在STM32的初始化文件中看到一段说明:
- For Low, Medium and High density Value line devices an external 8MHz
crystal is used to drive the System clock.
- For Low, Medium and High density devices an external 8MHz crystal is
- For Connectivity line devices an external 25MHz crystal is used to drive
the System clock.
If you are using different crystal you have to adapt those functions accordingly.
请问一下:High density Value line device 和Connectivity line device 这两个有什么区别?是什么意思啊?
