web登录界面,复位后,默认用户名/口令是:admin/admin
 查看的系统信息,貌似没dd,tt,op显示得全面
[attachment=2398957]
默认的时间服务器居然是openwrt的,看样子这个系统很有可能用了openwrt的源代码
配合3G上网卡,可以收发短信
USB口也有网络共享磁盘的功能
带有PPTP VPN服务器功能
wan口配置,可以双wan
无线配置,默认支持多ssid
接上TTL线,从Consol口得到的启动信息如下,供参考:
复制代码
- +Trying boot from system <A>
 - ...use system <A>
 - Trying NPE-C...phy for NPE-C found!
 - success. Using NPE-C with PHY 1.
 - Ethernet lan: MAC address 00:03:47:df:32:a8
 - IP: 192.168.3.44/255.255.255.0, Gateway: 192.168.3.1
 - Default server: 192.168.3.78
 - M/N: 600100907101311561
 - S/N: 11014002293E7BD9E
 - MAC: 00:22:93:E7:BD:9E
 - RedBoot(tm) bootstrap and debug environment [ROMRAM]
 - Red Hat certified release, version 2.04 - built 03:04:15, Mar 26 2010
 - Platform: KIXRP435 Development Platform (IXP43X) BE
 - Copyright (C) 2000, 2001, 2002, 2003, 2004, 2007 Free Software Foundation, Inc.
 - RAM: 0x00000000-0x08000000, [0x00082b08-0x07fd1000] available
 - FLASH: 0x50000000 - 0x50400000, 64 blocks of 0x00010000 bytes each.
 - == Executing boot script in 1.000 seconds - enter ^C to abort
 - RedBoot>fis load -b 0x100000 ker1;exec -b 0x00100000 -l 0x00120000 -c "console=t
 - tyMTD,panic console=ttyS0,115200 root=/dev/mtdblock8 ro rootfstype=yaffs2 init=/
 - etc/preinit"
 - Uncompressing Linux.............................................................
 - .............. done, booting the kernel.
 - Linux version 2.6.20.3 (doris.wang@build-new) (gcc version 3.4.1 20040714 (TimeS
 - ys 3.4.1-7)) #2 Fri Mar 26 03:07:10 EDT 2010
 - CPU: XScale-IXP43x Family [69054041] revision 1 (ARMv5TE), cr=000039ff
 - Machine: Intel KIXRP435 Reference Platform
 - Memory policy: ECC disabled, Data cache writeback
 - CPU0: D VIVT undefined 5 cache
 - CPU0: I cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
 - CPU0: D cache: 32768 bytes, associativity 32, 32 byte lines, 32 sets
 - Built 1 zonelists. Total pages: 32512
 - Kernel command line: console=ttyMTD,panic console=ttyS0,115200 root=/dev/mtdbloc
 - k8 ro rootfstype=yaffs2 init=/etc/preinit
 - PID hash table entries: 512 (order: 9, 2048 bytes)
 - Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
 - Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
 - Memory: 128MB = 128MB total
 - Memory: 127488KB available (2096K code, 203K data, 88K init)
 - Mount-cache hash table entries: 512
 - CPU: Testing write buffer coherency: ok
 - NET: Registered protocol family 16
 - IXP4xx: Using 16MiB expansion bus window size
 - PCI: IXP4xx is host
 - PCI: IXP4xx Using direct access for memory space
 - PCI: bus0: Fast back to back transfers enabled
 - dmabounce: registered device 0000:00:0e.0 on pci bus
 - SCSI subsystem initialized
 - usbcore: registered new interface driver usbfs
 - usbcore: registered new interface driver hub
 - usbcore: registered new device driver usb
 - NET: Registered protocol family 2
 - IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
 - TCP established hash table entries: 4096 (order: 2, 16384 bytes)
 - TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
 - TCP: Hash tables configured (established 4096 bind 2048)
 - TCP reno registered
 - ixp4xx GPIO-based infrared receiver initialize
 - NetWinder Floating Point Emulator V0.97 (double precision)
 - JFFS2 version 2.2. (C) 2001-2006 Red Hat, Inc.
 - yaffs Mar 26 2010 03:05:26 Installing.
 - io scheduler noop registered
 - io scheduler deadline registered (default)
 - IXP4xx Watchdog Timer: heartbeat 60 sec
 - Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
 - serial8250.0: ttyS0 at MMIO 0xc8000000 (irq = 15) is a XScale
 - tun: Universal TUN/TAP device driver, 1.6
 - tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
 - IXP4XX-Flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
 - Amd/Fujitsu Extended Query Table at 0x0040
 - number of CFI chips: 1
 - cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
 - Searching for RedBoot partition table in IXP4XX-Flash.0 at offset 0x3f0000
 - 8 RedBoot partitions found on MTD device IXP4XX-Flash.0
 - Creating 8 MTD partitions on "IXP4XX-Flash.0":
 - 0x00000000-0x00080000 : "RedBoot"
 - 0x00080000-0x001a0000 : "ker1"
 - 0x001a0000-0x002c0000 : "ker2"
 - 0x002c0000-0x003d0000 : "config"
 - 0x003d0000-0x003e0000 : "flags"
 - 0x003e0000-0x003f0000 : "panic"
 - 0x003f0000-0x003ff000 : "FIS directory"
 - mtd: partition "FIS directory" doesn't end on an erase block -- force read-only
 - 0x003ff000-0x00400000 : "RedBoot config"
 - mtd: partition "RedBoot config" doesn't start on an erase block boundary -- forc
 - e read-only
 - NAND device: Manufacturer ID: 0xad, Chip ID: 0xd3 (Hynix NAND 1GiB 3,3V 8-bit)
 - Scanning device for bad blocks
 - Bad eraseblock 1816 at 0x1c600000
 - Creating 4 MTD partitions on "ixp4xx-nand":
 - 0x00000000-0x08000000 : "root1"
 - 0x08000000-0x10000000 : "root2"
 - 0x10000000-0x1ff00000 : "data"
 - 0x1ff00000-0x40000000 : "backup"
 - ixp4xx-ehci ixp4xx-ehci.0: IXP4XX EHCI Host Controller
 - ixp4xx-ehci ixp4xx-ehci.0: new USB bus registered, assigned bus number 1
 - ixp4xx-ehci ixp4xx-ehci.0: irq 32, io mem 0xcd000100
 - ixp4xx-ehci ixp4xx-ehci.0: USB 0.0 started, EHCI 1.00, driver 27 July 2006
 - usb usb1: configuration #1 chosen from 1 choice
 - hub 1-0:1.0: USB hub found
 - hub 1-0:1.0: 1 port detected
 - ixp4xx-ehci ixp4xx-ehci.1: IXP4XX EHCI Host Controller
 - ixp4xx-ehci ixp4xx-ehci.1: new USB bus registered, assigned bus number 2
 - ixp4xx-ehci ixp4xx-ehci.1: irq 33, io mem 0xce000100
 - ixp4xx-ehci ixp4xx-ehci.1: USB 0.0 started, EHCI 1.00, driver 27 July 2006
 - usb usb2: configuration #1 chosen from 1 choice
 - hub 2-0:1.0: USB hub found
 - hub 2-0:1.0: 1 port detected
 - Initializing USB Mass Storage driver...
 - usbcore: registered new interface driver usb-storage
 - USB Mass Storage support registered.
 - rx8025_init
 - i2c /dev entries driver
 - : power-on reset was detected, you may have to readjust the clock
 - result1[1] 0x3
 - driver name is rx8025<6>loaded driver for RX-8025 SA/NB on addr 50
 - NET: Registered protocol family 26
 - ip_conntrack version 2.4 (8192 buckets, 65536 max) - 308 bytes per conntrack
 - ip_tables: (C) 2000-2006 Netfilter Core Team
 - arp_tables: (C) 2002 David S. Miller
 - TCP westwood registered
 - NET: Registered protocol family 17
 - Bridge firewalling registered
 - 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
 - All bugs added by David S. Miller <davem@redhat.com>
 - XScale DSP coprocessor detected.
 - drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
 - Time: OSTS clocksource has been installed.
 - yaffs: dev is 32505864 name is "mtdblock8"
 - yaffs: passed flags ""
 - yaffs: Attempting MTD mount on 31.8, "mtdblock8"
 - yaffs_read_super: isCheckpointed 0
 - VFS: Mounted root (yaffs2 filesystem) readonly.
 - Freeing init memory: 88K
 - Warning: unable to open an initial console.
 - - preinit -
 - - init -
 - ixp400_eth: Initializing IXP400 NPE Ethernet driver software v. 1.8
 - ixp400_eth: CPU clock speed (approx) = 532 MHz
 - ixEthMiiPhyId[21040261] value is 0x141
 - ixEthMiiPhyScan() end numphys= 8
 - ixp400_eth: eth1 is using NPEC and the PHY at address 0
 - ixp400_eth: eth2 is using NPEA and the PHY at address 1
 - ixp400_eth: Use default MAC address 00:02:b3:02:02:02 for port 1
 - ixp400_eth: Use default MAC address 00:02:b3:03:03:03 for port 2
 - init started: BusyBox v1.4.2 (2010-03-26 03:17:59 EDT) multi-call binary
 - Please press Enter to activate this console. Jan 1 00:00:18 (none) syslog.info
 - syslogd started: BusyBox v1.4.2
 - Jan 1 00:00:18 (none) user.notice kernel: klogd started: BusyBox v1.4.2 (2010-0
 - 3-26 03:17:59 EDT)
 - Jan 1 00:00:18 (none) user.notice kernel: Linux version 2.6.20.3 (doris.wang@bu
 - ild-new) (gcc version 3.4.1 20040714 (TimeSys 3.4.1-7)) #2 Fri Mar 26 03:07:10 E
 - DT 2010
 - Jan 1 00:00:18 (none) user.warn kernel: CPU: XScale-IXP43x Family [69054041] re
 - vision 1 (ARMv5TE), cr=000039ff
 - Jan 1 00:00:18 (none) user.warn kernel: Machine: Intel KIXRP435 Reference Platf
 - orm
 - Jan 1 00:00:18 (none) user.warn kernel: Memory policy: ECC disabled, Data cache
 - writeback
 - Jan 1 00:00:18 (none) user.debug kernel: On node 0 totalpages: 32768
 - Jan 1 00:00:18 (none) user.debug kernel: DMA zone: 128 pages used for memmap
 - Jan 1 00:00:18 (none) user.debug kernel: DMA zone: 0 pages reserved
 - Jan 1 00:00:18 (none) user.debug kernel: DMA zone: 16256 pages, LIFO batch:3
 - Jan 1 00:00:18 (none) user.debug kernel: Normal zone: 128 pages used for memm
 - ap
 - Jan 1 00:00:18 (none) user.debug kernel: Normal zone: 16256 pages, LIFO batch
 - :3
 - Jan 1 00:00:18 (none) user.warn kernel: CPU0: D VIVT undefined 5 cache
 - Jan 1 00:00:18 (none) user.warn kernel: CPU0: I cache: 32768 bytes, associativi
 - ty 32, 32 byte lines, 32 sets
 - Jan 1 00:00:18 (none) user.warn kernel: CPU0: D cache: 32768 bytes, associativi
 - Jan 1 00:00:18 (none) user.warn kernel: Built 1 zonelists. Total pages: 32512
 - Jan 1 00:00:18 (none) user.notice kernel: Kernel command line: console=ttyMTD,p
 - anic console=ttyS0,115200 root=/dev/mtdblock8 ro rootfstype=yaffs2 init=/etc/pre
 - init
 - Jan 1 00:00:18 (none) user.warn kernel: PID hash table entries: 512 (order: 9,
 - 2048 bytes)
 - Jan 1 00:00:18 (none) user.warn kernel: Dentry cache hash table entries: 16384
 - (order: 4, 65536 bytes)
 - Jan 1 00:00:18 (none) user.warn kernel: Inode-cache hash table entries: 8192 (o
 - rder: 3, 32768 bytes)
 - Jan 1 00:00:18 (none) user.info kernel: Memory: 128MB = 128MB total
 - Jan 1 00:00:18 (none) user.notice kernel: Memory: 127488KB available (2096K cod
 - e, 203K data, 88K init)
 - Jan 1 00:00:18 (none) user.debug kernel: Calibrating delay loop... 532.48 BogoM
 - IPS (lpj=2662400)
 - Jan 1 00:00:18 (none) user.warn kernel: Mount-cache hash table entries: 512
 - Jan 1 00:00:18 (none) user.info kernel: CPU: Testing write buffer coherency: ok
 - Jan 1 00:00:18 (none) user.info kernel: NET: Registered protocol family 16
 - Jan 1 00:00:18 (none) user.warn kernel: IXP4xx: Using 16MiB expansion bus windo
 - w size
 - Jan 1 00:00:18 (none) user.warn kernel: PCI: IXP4xx is host
 - Jan 1 00:00:18 (none) user.warn kernel: PCI: IXP4xx Using direct access for mem
 - ory space
 - Jan 1 00:00:18 (none) user.info kernel: PCI: bus0: Fast back to back transfers
 - enabled
 - Jan 1 00:00:18 (none) user.info kernel: dmabounce: registered device 0000:00:0e
 - .0 on pci bus
 - Jan 1 00:00:18 (none) user.notice kernel: SCSI subsystem initialized
 - Jan 1 00:00:18 (none) user.info kernel: usbcore: registered new interface drive
 - r usbfs
 - r hub
 - Jan 1 00:00:18 (none) user.info kernel: usbcore: registered new device driver u
 - sb
 - Jan 1 00:00:18 (none) user.info kernel: NET: Registered protocol family 2
 - Jan 1 00:00:18 (none) user.warn kernel: IP roipt_domain loading
 - ute cache hash table entries: 1024 (order: 0, 4096 bytes)
 - Jan 1 00:00:18 (none) user.warn kernel: TCP established hash table entries: 409
 - 6 (order: 2, 16384 bytes)
 - Jan 1 00:00:18 (none) user.warn kernel: TCP bind hash table entries: 2048 (orde
 - r: 1, 8192 bytes)
 - Jan 1 00:00:18 (none) user.info kernel: TCP: Hash tables configured (establishe
 - d 4096 bind 2048)
 - Jan 1 00:00:18 (none) user.info kernel: TCP reno registered
 - Jan 1 00:00:18 (none) user.info kernel: ixp4xx GPIO-based infrared receiver ini
 - tialize
 - Jan 1 00:00:18 (none) user.warn kernel: NetWinder Floating Point Emulator V0.97
 - (double precision)
 - Jan 1 00:00:18 (none) user.info kernel: JFFS2 version 2.2. (C) 2001-2006 Red Ha
 - t, Inc.
 - Jan 1 00:00:18 (none) user.warn kernel: yaffs Mar 26 2010 03:05:26 Installing.
 - Jan 1 00:00:18 (none) user.info kernel: io scheduler noop registered
 - Jan 1 00:00:18 (none) user.info kernel: io scheduler deadline registered (defau
 - lt)
 - Jan 1 00:00:18 (none) user.warn kernel: IXP4xx Watchdog Timer: heartbeat 60 sec
 - Jan 1 00:00:18 (none) user.info kernel: Serial: 8250/16550 driver $Revision: 1.
 - 90 $ 2 ports, Jan 1 00:00:18 (none) user.info kernel: serial8250.0: ttyS0 at MM
 - IO 0xc8000000 (irq = 15) is a XScale
 - Jan 1 00:00:18 (none) user.info kernel: tun: Universal Tnetfilter PSD loaded -
 - Success
 - UN/TAP device driver, 1.6
 - Jan 1 00:00:18 (none) user.info kernel: tun: (C) 1999-2004 Max Krasnyansky <max
 - k@qualcomm.com>
 - Jan 1 00:00:18 (none) user.info kernel: IXP4XX-Flash.0: Found 1 x16 devices at
 - 0x0 in 16-bit bank
 - Jan 1 00:00:18 (none) user.warn kernel: Amd/Fujitsu Extended Query Table at 0x
 - 0040
 - Jan 1 00:00:18 (none) user.notice kernel: number of CFI chips: 1
 - Jan 1 00:00:18 (none) user.notice kernel: cfi_cmdset_0002: Disabling erase-susp
 - end-program due to code brokenness.
 - Jan 1 00:00:18 (none) user.notice kernel: Searching for RedBoot partition table
 - in IXP4XX-Flash.0 at offset 0x3f0ipt_time loading
 - 000
 - Jan 1 00:00:18 (none) user.notice kernel: 8 RedBoot partitions found on MTD dev
 - ice IXP4XX-Flash.0
 - Jan 1 00:00:18 (none) user.notice kernel: Creating 8 MTD partitions on "IXP4XX-
 - Flash.0":
 - Jan 1 00:00:18 (none) userJan 1 00:00:18 (none) user.notiJan 1 00:00:18 (none
 - ) user.notiJan 1 00:00:18 (none) user.warnJan 1 00:00:18 (none) user.infoJan
 - 1 00:00:18 (none) user.infoJan 1 00:00:18 (none) user.infoJan 1 00:00:18 (none
 - ) user.warnJan 1 00:00:18 (none) user.infoJan 1 00:00:18 (none) user.infoJan
 - 1 00:00:18 (none) user.warnJan 1 00:00:18 (none) user.warnJan 1 00:00:18 (none
 - ) user.warnJan 1 00:00:18 (none) user.warn kernel: ipt_domain loading
 - Jan 1 00:00:19 (none) user.warn kernel: netfilter PSD loaded - Success
 - Jan 1 00:00:19 (none) user.warn kernel: ipt_time loading
 - netem: version 1.2
 - Jan 1 00:00:19 (none) user.info kernel: netem: version 1.2
 - u32 classifier
 - Performance counters on
 - input device check on
 - Actions configured
 - Jan 1 00:00:19 (none) user.warn kernel: u32 classifier
 - Jan 1 00:00:19 (none) user.warn kernel: Performance counters on
 - Jan 1 00:00:19 (none) user.warn kernel: input device check on
 - Jan 1 00:00:19 (none) user.warn kernel: Actions configured
 - cpld driver load ok ver:0.0.1
 - Jan 1 00:00:20 (none) user.warn kernel:
 - Jan 1 00:00:20 (none) user.warn kernel: cpld driver load ok ver:0.0.1
 - led: module license 'Itibia GPL' taints kernel.
 - leds: LED Initialize OK.
 - Jan 1 00:00:20 (none) user.warn kernel: led: module license 'Itibia GPL' taints
 - kernel.
 - Jan 1 00:00:20 (none) user.info kernel: leds: LED Initialize OK.
 - hwport: hwport module load OK.
 - Jan 1 00:00:20 (none) user.info kernel: hwport: hwport module load OK.
 - port 0 now status: 0
 - send sigal to application,port 0 status: 0
 - port 1 now status: 0
 - send sigal to application,port 1 status: 0
 - port 2 now status: 0
 - send sigal to application,port 2 status: 0
 - port 3 now status: 0
 - send sigal to application,port 3 status: 0
 - port 4 now status: 0
 - send sigal to application,port 4 status: 0
 - port 5 now status: 0
 - send sigal to application,port 5 status: 0
 - port 6 now status: 0
 - send sigal to application,port 6 status: 0
 - port 7 now status: 0
 - send sigal to application,port 7 status: 0
 - Jan 1 00:00:20 (none) user.warn kernel: port 0 now status: 0
 - Jan 1 00:00:20 (none) user.warn kernel: send sigal to application,port 0 statu
 - s: 0
 - Jan 1 00:00:20 (none) user.warn kernel: port 1 now status: 0
 - Jan 1 00:00:20 (none) user.warn kernel: send sigal to application,port 1 statu
 - s: 0
 - Jan 1 00:00:20 (none) user.warn kernel: port 2 now status: 0
 - Jan 1 00:00:20 (none) user.warn kernel: send sigal to application,port 2 statu
 - s: 0
 - Jan 1 00:00:20 (none) user.warn kernel: port 3 now status: 0
 - Jan 1 00:00:20 (none) user.warn kernel: send sigal to application,port 3 statu
 - s: 0
 - Jan 1 00:00:20 (none) user.warn kernel: port 4 now status: 0
 - Jan 1 00:00:20 (none) user.warn kernel: send sigal to application,port 4 statu
 - s: 0
 - Jan 1 00:00:20 (none) user.warn kernel: port 5 now status: 0
 - Jan 1 00:00:20 (none) user.warn kernel: send sigal to application,port 5 statu
 - s: 0
 - Jan 1 00:00:20 (none) user.warn kernel: port 6 now status: 0
 - Jan 1 00:00:20 (none) user.warn kernel: send sigal to application,port 6 statu
 - s: 0
 - Jan 1 00:00:20 (none) user.warn kernel: port 7 now status: 0
 - Jan 1 00:00:20 (none) user.warn kernel: send sigal to application,port 7 statu
 - s: 0
 - yaffs: dev is 32505866 name is "mtdblock10"
 - yaffs: Attempting MTD mount on 31.10, "mtdblock10"
 - block 793 is bad
 - Jan 1 00:00:22 (none) user.info kernel: yaffs: dev is 32505866 name is "mtdbloc
 - k10"
 - Jan 1 00:00:22 (none) user.info kernel: yaffs: passed flags ""
 - Jan 1 00:00:22 (none) user.warn kernel: yaffs: Attempting MTD mount on 31.10, "
 - mtdblock10"
 - Jan 1 00:00:22 (none) user.warn kernel: block 793 is bad
 - yaffs: dev is 32505867 name is "mtdblock11"
 - yaffs: Attempting MTD mount on 31.11, "mtdblock11"
 - yaffs: restored from checkpoint
 - yaffs_read_super: isCheckpointed 1
 - Get time...
 - Probing device eth0:
 - No such device
 - Probing device eth1:
 - PHY found!
 - PPP generic driver version 2.4.2
 - PPP MPPE Compression module registered
 - ip_conntrack_pptp version 3.1 loaded
 - ip_nat_pptp version 3.0 loaded
 - usbflash: USB flash driver load.
 - Register forward hook ok!
 - regex_init start
 - regex_init re2post_new end
 - regex_init:malloc l1(8288),l2(8288)
 - regex_init OK
 - dfa_init:smp running in gateway mode
 - dfa module init ok!
 - NET: Registered protocol family 24
 - PPTP driver version 0.8.2
 - wlan: 0.8.4.2 (Atheros/multi-bss)
 - ath_hal: 0.9.17.1 (AR5212, RF5111, RF5112, RF2413, RF5413, REGOPS_FUNC)
 - ath_rate_atheros: Version 2.0.1
 - Copyright (c) 2001-2004 Atheros Communications, Inc, All Rights Reserved
 - ath_dfs: Version 2.0.0
 - Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
 - ath_pci: 0.9.4.5 (Atheros/multi-bss)
 - PCI: enabling device 0000:00:0e.0 (0340 -> 0342)
 - wifi0: 11b rates: 1Mbps 2Mbps 5.5Mbps 11Mbps
 - wifi0: 11g rates: 1Mbps 2Mbps 5.5Mbps 11Mbps 6Mbps 9Mbps 12Mbps 18Mbps 24Mbps 36
 - Mbps 48Mbps 54Mbps
 - wifi0: mac 7.8 phy 4.5 radio 5.6
 - wifi0: Use hw queue 1 for WME_AC_BE traffic
 - wifi0: Use hw queue 0 for WME_AC_BK traffic
 - wifi0: Use hw queue 2 for WME_AC_VI traffic
 - wifi0: Use hw queue 3 for WME_AC_VO traffic
 - wifi0: Use hw queue 8 for CAB traffic
 - wifi0: Use hw queue 9 for beacons
 - wifi0: Atheros 5212: mem=0x48000000, irq=26
 - wlan: mac acl policy registered
 - usbcore: registered new interface driver usbserial
 - drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
 - usbcore: registered new interface driver usbserial_generic
 - drivers/usb/serial/usb-serial.c: USB Serial Driver core
 - drivers/usb/serial/usb-serial.c: USB Serial support registered for GSM modem (1-
 - port)
 - usbcore: registered new interface driver zte
 - drivers/usb/evdo/zte.c: USB Driver for GSM modems: v1.0.1
 - up: dev_media_check_thread() port=1 PhyIndex=0, linkMonitor=0
 - eth1.1: Setting MAC address to 00 22 93 e7 bd 9f.
 - device eth1 entered promiscuous mode
 - VLAN (eth1.1): Setting underlying device (eth1) to promiscious mode.
 - eth1.1: dev_set_promiscuity(master, 1)
 - device eth1.1 entered promiscuous mode
 - br-lan1: port 1(eth1.1) entering learning state
 - br-lan1: topology change detected, propagating
 - br-lan1: port 1(eth1.1) entering forwarding state
 - up: dev_media_check_thread() port=2 PhyIndex=1, linkMonitor=0
 - eth2.8: Setting MAC address to 00 22 93 e7 bd 9e.
 - device eth2 entered promiscuous mode
 - VLAN (eth2.8): Setting underlying device (eth2) to promiscious mode.
 - qos Interface loaded
 - Qos_SET_REGS:the qos reg para is:
 - dev_add: 17, reg_addr:a, val:3000
 - Qos_SET_REGS:read value you write just now is:
 - dev_add: 16, reg_addr:a, val:3000
 - ixCryptoAccInit failed, assuming already initialised!
 - klips_info:ipsec_init: KLIPS startup, Openswan KLIPS IPsec stack version: 2.4.9
 - NET: Registered protocol family 15
 - klips_info:ipsec_alg_init: KLIPS alg v=0.8.1-0 (EALG_MAX=255, AALG_MAX=251)
 - klips_info:ipsec_alg_init: calling ipsec_alg_static_init()
 - ipsec_aes_init(alg_type=15 alg_id=12 name=aes): ret=0
 - ipsec_3des_init(alg_type=15 alg_id=3 name=3des): ret=0
 - apam_uduf_set get the uduf switch -- disable
 - device ra0 entered promiscuous mode
 - br-lan1: port 2(ra0) entering learning state
 - br-lan1: port 2(ra0) entering forwarding state
 - Itibia Corporation 2008 presents
 - Bizbox login:
Over,谢谢观赏
