电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » 标准电阻的阻值表
标准电阻的阻值表
2014-06-12 10:37:45     打赏
标准电阻的阻值表
电阻精度与常用阻值
转贴自 21ic 作者 sirliu
国家标准规定了电阻的阻值按其精度分为两大系列,分别为E-24系列和E-96系列,E-24系列精度为5%,E-96系列为1%,在这街窒盗兄?獾牡缱栉?潜甑缱瑁?夏巡晒骸O旅媪谐隽顺S玫?%和1%精度电阻的标称值,供大家设计时参考。??精度为5%的碳膜电阻,以欧姆为单位的标称值:
1.05.633 160 8203.9K 20K 100K 510K 2.7M
1.16.236 180 9104.3K 22K 110K 560K 3M
1.26.839 200 1K 4.7K 24K 120K 620K 3.3M
1.37.543 220 1.1K 5.1K 27K 130K 680K 3.6M
1.58.247 240 1.2K 5.6K 30K 150K 750K 3.9M
1.69.151 270 1.3K 6.2K 33K 160K 820K 4.3M
1.810 56 300 1.5K 6.6K 36K 180K 910K 4.7M
2.011 62 330 1.6K 7.5K 39K 200K 1M 5.1M
2.212 68 360 1.8K 8.2K 43K 220K 1.1M 5.6M
2.413 75 390 2K 9.1K 47K 240K 1.2M 6.2M
2.715 82 430 2.2K 10K51K 270K 1.3M 6.8M
3.016 91 470 2.4K 11K56K 300K 1.5M 7.5M
3.318 100510 2.7K 12K62K 330K 1.6M 8.2M
3.620 110560 3K 13K68K 360K 1.8M 9.1M
3.922 120620 3.2K 15K75K 390K 2M 10M
4.324 130680 3.3K 16K82K 430K 2.2M 15M
4.727 150750 3.6K 18K91K 470K 2.4M 22M
5.130
精度为1%的金属膜电阻,以欧姆为单位的标称值:
10331003321K 3.32K10.5K34K107K357K
10.233.21023401.02K3.4K 10.7K34.8K110K360K
10.5341053481.05K3.48K11K35.7K113K365K
10.734.81073501.07K3.57K11.3K36K115K374K
1135.71103571.1K 3.6K 11.5K36.5K118K383K
11.3361133601.13K3.65K11.8K37.4K120K390K
11.536.51153651.15K3.74K12K38.3K121K392K
11.837.41183741.18K3.83K12.1K39K124K402K
1238.31203831.2K 3.9K 12.4K39.2K127K412K
12.1391213901.21K3.92K12.7K40.2K130K422K
12.439.21243921.24K4.02K13K41.2K133K430K
12.740.21274021.27K4.12K13.3K42.2K137K432K
1341.21304121.3K 4.22K13.7K43K140K442K
13.342.21334221.33K4.32K14K43.2K143K453K
13.7431374301.37K4.42K14.3K44.2K147K464K
1443.21404321.4K 4.53K14.7K45.3K150K470K
14.344.21434421.43K4.64K15K46.4K154K475K
14.745.31474531.47K4.7K 15.4K47K158K487K
1546.41504641.5K 4.75K15.8K47.5K160K499K
15.4471544701.54K4.87K16K48.7K162K511K
15.847.51584751.58K4.99K16.2K49.9K165K523K
1648.71604871.6K 5.1K 16.5K51K169K536K
16.249.91624991.62K5.11K16.9K51.1K174K549K
16.5511655101.65K5.23K17.4K52.3K178K560K
16.951.11695111.69K5.36K17.8K53.6K180K562K
17.452.31745231.74K5.49K18K54.9K182K576K
17.853.61785361.78K5.6K 18.2K56K187K590K
1854.91805491.8K 5.62K18.7K56.2K191K604K
18.2561825601.82K5.76K19.1K57.6K196K619K
18.756.21875621.87K5.9K 19.6K59K200K620K
19.157.61915651.91K6.04K20K60.4K205K634K
19.6591965781.96K6.19K20.5K61.9K210K649K
2060.42005902K 6.2K 21K62K215K665K
20.561.92056042.05K6.34K21.5K63.4K220K680K
21622106192.1K 6.49K22K64.9K221K681K
21.563.42156202.15K6.65K22.1K66.5K226K698K
2264.92206342.2K 6.8K 22.6K68K232K715K
22.166.52216492.21K6.81K23.2K68.1K237K732K
22.6682266652.26K6.98K23.7K69.8K240K750K
23.268.12326802.32K7.15K24K71.5K243K768K
23.769.82376812.37 7.32K24.3K73.2K249K787K
2471.52406982.4K 7.5K 24.9K75K255K806K
24.373.22437152.43K7.68K25.5K76.8K261K820K
24.7752497322.49K7.87K26.1K78.7K267K825K
24.975.52557502.55K8.06K26.7K80.6K270K845K
25.576.82617682.61K8.2K 27K82K274K866K
26.178.72677872.67K8.25K27.4K82.5K280K887K
26.780.62708062.7K 8.45K28K84.5K287K909K
27822748202.74K8.66K28.7K86.6K294K910K
27.482.52808252.8K 8.8K 29.4K88.7K300K931K
2884.52878452.87K8.87K30K90.9K301K953K
28.786.62948662.94K9.09K30.1K91K309K976K
29.488.73008873.0K 9.1K 30.9K93.1K316K1.0M
3090.93019093.01K9.31K31.6K95.3K324K1.5M
30.1913099103.09K9.53K32.4K97.6K330K2.2M
30.993.13169313.16K9.76K33K100K 332K
31.695.33249533.24K10K33.2K102K 340K
32.497.63309763.3K 10.2K33.6K105K 348K
电阻阻值一览表
阻值1 阻值2 阻值3 阻值4 阻值5 阻值6 阻值7 阻值8 阻值90.1欧 1.0欧 10欧 100欧 1.0K 10K 100K 1.0M 10M0.11欧 1.1欧 11欧 110欧 1.1K 11K 110K 1.1M 11M0.12欧 1.2欧 12欧 120欧 1.2K 12K 120K 1.2M 12M0.13欧 1.3欧 13欧 130欧 1.3K 13K 130K 1.3M 13M0.15欧 1.5欧 15欧 150欧 1.5K 15K 150K 1.5M 15M0.16欧 1.6欧 16欧 160欧 1.6K 16K 160K 1.6M 16M0.18欧 1.8欧 18欧 180欧 1.8K 18K 180K 1.8M 18M0.20欧 2.0欧 20欧 200欧 2.0K 20K 200K 2.0M 20M0.22欧 2.2欧 22欧 220欧 2.2K 22K 220K 2.2M 22M0.24欧 2.4欧 24欧 240欧 2.4K 24K 240K 2.4M 0.27欧 2.7欧 27欧 270欧 2.7K 27K 270K 2.7M 0.30欧 3.0欧 30欧 300欧 3.0K 30K 300K 3.0M 0.33欧 3.3欧 33欧 330欧 3.3K 33K 330K 3.3M 0.36欧 3.6欧 36欧 360欧 3.6K 36K 360K 3.6M 0.39欧 3.9欧 39欧 390欧 3.9K 39K 390K 3.9M 0.43欧 4.3欧 43欧 430欧 4.3K 43K 430K 4.3M 0.47欧 4.7欧 47欧 470欧 4.7K 47K 470K 4.7M 0.51欧 5.1欧 51欧 510欧 5.1K 51K 510K 5.1M 0.56欧 5.6欧 56欧 560欧 5.6K 56K 560K 5.6M 0.62欧 6.2欧 62欧 620欧 6.2K 62K 620K 6.2M 0.68欧 6.8欧 68欧 680欧 6.8K 68K 680K 6.8M 0.75欧 7.5欧 75欧 750欧 7.5K 75K 750K 7.5M 0.82欧 8.2欧 82欧 820欧 8.2K 82K 820K 8.2M 0.91欧 9.1欧 91欧 910欧 9.1K 91K 910K 9.1M
关键词: 电阻
