【应用笔记】AN623:使用DSP Builder高级模块实现重采样滤波器(AN 623: Using the DSP Builder Advanced Blockset to Implement Resampling Filters)
本应用笔记讨论使用DSP Builder高级模块实现重采样滤波器的各种设计技巧。
This application note discusses various design techniques for implementing
resampling filters using the Altera® DSP Builder advanced blockset. The DSP Builder
advanced blockset supports constraint-based high-level synthesis and is particularly
efficient for implementing multiple channel, high-performance resampling filters. You
can use the DSP Builder advanced blockset to quickly map highly abstract algorithms
to model-based Simulink designs and to generate near optimal HDL code based on
your design requirements. In addition, because you can parameterize the DSP Builder
advanced blockset components, you can quickly update your design if the
specification changes.an623.pdf
共1条
共1条
