#include <GLOBAL.h>
#include <stdlib.h>
#include <stdbool.h>
#include <msp430x41x.h>
#define SysSclOpen P1SEL|=BIT0;
#define SysSclClos P1SEL&=~BIT0;
#define SysSclIns P1DIR &=~BIT0
#define SysSclOut P1DIR |= BIT0
#define DataOutIn P1DIR &=~ BIT2
#define DataOutSt P1IN & BIT2
#define CardPowerOut P1DIR |= BIT3
#define CardPowerOpen P1OUT |= BIT3
#define CardPowerClose P1OUT &= ~BIT3
#define CardFrequencyOut P1DIR |= BIT5
#define CardFrequencyHig P1OUT |= BIT5
#define CardFrequencyLow P1OUT &= ~BIT5
#define CardChkSt BIT0
#define CardChkDirIn P1DIR &=~ BIT0
#define SendGapTime 170
#define SendHigTime 256
#define SendLowTime 80
//Delay(43);//---延时63.73微秒
//Delay(89);//----延时126.92微秒
//Delay(182);//---延时254.67微秒
//Delay(276);//---延时383.79微秒
const unsigned char CardPassword[4]={0x47,0x48,0x5A,0x42};
void CardInit(void)
CardPowerOut;
CardPowerClose;
CardChkDirIn;
P1IE = CardChkSt;
P1IES = CardChkSt;
void FieldClockOpen(void)
//TACCR0 = 13;//-------------------------
//TACCTL0=0x0080;//----------------------mode 4
//TACTL=0X0210;//------------------------SMCLK,TA_INT=Dis.
SysSclOut;
SysSclOpen;
CardFrequencyOut;
CardFrequencyHig;
WDT();
Delay(5000);
void FieldClockClos(void)
TACCR0=0;//-------------------------
TACCTL0=0;//----------------------mode 4
TACTL=0;//------------------------SMCLK,TA_INT=Dis.
SysSclClos//-----------------------------------------------------------关闭时钟
SysSclIns;
CardFrequencyLow;
WDT();
Delay(5000);
WDT();
Delay(5000);
void CardPowerOpenConn(void)
CardPowerOut;
CardPowerOpen;
FieldClockClos();
WDT();
Delay(5000);
FieldClockOpen();
DataOutIn;
void CardPowerClosConn(void)
CardPowerOut;
CardPowerClose;
FieldClockClos();
bool HeardChk(void)
bool ChkOk;
unsigned int ChkTime;
WDT();
ChkOk=1;
ChkTime=0;
//------------------------------------------------等待上升沿的到来同步信号检测
do
_NOP();
while(!(DataOutSt&BIT2));
if(ChkOk)
ChkTime=2;
//------------------------------------------------等待下降沿的到来同步信号检测1(24FC---HIG---384)
do
ChkTime=ChkTime+12;
if(ChkTime>1748)//-----最大极限数值:(384+96)*3.64=1748
break;
}//-------------------此处数据为等待时间(384微妙)同时防治死机!
while(DataOutSt&BIT2);
if((1164 < ChkTime)&&(ChkTime < 1630))//检测同步信号维持时间---最小数值:(384-64)*3.64=1164 最大数值:(384+64)*4=1630
ChkOk=1;
else
ChkOk=0;
if(ChkOk)
ChkTime=2;
//------------------------------------------------等待下降沿的到来同步信号检测1(8FC---LOW---128)
do
ChkTime=ChkTime+12;
if(ChkTime>815)//-----最大极限数值:(128+96)*3.64=815
break;
}//-------------------此处数据为等待时间(128微妙)同时防治死机!
if((232 < ChkTime)&&(ChkTime < 698))//检测同步信号维持时间---最小数值:(128-64)*3.64=349 最大数值:(128+64)*3.64=698
ChkOk=1;
Delay(182);//---延时256
Delay(42);//---延时63.73微秒
else
ChkOk=0;
return ChkOk;
//-----***-unsigned char RecvConn(void)-***-----//
//---功能描述:接收一个数据。
//---输入条件:无。
//---输出项目:RecvData。
void ReadData(void)
unsigned char i;
unsigned char Bits;
for(i=0;i<24;i++)
Bits = 0;
State = 1;
RecvData = 0;
while(State)
if( Bits < 8 )
Bits ++ ;
RecvData <<= 1;
if(DataOutSt&BIT2)
RecvData &= 0xFE;
else
RecvData |= 0x01;
if( Bits < 8)
Delay(170);//---16FC
else
Delay(85);//---8FC
if(DataOutSt&BIT2)
do
_NOP();
else
do
_NOP();
else
State=0;
Delay(35);
CardBuf=RecvData;
void CardRead(void)//-------------------读卡调用此函数
unsigned int i;
_DINT();
WDT();
CardErr=0;
RamCler(CardBuf,24);
for(i=0;i<512;i++)
if(HeardChk())
ReadData();
break;
WDT();
_EINT();
//------------------------------------------------------------------------------写卡程序
void SendZero(void)
CardFrequencyHig;
Delay(SendLowTime);
void SendOne(void)
CardFrequencyHig;
Delay(SendHigTime);
void SendGap(void)
CardFrequencyLow;
Delay(SendGapTime);
void RfStart(void)
CardFrequencyLow;
Delay(SendGapTime);
void RfReast(void)
RfStart();
SendZero();
SendGap();
SendZero();
SendGap();
FieldClockClos();
void SendWord(unsigned char Temp)
unsigned char i;
for(i=0;i<8;i++)
if(Temp&0x80)
SendOne();
SendGap();
else
SendZero();
SendGap();
Temp=Temp<<1;
void CardWrite(void)//------------------写卡调用此函数
unsigned char i,j;
unsigned char DataDptr,TempData;
_DINT();
for(i=1;i<7;i++)
WDT();
DataDptr=(i-1)*4;//----------------节起始地址
RfReast();
RfStart();
SendOne();
SendGap();
SendZero();
SendGap();
for(j=0;j<4;j++) //--------密码发送的四字节循环
WDT();
SendWord(CardPassword[j]);//----------------------------------发送密码
SendZero();
SendGap();
for(j=DataDptr;j<DataDptr+4;j++) //-----------块的四字节循环
SendWord(CardBuf[j]); //-------------发送一块数据(四个字节)
TempData=i<<5;
for(j=0;j<3;j++)
if(TempData&0x80)
SendOne();
SendGap();
else
SendZero();
SendGap();
TempData=TempData<<1;
FieldClockClos();
WDT();
Delay(5000);
_EINT();
