电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » 1-Wire® Master Device Configuration
2012-04-03 23:16:29     打赏
关键词: 1-Wire Master, IEEE 1451.4, XML, DS2430A, auto-configure
Abstract: The 'family-code' embedded in the lasered ROM number of each 1-Wire device signifies a specific device type. Since each device type has different features and commands, it is imperative the 1-Wire master knows how to translate this 'family-code' into the correct commands. This document presents a method to dynamically configure the 1-Wire master to correctly communicate with a previously unknown 1-Wire device type by providing the 1-Wire master with an XML configuration file. This document was originally created to support the IEEE® 1451.4 A Smart Transducer Interface for Sensors and Actuators—Mixed-Mode Communication Protocols and Transducer Electronic Data Sheet (TEDS) Formats standards committee.
 1-Wire® Master Device Configuration.pdf
关键词: 1-Wire     Master     Device     Conf
