【应用手册】AN 610: Implementing Deterministic Latency for CPRI and OBSAI Protocols in Altera Devices
This application note describes how to implement deterministic latency for Common
Public Radio Interface (CPRI) and Open Base Station Architecture Initiative Reference
Point 3-01 (OBSAI RP3-01) protocols with transceivers in Stratix® IV, HardCopy® IV,
Arria® II GX, and Cyclone® IV devices. It also describes the transceiver configuration
and clocking scheme to implement deterministic latency. You can create your
proprietary CPRI, OBSAI RP3-01, or other interfaces requiring deterministic latency
designs based on the implementation descriptions in this application note.
The CPRI and OBSAI RP3-01 are point-to-point, high-speed serial interfaces in
wireless applications for connecting base station component and remote radio heads.
Figure 1 shows various CPRI topologies. Fundamentally, CPRI connects between a
radio equipment controller (REC) and radio equipment (RE) modules (in single-hop
connections). For high bandwidth, multiple REs can be chained to a single REC (in
multi-hop connections), with CPRI links between the RE modules. The REC port is
always the master port and the RE is the slave port for links between REC and RE.
For links between REs, the port nearest to REC is the master.an610.pdf
共1条
共1条
| Chaos-nano:专为低资源单片机设计的轻量级协作式异步操作系统(ATMEGA328P轻量级操作系统)—— 详细介绍被打赏¥16元 | |
| FPGA配置被打赏¥10元 | |
| Chaos-nano协作式异步操作系统:赋能MicrochipAVR8位单片机的革新之路被打赏¥15元 | |
| 基于esp32开发时串口工具的注意点被打赏¥24元 | |
| 基于FireBeetle2ESP32-C5开发板的舵机控制被打赏¥20元 | |
| 【分享开发笔记,赚取电动螺丝刀】MAX78000开发板制作的电子相册被打赏¥32元 | |
| 基于FireBeetle2ESP32-C5开发板的超声波测距及显示被打赏¥21元 | |
| FireBeetle2ESP32-C5上RTC电子时钟的实现被打赏¥25元 | |
| 【分享开发笔记,赚取电动螺丝刀】MAX78000开发板读取SD卡被打赏¥23元 | |
| 【S32K3XX】Standby RAM 重启后数据异常问题调查被打赏¥38元 | |
