电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » How to Interpret DS1852 Temperature and
How to Interpret DS1852 Temperature and Voltage Readings
2012-04-13 17:42:50     打赏
关键词: DS1852, temperature and voltage, temperature measurement, voltage measurement
Abstract: The DS1852 is a digital potentiometer with five analog inputs that can be used in conjunction with the potentiometers to gather feedback information about an analog system, as well as provide analog control functions. Its intended application is to provide a high level of control and instrumentation in a laser transceiver, but it could be used in any sort of control system where this kind of instrumentation and control is required. This application brief discusses the interpretation of the analog input registers in the DS1852. It is intended as a supplement to the data sheet for a software/firmware developer writing code to control the DS1852.
 How to Interpret DS1852 Temperature and Voltage Readings.pdf
关键词: Interpret     DS1852     Temperat
