电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Understanding and Configuring the DS2483
Understanding and Configuring the DS2483 1-Wire® Master
2012-04-04 12:02:59     打赏
关键词: 1-wire master, I²C, level translator, 1wire, I2C
Abstract: The DS2483 represents the next generation of integrated 1-Wire masters. With its configurability, 2-stage power-savings mode, and level translator function, the DS2483 is well suited for battery-operated applications. This application note explains the operation of the 1-Wire master port, gives advice on when to deviate from the default configurations, and explains how to determine the drive capability for a given network.
  Understanding and Configuring the DS2483 1-Wire® Master.pdf
关键词: Understanding     Configuring
