这个是键盘的程序 是对的 用ise综合对了 想知道 这个文件现在已经是顶层文件了吗 我想在板子上实现下一步该做什么了
-- Company:-- Engineer:
-- Create Date: 23:53:46 04/09/2014
-- Design Name:
-- Module Name: keyboard - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity keyboard is
port(
k_data:in std_logic;
k_clock:in std_logic;
out_data:out std_logic_vector(5 downto 0));
end keyboard;
architecture Behavioral of keyboard is
signal tempdata:std_logic_vector(11 downto 0):="000000000000";
signal count,count1:integer range 0 to 11:=0;
signal datascan,previous_data:std_logic_vector(7 downto 0);
signal out_data_temp:std_logic_vector(5 downto 0);
signal chang_clk:std_logic:='0';
begin
out_data<=out_data_temp;
process(k_clock)
begin
if(k_clock'event and k_clock='0')then
if (count=10)then
count<=0;
datascan<=tempdata(8 downto 1);
else
count<=count+1;
tempdata(count)<=k_data;
end if;
end if;
if(k_clock'event and k_clock='1')then
if(count=10)then
count1<=0;
previous_data<=datascan;
chang_clk<='1';
else
count1<=count1+1;
chang_clk<='0';
end if;
end if;
end process;
process(chang_clk)
begin
if(chang_clk'event and chang_clk='1')then
if((not(datascan=previous_data))and((datascan="11110000")or(previous_data="11110000")))then
out_data_temp<="000000";
else
case datascan is
when"00010101"=>out_data_temp<="000001";
when"00011101"=>out_data_temp<="000010";
when"00100100"=>out_data_temp<="000011";
when"00101101"=>out_data_temp<="000100";
when"00101100"=>out_data_temp<="000101";
when"00110101"=>out_data_temp<="000110";
when"00111100"=>out_data_temp<="000111";
when"00010110"=>out_data_temp<="010001";
when"00011110"=>out_data_temp<="010010";
when"00100110"=>out_data_temp<="010011";
when"00100101"=>out_data_temp<="010100";
when"00101110"=>out_data_temp<="010101";
when"00110110"=>out_data_temp<="010110";
when"00111101"=>out_data_temp<="010111";
when"00011100"=>out_data_temp<="100001";
when"00011011"=>out_data_temp<="100010";
when"00100011"=>out_data_temp<="100011";
when"00101011"=>out_data_temp<="100100";-
when"00110100"=>out_data_temp<="100101";
when"00110011"=>out_data_temp<="100110";
when"00111011"=>out_data_temp<="100111";
when others=>out_data_temp<=out_data_temp;
end case;
end if;
end if;
end process;
end ;
 我要赚赏金 STM32
STM32 MCU
MCU 通讯及无线技术
通讯及无线技术 物联网技术
物联网技术 电子DIY
电子DIY 板卡试用
板卡试用 基础知识
基础知识 软件与操作系统
软件与操作系统 我爱生活
我爱生活 小e食堂
小e食堂
