Using a PC with a DS3900 to Communicate with DS1267s, DS1867s, and DS1868s
关键词: DS1267, DS1867, DS1868, DS3900, 3-wire , digital pots, 3wire, digital potentiometers
Abstract: This application note describes how to use the DS3900 PC serial port to 3-wire interface to communicate with the three digital pots, the DS1267, DS1867, and DS1868, which use this shift register interface for programming. The DS3900 is a module that has a MAX3223 RS-232 transceiver and a microprocessor which acts as an interface between the PC's serial port the 3-wire device being controlled. The transceiver allows the module’s microprocessor to communicate with a PC and the microprocessor implements a command structure, via its parallel port, to allow a PC to read or write the three digital potentiometers. The application note describes the DS3900 and how to interface it to the devices under test. The source code described in the article is available on Dallas Semiconductor’s FTP site.
Using a PC with a DS3900 to Communicate with DS1267s, DS1867s, and DS1868s.pdf
共1条
共1条
请大声喊出:我要开发板! | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! |
打赏帖 | |
如何实现基于NXPiMX.RT1021的BH1730采集被打赏5分 | |
玩转“DFRobot盖革计数器模块”准备工作认识模块知识分享被打赏30分 | |
老胖子聊电路--分析一个反馈电路被打赏50分 |
