关键词: aliasing, aperture, INL, crosstalk, coherent sampling, common-mode, DNL, dithering, ENOB, flash, frequency bin, glitch energy, latency, monotonicity, intermodulation, SNR, NPR, quantization, SFDR, SINAD, spectral leakage, THD, VSWR
Abstract: The glossary provides a detailed description of AC performance terms related to high-speed data converters such as ADCs and DACs. It also gives some insight into the test conditions these parameters are specified for.
Glossary of Frequently Used High-Speed Data Converter Terms.pdf
