,则启动发送.
void TX_Mode(void)
Clr_NRF24L01_CE;
NRF24L01_Write_Buf(SPI_WRITE_REG+TX_ADDR,(u8*)TX_ADDRESS,TX_ADR_WIDTH); //写TX节点地址
NRF24L01_Write_Buf(SPI_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH); //设置TX节点地址,主要为了使能ACK
NRF24L01_Write_Reg(SPI_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址
NRF24L01_Write_Reg(SPI_WRITE_REG+SETUP_RETR,0x1a);//设置自动重发间隔时间:500us + 86us;最大自动重发次数:10次
NRF24L01_Write_Reg(SPI_WRITE_REG+RF_CH,40); //设置RF通道为40
NRF24L01_Write_Reg(SPI_WRITE_REG+CONFIG,0x0e); //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式,开启所有中断
Set_NRF24L01_CE; //CE为高,10us后启动发送
【有奖活动】分享技术经验,兑换京东卡 | |
话不多说,快进群! | |
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
打赏了!打赏了!打赏了! |
打赏帖 | |
【换取逻辑分析仪】-基于ADI单片机MAX78000的简易MP3音乐播放器被打赏48分 | |
我想要一部加热台+树莓派PICO驱动AHT10被打赏38分 | |
【换取逻辑分析仪】-硬件SPI驱动OLED屏幕被打赏36分 | |
换逻辑分析仪+上下拉与多路选择器被打赏29分 | |
Let'sdo第3期任务合集被打赏50分 | |
换逻辑分析仪+Verilog三态门被打赏27分 | |
换逻辑分析仪+Verilog多输出门被打赏24分 | |
【分享评测,赢取加热台】使用8051单片机驱动WS2812被打赏40分 | |
【换取逻辑分析仪】rtthread添加RRH62000传感器驱动-基于野火启明6M5被打赏48分 | |
换逻辑分析仪+Verilog多输入门被打赏27分 |
